Neglect - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 07-08-2012, 10:01 PM   #21
sbrn33's Avatar
Rewards Points: 3,614
Originally Posted by Theriot View Post
I know I'm ashamed of my own shed panel. That's one of those ill fix it later things eight years ago.
What do you mean? Peter d would think that was a perfect install.
Old 07-09-2012, 04:20 AM   #22
BBQ
Salty Member
BBQ's Avatar
Originally Posted by Celtic View Post
my entire service is an abomination
Same here.
Old 07-09-2012, 04:23 AM   #23
BBQ
Salty Member
BBQ's Avatar
Originally Posted by micromind View Post
Here's one you won't find any too often in a house;
The service is 120/208 3 4 wire wye. There is a 3 panel in the garage, and adjacent to it is a 12X12X4 N1 screw cover can recessed in the wall. In this can there are three 10 amp relay bases, each with a 3 pole 10 amp HP rated relay. All 3 bases are fed with a 3 pole 10 amp breaker, and #14 THHN; daisy chained together.
The load side of each relay base feeds a 3 pole fuseblock. Each fuseblock feeds a 3 motor, one for the swamp cooler in the garage (1/2HP), one for the exhaust fan in the garage (1/2HP), one for the attic fan in the house (1/4HP).
The fuses are time-delay and sized to protect the motors from overload, single-phasing, etc.
Sort of a poor mans MCC.
Only one problem; no individual disconnecting means for each motor controller.
Other than that, it's very likely compliant.
I have about $600 worth of controls running a $35 attic exhaust fan.
The Following 2 Users Say Thank You to BBQ For This Useful Post:
Hamer (07-09-2012), micromind (07-09-2012)
Old 07-09-2012, 12:55 PM   #24
Rewards Points: 1,022
I have two bedrooms left with 3 wire receptacles and two wire NM.
Old 07-09-2012, 01:04 PM   #25
Hamer's Avatar
Sounds like a "micrologix1200 for the Christmas lights" kind of story. Nah, I never overengineered anything at my house.
Coffee
Hamer is offline   Reply With Quote
Old 07-09-2012, 10:33 PM   #26
erics37's Avatar
Rewards Points: 642
My meter base isn't physically attached to the side of the house.
Plus it's an old piece of crap.
Old 07-09-2012, 11:03 PM   #27
Vintage Sounds's Avatar
Rewards Points: 4,004
I buried some NMWU in my yard, to feed a pond pump receptacle and future landscape lighting. Code says it should be 24" underground. I said F that, and went with 6-8". Whatever. It's on a GFCI breaker and sleeved in PVC where it comes out of the ground.
Old 07-09-2012, 11:49 PM   #28
Rewards Points: 2,002
I've done that a few times, but without the GFCI breaker.
Old 07-10-2012, 01:40 AM   #29
carryyourbooks's Avatar
Rewards Points: 1,292
i just recently replaced a sd that hadn't worked since i bought the house (10 yrs.). i stll need to put gfci's in the kitchen. oh yeah, my disposal switch is upside down.
i think i'll leave it like it is though......it will keep the home inspectors feeling good about himself when i get ready to sell.
carryyourbooks is offline   Reply With Quote
Old 07-10-2012, 02:24 AM   #30
Sideways Sparky
farlsincharge's Avatar
Rewards Points: 1,170
no gfi's outside, no tr, no afci.
15 amp rec's on 20 amp feed in garage, it is #12 though.
Man, I feel a little like the teachers pet. Maybe I'll go down and pull the covers off a couple jb's.
farlsincharge is offline   Reply With Quote
Old 07-10-2012, 02:51 AM   #31
Master Of Disaster
socalelect's Avatar
Rewards Points: 1,006
The hub on my well service panel has been broke for a couple years. I keep saying ill fix it. I did squirt some squeeze cheese in it does that count?
Old 07-10-2012, 12:08 PM   #32
Rewards Points: 546
What's the biggest code vialation in or around your house?
This cover hasn't been put on in nine years
Garage door openers aren't GFI
Don't even know where my cover is for my shed panel.
That could be my house!
I had to run some new conductors into the ceiling from my load center, but since it's in the garage, the Sheetrock is 5/8" and nobody has short pieces of 5/8 hanging around but I don't want to buy a whole sheet and toss most of it. So I'm waiting fir one of my neighbors to do a garage project so I can steal a chunk of Sheetrock from them and I have yet to put the cover back on. It's been probably about 5 years now...
Also no GFI on the garage door opener, also have an unfinished outlet box hanging out of the wall by the romex.
Old 07-10-2012, 01:59 PM   #33
WWMDSD
Oakey's Avatar
Rewards Points: 30
THHN hanging out of the LB in the garage spliced on the fly to a POS sub panel with no cover. My old time 100 amp main service has bare conductors on the drop and the panel cover I cant fit on anymore.
Oakey is offline   Reply With Quote
Old 07-10-2012, 11:27 PM   #34
Oh yeah, add that to my list too. But it's most of my apt.
