Neon Tester Findings - Electrician Talk - Professional Electrical Contractors Forum
Old 05-24-2011, 09:47 PM   #1
Cletis's Avatar
Rewards Points: 2,050
Default Neon Tester Findings
Been using neon tester for many years for following. To find hot in box, grounded conductors, 240, 120, etc...Just by the intensity of light I could figure out what was what without a meter.
To find the hot in the box i've always touched the neon to conductors and other end to fingertip with thick rubber boots on. Faint glow meant the hot.
Question: How do get the faint glow with basically no return path and very high resistance? Same with neutral, except faint would mean bad neutral, but why faint and not just no glow?? For some reason I thought you had to have a full return path to get a glow.
I know it's all ohm's law so some other analogy would help.
Old 05-24-2011, 10:02 PM   #2
Rewards Points: 2,000
The first job I was on the JW called it an "idiot" light. Never used it again.
Mr Rewire is offline   Reply With Quote
Old 05-24-2011, 10:08 PM   #3
Rewards Points: 2,002
Once again, Cletis comes up with a great story.
Old 05-24-2011, 10:14 PM   #4
Cletis's Avatar
Default Story
How is explaining neon tracers and ohm's law a story??
Old 05-24-2011, 10:41 PM   #5
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
I've never used a neon tester like that, but I think it's just a case of your insulated boots not being quite as insulated as you prefer and your body is conducting a tiny bit of current.
Have you ever noticed if the light glows a different brightness when you try this trick standing in a concrete basement versus a plywood attic?
I think you're opening yourself up to the possibility of a nasty shock, but other than that, try standing on a couple ceramic tiles the next time you do it, and see if it still works.
-John
Always wear your gloves.
Old 05-24-2011, 10:46 PM   #6
Cletis's Avatar
Default lit up
Yeah. I did that accidently once. I'm guessing it glowed very bright cause I jumped backwards a few feet. I would have thought that with thick dry socks and very thick rubber redwing electrician shoes my resistance would be infinity to the ground ?
Old 05-24-2011, 10:50 PM   #7
Rewards Points: 2,328
I use a Ideal Test-Glo at work because I work with 125 VDC controls.
The neon voltage test lights draw a extremely small amount of current Maybe down in the micro or picro amp range.
with that being said they can tolerate extremely high resistance in the circuit.
When I started in this game I carried a small neon test screwdriver it had a metal clip and a large resister in the handle between the neon lamp and the clip.I would touch the screwdriver tip to a conductor and the circuit would be completed through my body. That was many years before we had non contact capacitance coupled voltage testers.
Old 05-24-2011, 10:52 PM   #8
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
...I would have thought that with thick dry socks and very thick rubber redwing electrician shoes my resistance would be infinity to the ground ?
Unless the boots where brand-spanking-new bone-dry EH rated, I wouldn't count on that stuff to be a great insulator.
A little bit of sweat, a little bit of dirt, a little bit of water is all it takes to ruin an insulation rating. I've gotten a little buzz from 120V in my boots that are supposed to be rated to withstand something like 10,000V.
-John
Old 05-25-2011, 12:06 AM   #9
Rewards Points: 1,568
The path of current IS indead thru your body to ground,
But neons need very little current to operate,
Typically around 500ua,
So you dont feel it.
No need for ohms law to explain this one.
I dont have to tell you that letting ANY current
flow thru your body is RISKY.
Old 05-25-2011, 01:02 AM   #10
Rewards Points: 6
Even if you're completely insulated from any return path, the capacitance of your body will be enough to cause the light to glow some.
Old 05-25-2011, 03:50 AM   #11
Rewards Points: 1,464
Capacitance.
TSA Findings BBQ Off Topic (Non Trade) 6 01-10-2011 07:06 PM
neon signs Murphy General Electrical Discussion 38 11-04-2010 05:48 PM
Multi meter tester & Pat tester for sale dekpet Tools, Equipment and New Products 0 11-24-2009 06:02 AM
For Sale: Exfo Multifunction Loss Tester FOT-930 Max Tester II kliffwalker Electrician Swap 2 05-31-2009 12:59 PM
Plexi-neon maxfieldd Lighting Design 1 12-11-2008 09:23 AM
