Need a vendor - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
Old 05-16-2019, 04:58 PM   #21
Russian Bot
Helmut's Avatar
Rewards Points: 3,873
You guys are missing what I need.
I need t a new back box. The top of this one is swiss cheesed with existing pipes.
Has nothing to do with the cover, the cover I have is a surface mount, They built a wall around the panel. I figured I could get a new box, use existing guts breakers and cover. The new pipe runs I ran, I could land in the new boxes KO's. I have done this in the past with BL panel boxes, so I figured I could do the same with the QO.
The load center didn't appear to be that old.
I'll put in a BL panel I have. Might work out better as the BL's are solid top and it's easier to land pipes.
99cents likes this.
Alright, Alright, Alright... I'll tell you what to do. Go that way, reeeeeeeeeally fast. If something gets in your way......turn.
The Following User Says Thank You to Helmut For This Useful Post:
HackWork (05-16-2019)
Old 05-16-2019, 05:28 PM   #22
Rewards Points: 10,561
Originally Posted by Helmut View Post
Don't you just love when you get an email that says:
Panel box discontinued, no suitable substitute available
Thanks SQD.
Absolutely love it. Now you tell the customer you need to replace it, no choice.
For the record, Siemens makes 3 phase panels that take both bolt-on and push-in breakers (at least up here in the frozen north).
Old 05-16-2019, 05:39 PM   #23
Russian Bot
Helmut's Avatar
I wish, this is on me. I gave them a price to do the fit-out. Figured I could make a bunch more by re-using the load center. This time it bit me. I have 2 complete BL's full of breakers, with new boxes and covers in the shop. It didn't bite me too hard, in fact, this mistake made floor space.
See above.
Old 05-16-2019, 05:53 PM   #24
Rewards Points: 40
Can you get a metal shop to make you a new top you can rivit in place?
Sent from my XT1650 using Tapatalk
Old 05-16-2019, 06:07 PM   #25
Russian Bot
Helmut's Avatar
Doubt that pass inspection.
Tons of options I suppose. I could mount a gutter over the panel using existing pipe layout in the QO panel, and land the new pipe runs in the gutter.
Old 05-16-2019, 06:10 PM   #26
Rewards Points: 40
I've done it on a panel board can. I could see doing it on loadcenter getting raised eyebrows.
Old 05-16-2019, 06:17 PM   #27
Rewards Points: 691
Forge Boy’s idea is great. It is code compliant as long as you use a piece of steel the same thickness or thicker than the existing panel.
Just cut a flat piece of steel to go over the entire top, then drill your KOs in it.
It’s no different than when I use a 1900 blank cover plate to close a KO or as a reducing washer.
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 05-16-2019, 06:34 PM   #28
Russian Bot
Helmut's Avatar
2 things come to mind, 1 is it looks like hell, and 2, how to you insure it' properly bonded? With pop rivets? I am sure you'd had to put grounding bushings on every pipe entering that new top.
Then, can someone make you this is a couple days?
Old 05-16-2019, 07:03 PM   #29
Rewards Points: 691
You don’t need it made special. All you need is a flat piece of steel, 4”x14.5” Or whatever the dimension of the top of the panel is. Cut it out of an old trough or the back of a panel.
As for looks, it would sit flat on the top of the panel, no one would be able to see it or know that it wasn’t part of the panel.
Use a 1/4-20 bolt in each corner and you’re done, no issues with bonding.
I have ran conduit into 1900 blank plates that were held on with 2 8-32 screws and nuts. Perfectly code compliant and passed inspection.
Old 05-16-2019, 08:46 PM   #30
Rewards Points: 40
I guess I'm spoiled. We have a fabrication shop for a customer and i can call in and have metal cut/bent for the next morning if I need it. It helps that I have saved their butts more than once and got their machines up and running so they could keep rolling.
Old 05-16-2019, 08:50 PM   #31
Cow
Rewards Points: 4,428
Put me in the camp with everyone else. I'd install a sheetmetal plate on the top of the panel and use machine screws or similar to hold it down. Done.
Changing a panel because the top is swiss cheesed sounds extreme to me.
We also have a steel shop down the road that will shear or thread or do whatever we need.
This would take a 5 minute phone call and stopping by to pick up the plate, it couldn't be simpler. I bet it'd be well under 20 bucks.
Old 05-16-2019, 08:58 PM   #32
Jlarson's Avatar
Rewards Points: 3,878
If I really had a burning desire to reuse a little loadcenter like that I'd grab a scrap of plate and slap it onto it in a heat beat.
Old 05-16-2019, 09:05 PM   #33
Rewards Points: 691
I wish I had a metal shop for things like this. I could find one, but it would probably be a place that only liked large orders and charged me an arm and a leg to do it.
For me, I'd stop at the supply house, get a 4" x 16" trough cover, cut it with a sawzall at the truck, and put it on. It will even be painted gray.
Old 05-16-2019, 09:28 PM   #34
Rewards Points: 4,060
The backbox is completely symmetrical. Remove everything. Flip backbox upside down. Reinstall everything. KO seal all the bottom KOs and the new top is virgin.
Old 05-17-2019, 06:38 AM   #35
Rewards Points: 3,144
I don't think bonding would be difficult, and I do have tin bangers I can bribe for this kind of thing, but I still would worry about an inspector balking about the repair.
I never did it, but if you are surface mounting it, I wonder if it would work out if you just attached a trough on top with a few large chase nipples.
Electrical Vendor needing an answers to basic electrical fittings questions AntDWood New Member Introductions 4 01-25-2019 11:49 AM
National Vendor Service Providers KL-Networks Structured Wiring 21 12-14-2018 03:24 PM
Div 26 Specs - Commercial Jobs FootballFan General Electrical Discussion 5 03-23-2018 07:20 PM
