Need help looking for... - Electrician Talk - Professional Electrical Contractors Forum
Old 02-08-2012, 08:48 PM   #1
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
Default Need help looking for...
...a security light that is double switched capable: dusk to dawn/motion at dark and constant on, day or night.
I'd rather be sleeping.
Old 02-08-2012, 08:49 PM   #2
Bulldog1's Avatar
Rewards Points: 1,000
We always use RAB. I don't know if they have dusk to dawn. I bet they do and they make a quality flood and the longest lasting motion sensor I have ever used.
The Following User Says Thank You to Bulldog1 For This Useful Post:
jefft110 (02-08-2012)
Old 02-08-2012, 08:53 PM   #3
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
Put a SP switch in parallel to lamp holders..
Welcome to ET.. where the clowns don't need a tent to try and make people laugh..
Old 02-08-2012, 08:55 PM   #4
Bulldog1's Avatar
This is the one we use and it stays on 8 hours after dusk and motion activated after that until dawn. It is a quality light. If you are wanting to switch one head off the motion and one off a switch you could wire any flood that way.
http://www.rabweb.com/product_detail...duct=STL360HBW
The Following 3 Users Say Thank You to Bulldog1 For This Useful Post:
BuzzKill (02-08-2012), Restoration (02-08-2012), Whatevva (02-09-2012)
Old 02-08-2012, 09:10 PM   #5
I own stock in FotoMat!
Rewards Points: 6,520
Yep.... just send power past the PC right to the lamps.
Old 02-08-2012, 09:28 PM   #6
BuzzKill's Avatar
14/3 and share the N? Would that work?
Old 02-08-2012, 09:31 PM   #7
B4T
B4T's Avatar
(3) wire.. red.. switch control.. black .. motion control.. share neutral
electricalperson (02-08-2012)
Old 02-08-2012, 09:34 PM   #8
Rewards Points: 2,294
Two switches. First switch goes directly to the lamp heads. Second switch goes to the photocell or motion sensor. Of course, if the first switch is on the motion/photocell will not work.
I can't help it if I'm lucky
Old 02-08-2012, 09:36 PM   #9
Rewards Points: 1,038
Yeah RAB makes good stuff.
For some reason my supply house switched to tamlite.
jefft110 is offline   Reply With Quote
Old 02-08-2012, 09:37 PM   #10
BuzzKill's Avatar
I like one switch. Wire it with a constant hot.
Old 02-08-2012, 09:39 PM   #11
Bulldog1's Avatar
You must buy material from CES.
Old 02-08-2012, 09:43 PM   #12
Yep.
Old 02-08-2012, 11:12 PM   #13
Rewards Points: 864
RAB is great and their customer service is awesome had a client last year I used 8 of the ones Bulldog showed had one that was like the black sheep of the family I had it set and even went back twice due to customer complaints. I called customer service to get a new sensor to replace the bad one, they sent me a case of six it took a couple of days but change it out no problems since.
Sparky J is offline   Reply With Quote
The Following User Says Thank You to Sparky J For This Useful Post:
Bulldog1 (02-09-2012)
Old 02-08-2012, 11:21 PM   #14
backstay's Avatar
Rewards Points: 296
Most motion lights with dusk to dawn have a override feature. Turn the switch on/off/on quickly and the light stays on until the next dusk/dawn cycle.
Chris1971 (02-08-2012)
Old 02-08-2012, 11:36 PM   #15
Rewards Points: 530
Most cheap Lowes motion lights I've installed have all those functions. Sometimes the box doesn't say it clearly but when you toggle switch twice it works as normal flood lights. Toggle twice again and back to motion. I did learn though from this forum that RAB are superior to all.
Old 02-08-2012, 11:36 PM   #16
Rewards Points: 530
I'm late. Ha
Old 02-09-2012, 08:14 AM   #17
Bulldog1's Avatar
Every motion flood I have ever installed from cheap to expensive worked that way.
Old 02-09-2012, 08:18 AM   #18
Bulldog1's Avatar
Yep.
I buy very little from them anymore.They are always about 10% to 15% more for the same item than HD Supply is. A few years ago their pricing was in line with HD and we did buy a lot from them.
