need some motor wiring help - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2015, 01:47 PM   #1
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
Default need some motor wiring help
Motor is wired for 3phase 250volt. Customer would like it to work on single phase.
The motor label configuration looks like what I got looking at the motor wiring, so this leads me to believe I could change something in that terminal block instead? I dunno, I'm at a loss here.
I'd rather be sleeping.
Old 02-17-2015, 01:56 PM   #2
Lep
THE "BIG RED MACHINE"
Lep's Avatar
Rewards Points: 2,927
he's going to have to buy a single phase motor can't interchange three and single phase motors.
"See the ball; Hit the ball."
Pete Rose:Joe Morgan
Lep is offline   Reply With Quote
The Following 3 Users Say Thank You to Lep For This Useful Post:
CADPoint (02-17-2015), dronai (02-17-2015), John Valdes (02-18-2015)
Old 02-17-2015, 01:57 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Yep. ..
Old 02-17-2015, 01:59 PM   #4
BuzzKill's Avatar
whaat? dammit
Old 02-17-2015, 01:59 PM   #5
daveEM's Avatar
Rewards Points: 2,382
Sell him a 3 phase service.
Maybe some kind of single phase to three phase converter but I don't know how those work or if they are any good.
I like perfect.
Old 02-17-2015, 02:00 PM   #6
MadDawg's Avatar
Rewards Points: 375
Could use a 1Ph to 3Ph VFD if it's not too large.
MadDawg is offline   Reply With Quote
Old 02-17-2015, 02:02 PM   #7
BuzzKill's Avatar
so the wiring config is for 3 phase 240v and 3phase 480...sh*t.
Old 02-17-2015, 02:05 PM   #8
daveEM's Avatar
Yeah, plus it looks like it is only one component of a system? - Your 3rd. pic.
I like perfect.
Old 02-17-2015, 02:10 PM   #9
BuzzKill's Avatar
The terminal block sends all those wires to a contactor and on/off, forward/reverse switches...it's an industrial paper shredder.
Old 02-17-2015, 02:12 PM   #10
Lep
Lep's Avatar
You can't enter change 3 phase and single phase.But that three phase motor(in the picture) is dual voltage you'll have to look at the motor specs to see if motor voltages falls into the voltages you have in your building electrical system .you speak german? Lol
Perhaps a buck boost transformer if you have the correct system will give you the correct voltage for the motor.
Some of the other guys know more about this stuff than I do ,I used to rewind motors but I've forgotten a lot.
Old 02-17-2015, 02:16 PM   #11
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
Sell him a phase converter. Install a single phase fed inverter on the 3 phase loads or replace the motors with single phase ones. Those are your only options.
The Following 2 Users Say Thank You to Jhellwig For This Useful Post:
BuzzKill (02-17-2015), Dennis Alwon (02-18-2015)
Old 02-17-2015, 02:21 PM   #12
BuzzKill's Avatar
jeebus, after a quick search I found static, cnc phase, rotary...sheesh.
Old 02-17-2015, 02:27 PM   #13
Jhellwig's Avatar
If it is just one small motor an inverter might be the best option.
Old 02-17-2015, 02:57 PM   #14
Rewards Points: 3,090
BuzzKill
Are you saying one leg of single phase, or two legs?
Maybe I am missing something. Plus, why would the customer want to?
Just curious?
Borgi
Old 02-17-2015, 03:23 PM   #15
dronai's Avatar
Rewards Points: 163
I agree, but I think shredders require some horsepower
Old 02-17-2015, 03:27 PM   #16
dronai's Avatar
Rewards Points: 163
I worked on a single phase motor for a shredder, and the forwards and reverse controls for 3 phase are already in place with interlocks. You have to know what you are doing to replace with a single phase that has the same controls.
And with a Vfd, you would have to control this to the Vfd and not the motor (I think)
Old 02-17-2015, 03:54 PM   #17
MadDawg's Avatar
Rewards Points: 375
Usually they drive a high ratio gear reducer to use a small HP motor to get high torque at low speed. Most paper shredders are low RPM, high TORQUE
The Following User Says Thank You to MadDawg For This Useful Post:
dronai (02-17-2015)
Old 02-17-2015, 06:49 PM   #18
BuzzKill's Avatar
oh damn it that would have to get rewired as well?
Old 02-17-2015, 06:51 PM   #19
BuzzKill's Avatar
3 phase shredder and only single phase power available.
The Following User Says Thank You to BuzzKill For This Useful Post:
51360 (02-17-2015)
Old 02-17-2015, 06:59 PM   #20
MadDawg's Avatar
Rewards Points: 375
VFD drives have FWD and REV inputs built in
Motor wiring diagram MEISENBURG General Electrical Discussion 14 07-12-2014 01:25 PM
VFD Motor Wiring Dare General Electrical Discussion 7 10-17-2013 04:03 PM
Help With Motor Wiring A Little Short PLCs, VFDs, Motors and Controls 7 05-02-2013 11:21 PM
dayton motor wiring RM Sparks General Electrical Discussion 6 08-07-2009 03:39 PM
help wiring a motor javier6866 PLCs, VFDs, Motors and Controls 2 01-21-2009 04:16 PM
