need some motor wiring help - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-22-2015, 01:26 PM   #41
Rewards Points: 244
Originally Posted by Lep View Post
Can we help you estamate the job too?
Can we help you with spelling?
Originally Posted by dronai View Post
Also if he disconnects the forward and reverse starters to use for his VFD, there may be aux contacts that close when the starters close, that need to work. Some controls are also wired into the control circuit for safety devices like the access doors. That's why I said to look at the schematic first.
Exactly. He cannot just stick the VFD in and expect all the peripheral equipment to work. Push buttons ect.....
Any and all operator control for the motor must be connected to the drive either directly or using some existing circuitry to make it work.
Originally Posted by 7635tools View Post
If you use a static phase converter the motor gets de rated by 1/3. So basically a 3hp motor becomes a 2hp motor. This may be a problem if the machine sees a heavy load. Vfd's are pretty cheap now days and most of the ones I've used, you can input single phase or three phase. Overloads are built into the vfd. Just program and go. I've done this on several occasions. Works very well.
I also lean towards the VFD. But only because I am familiar with them. Easy peasy.
The Following User Says Thank You to John Valdes For This Useful Post:
pete87 (02-22-2015)
Old 02-22-2015, 09:26 PM   #42
Rewards Points: 1,702
I was wondering how reliable electronics are ? How long lasting ? I have never installed a VFD .
Pete
pete87 is offline   Reply With Quote
Old 02-22-2015, 11:30 PM   #43
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 6,600
Originally Posted by pete87
I was wondering how reliable electronics are ? How long lasting ? I have never installed a VFD . Pete
If correctly sized, installed and you keep them, cool, clean, minimal start/stop and properly maintained then 10 to 15 years is what I've seen.
pete87 (02-23-2015)
Old 02-23-2015, 04:28 PM   #44
Thanks Wirenuting , I worry about brownouts and dirty power and surges .
So , you could use a Rotary Phase Converter at 3hp or oversized to 5hp and out last the VFD .
Pete
Motor wiring diagram MEISENBURG General Electrical Discussion 14 07-12-2014 01:25 PM
VFD Motor Wiring Dare General Electrical Discussion 7 10-17-2013 04:03 PM
Help With Motor Wiring A Little Short PLCs, VFDs, Motors and Controls 7 05-02-2013 11:21 PM
dayton motor wiring RM Sparks General Electrical Discussion 6 08-07-2009 03:39 PM
help wiring a motor javier6866 PLCs, VFDs, Motors and Controls 2 01-21-2009 04:16 PM
