New Simplisafe Camera / Doorbell won't work. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By macmikeman
  • 1 Post By 3DDesign
Old 12-30-2018, 11:19 AM   #1
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 704
Default New Simplisafe Camera / Doorbell won't work.
I have been to the Simplisafe forum which is of no use. I have talked to Simplisafe tech support which was the most ridiculous conversation ever.
I'm trying to wrap my head around what is wrong.
I of course have measured 27 VAC at button from my bell transformer that goes into the mechanical Westminster chimes, NOT DIGITAL. (tech support kept telling me I had digital chimes.)
I remove my old doorbell button without LED, and wired the new camera button. As soon as I slip it on the wired base it starts ringing the bell constantly.
I read about other peoples' "fixes" using 10 Ohm resistors, Diodes, etc. I tried some of these in desperation and nothing works.
So I'm thinking to myself, Self, why not a relay? Only one major issue, I can't run a separate power. It has to be a single AC power source. Rectified to run the coil then AC power across N/O and COM.
Trying to find a bridge rectifier and relay in my scrap pile now. Maybe?
Cowboy words of wisdom.
Never approach a bull from the front, a horse from the rear, or a fool from any direction.
Old 12-30-2018, 12:30 PM   #2
360max's Avatar
Rewards Points: 1,234
Where did you put the resistor or diode, I read on a forum to put 10 ohm resister AT the chime location and it stopped the guys constant ringing.
Old 12-30-2018, 12:41 PM   #3
MTW
Rewards Points: 11,414
SimpliSafe = consumer grade junk. Thankfully ADI carries all major security brands now at wholesale prices, so no need to buy that trash.
Old 12-30-2018, 01:03 PM   #4
LARMGUY's Avatar
Rewards Points: 704
I tried a 10, 100 and 1K . The 10 and 100 acted like a direct short.
the 1K didn't short it and it didn't fix the issue. I read the same forum. He said he put the resistor across the terminals in parallel with the button wires coming in. It tried them at the button too. I tried a diode the same.
Old 12-30-2018, 01:05 PM   #5
Rewards Points: 20,743
Try a 16 volt transformer in place of the 24. You are maybe overdriving the circuit board
sbrn33 likes this.
Old 12-30-2018, 01:09 PM   #6
LARMGUY's Avatar
Rewards Points: 704
Wife ain't happy ain't nobody happy. That was the main reasoning behind the purchase of the system. I already had a Vista 50 with wireless transmitters installed. No... she wants a video doorbell with the system not as a separate item.
Don't judge me
Old 12-30-2018, 01:27 PM   #7
LARMGUY's Avatar
Rewards Points: 704
I had the original 16 VAC replaced with a 24VAC because I was told there wasn't enough power (voltage according to tech support) for the video, PIR, the chimes and the LED. It measured 19 VAC at the button and chimes.
Old 12-30-2018, 02:34 PM   #8
Rewards Points: 3,078
Originally Posted by LARMGUY View Post
I had the original 16 VAC replaced with a 24VAC because I was told there wasn't enough power for the video, PIR, the chimes and the LED. It measured 19 VAC at the button and chimes.
Having enough power doesn't mean increasing the voltage, it means increasing the VA of the transformer.
Purchase a 16V, 30 VA transformer.
If this is an old school, Nutone Westminster Chime, It had a diode installed.
The instructions showed it installed across the button. I never did that, I found it easier to install the diode at the chime.
brian john likes this.
Greg
Old 12-30-2018, 04:16 PM   #9
LARMGUY's Avatar
Rewards Points: 704
Poor choice of words. Tech support said 24 volts.
They also talked about a "chime connector" in the forums but this is where it gets confusing. The forums say it's for vintage solenoid types. Tech support said for digital.
Old 12-30-2018, 04:59 PM   #10
24 Volts, what is the VA
A normal doorbell transformer is 16V, 10 VA.
Replacing it with a 16V, 30 VA is usually required to run the chime and camera.
Greg
The Following User Says Thank You to 3DDesign For This Useful Post:
Bird dog (12-30-2018)
Old 12-30-2018, 05:01 PM   #11
Without the Diode, a Westminster Chime would play one or two notes, not five or seven. A missing Diode would not cause it to play constantly. That is, of course, in the original setup.
Greg
Old 12-30-2018, 05:16 PM   #12
LARMGUY's Avatar
Rewards Points: 704
It's a 20 VA. I'll get a 30 tomorrow.
Old 12-31-2018, 12:05 AM   #13
Rewards Points: 1,469
Make a small diode rectifier to drive the coil if you want to do the relay
Old 12-31-2018, 02:06 AM   #14
Rewards Points: 26,836
This is not a DIY site.
Electrical work at Tesla facility WPNortheast General Electrical Discussion 43 10-20-2018 01:11 PM
Research [email protected] General Electrical Discussion 126 09-30-2018 03:48 PM
I need a scope with a smaller camera head NDC Tools, Equipment and New Products 18 10-11-2016 11:05 PM
Getting my first car, advice to keep it clean when used for work commute ? David C Tools, Equipment and New Products 27 01-24-2016 10:39 PM
