need some motor wiring help - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-17-2015, 07:07 PM   #21
Rewards Points: 3,090
Originally Posted by BuzzKill View Post
3 phase shredder and only single phase power available.
Ok, misunderstood. Thought you were maybe taking this motor home for your customer's shop. Sorry.
Borgi
Old 02-17-2015, 07:23 PM   #22
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
It is as easy as this: buy a proper sized single phase input inverter for the motor you have, remove the starter from the control cabinet, put the inverter in its place, put the wire that went to the forward coil on the forward input on the inverter, put the wire that went to the reverse coil to the reverse input of the inverter, program inverter.
If it is a small enough inverter you might even be able to power it with 120 volt.
What is the horsepower, amps and rpm of the motor?
BuzzKill (02-17-2015)
Old 02-17-2015, 07:42 PM   #23
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,540
[QUOTE=J
What is the horsepower, amps and rpm of the motor?[/QUOTE]
I find out in the AM.
I'd rather be sleeping.
Old 02-17-2015, 10:24 PM   #24
Lep
THE "BIG RED MACHINE"
Lep's Avatar
Rewards Points: 2,927
Can we help you estamate the job too?
"See the ball; Hit the ball."
Pete Rose:Joe Morgan
Lep is offline   Reply With Quote
Old 02-18-2015, 11:27 AM   #25
dronai's Avatar
Rewards Points: 163
What about the OL's ?
Buzzkill, Is there schematic you can post ?
Old 02-18-2015, 12:28 PM   #26
Rewards Points: 1,830
I had to do this in a wood shop and I just used a phase converter
The Following 2 Users Say Thank You to Dennis Alwon For This Useful Post:
51360 (02-18-2015), pete87 (02-21-2015)
Old 02-18-2015, 01:29 PM   #27
Rewards Points: 2,080
don't need OL with vfd
The Following User Says Thank You to oliquir For This Useful Post:
dronai (02-20-2015)
Old 02-18-2015, 02:02 PM   #28
Rewards Points: 244
http://www.kbelectronics.com/Variabl...s_Chassis.html
The small chassis mount might just fit in place of the contactor. If its an IEC contactor it most likely will not fit and you will need to make some room or buy the enclosure model and mount it to the outside of the existing enclosure.
Note: The VFD can only operate the motor. You will need to control the VFD. So get the schematic from the web site and make your drawing to work from.
Old 02-18-2015, 02:18 PM   #29
Rewards Points: 134
Try www.northamericaphaseconverters.com
They probably have something that will do the trick. Might not be cheap but it's an alternative.
Sparky48 is offline   Reply With Quote
The Following User Says Thank You to Sparky48 For This Useful Post:
BuzzKill (02-18-2015)
Old 02-18-2015, 04:11 PM   #30
BuzzKill's Avatar
No schematic.
Motor is 208v, 3 phase, 11.6 amps and 3 HP.
Found this site, too:
https://www.phoenixphaseconverters.c...ase-converters
The Following User Says Thank You to BuzzKill For This Useful Post:
dronai (02-20-2015)
Old 02-18-2015, 04:22 PM   #31
Rewards Points: 1,702
No schematic.
The 5HP converters , just chump change over the 3HP
Pete
pete87 is offline   Reply With Quote
Old 02-18-2015, 05:13 PM   #32
BuzzKill's Avatar
Thanks for the help fellow sparks!
Old 02-20-2015, 10:01 AM   #33
dronai's Avatar
Rewards Points: 163
Any the decision yet ?
My only concern with using a VFD would be that dreaded phone call down the road that it failed ! I don't know the reliability for the application vs using a phase convertor .
3 HP convertor for $345.00
3 HP Single phase input drive $368.
Old 02-20-2015, 08:17 PM   #34
BuzzKill's Avatar
Sorry I missed this Dronai.
I'm getting a phase inverter; $345 for a 3HP model and $95 shipping. Mount it and the motor by the panel and run some conduit 30 feet to the showroom so he can show off his new shredder to customers. I haven't done the estimate yet, doing that over the week end. Prob a $1650ish job.
dronai (02-20-2015)
Old 02-21-2015, 01:36 PM   #35
Rewards Points: 12
Use a phase converter use them all the time east to hook up and cheep and reliable
South Hills is offline   Reply With Quote
Old 02-21-2015, 03:00 PM   #36
I have used the Rotary Converter , I too wonder which is more reliable in this
application ?
Pete
Old 02-21-2015, 08:51 PM   #37
dronai's Avatar
Rewards Points: 163
Also if he disconnects the forward and reverse starters to use for his VFD, there may be aux contacts that close when the starters close, that need to work. Some controls are also wired into the control circuit for safety devices like the access doors. That's why I said to look at the schematic first.
Old 02-21-2015, 09:19 PM   #38
Can't Remember
Rewards Points: 552
I tell customers, don't buy equipment off of ebay or wherever without talking to me first.
Old 02-21-2015, 10:16 PM   #39
Jhellwig's Avatar
No schematic.
You could buy a single phase motor since that is all the bigger it is but even decent inverter is cheaper.
A phase converter would seam silly for just one 3 phase motor load.
pete87 (02-22-2015)
Old 02-22-2015, 01:39 AM   #40
If you use a static phase converter the motor gets de rated by 1/3. So basically a 3hp motor becomes a 2hp motor. This may be a problem if the machine sees a heavy load. Vfd's are pretty cheap now days and most of the ones I've used, you can input single phase or three phase. Overloads are built into the vfd. Just program and go. I've done this on several occasions. Works very well.
7635tools is offline   Reply With Quote
The Following User Says Thank You to 7635tools For This Useful Post:
pete87 (02-22-2015)
Motor wiring diagram MEISENBURG General Electrical Discussion 14 07-12-2014 01:25 PM
VFD Motor Wiring Dare General Electrical Discussion 7 10-17-2013 04:03 PM
Help With Motor Wiring A Little Short PLCs, VFDs, Motors and Controls 7 05-02-2013 11:21 PM
dayton motor wiring RM Sparks General Electrical Discussion 6 08-07-2009 03:39 PM
help wiring a motor javier6866 PLCs, VFDs, Motors and Controls 2 01-21-2009 04:16 PM
