no conduit or j-box - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 1 Post By Bird dog
  • 1 Post By joebanana
  • 1 Post By wildleg
  • 1 Post By Navyguy
  • 2 Post By splatz
  • 1 Post By tmessner
Old 10-29-2018, 10:45 PM   #1
Rewards Points: 998
Default no conduit or j-box
How do you run conduit and wire to a device that has 3 wires hanging out of a small hole with no provision for adding a box or conduit? This is a bin level switch mounted on the side of a grain bin. It has a micro switch buried in with 3 wires hanging out in the air,
Here is link to what we found today on a bin.
Old 10-29-2018, 10:57 PM   #2
Bird dog's Avatar
Rewards Points: 806
Contact the company. Looks like there was no consultation with an electrical engineer.
http://levalert.com/
You might put heat shrink tube on the wires & run it into the bottom of a box.
Old 10-29-2018, 11:02 PM   #3
Rewards Points: 8,259
If all else fails, read the instructions.
wildleg likes this.
Old 10-30-2018, 12:02 AM   #4
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
what are you hooking it up to ? class 2 or contacts from a power limited system and you are good to go with pretty much anything I would think. I like the mechanical indicator. wonder how long this crap lasts before it is useless junk.
Old 10-30-2018, 06:55 AM   #5
Rewards Points: 3,084
I agree, no engineer involved in the design of this product. They say their switch is UL listed but I am sure it's just UL listed as an OEM part, I doubt the Levalert is listed.
The switch doesn't look like it's outdoor rated, I'd apply some silicone and hope for the best.
So like @wildleg says, even though the switch component might be rated for 120V, I wouldn't go there, I'd get a Class 2 power supply and a relay suitable for whatever you want to switch. The Class 2 rules are fast and loose but you'll still want it to work...
I'd use a piece of the marine heat shrink around the wires, mount a box next to the device, arrange the wire in a drip loop, and come into the bottom of the box with a cord grip.
It's just one step past homemade but a lot of these things are surprisingly trouble free.
#HACKLIVESMATTER
Old 10-30-2018, 07:37 AM   #6
Rewards Points: 998
What instructions?
Old 10-30-2018, 07:39 AM   #7
Rewards Points: 998
the farmers like the mechanical part. They seem to last many years. The electrical part is just a standard micro switch. As long as it is used in its rating it will last forever.
Old 10-30-2018, 07:40 AM   #8
Rewards Points: 998
We tie into a 120 volt control circuit , usually with a 5 amp control circuit breaker.
Old 10-30-2018, 07:50 AM   #9
Originally Posted by tmessner View Post
What instructions?
Their promo vid. mentioned their web site for more videos on installation procedures. Or you could write them.
Old 10-30-2018, 08:27 AM   #10
Navyguy's Avatar
Rewards Points: 5,940
I think I would be using 12 or 24 volts, not 120 volts. If you wanted to enclose the entire thing in a window box or something, then I might consider 120 volts.
https://hoffman.nvent.com/en/hoffman/CHJ1412HWPL2LG
Cheers
John
Old 10-30-2018, 09:04 AM   #11
Rewards Points: 998
Thanks for the ideas. This is a small example of what we run into in rural areas. Somebody has a great idea. and farmers love it and nobody checks with the guy that gets to hook it up. Just for giggles, we found out it was installed about 6" to low in the bin also.
Old 10-30-2018, 09:11 AM   #12
Cow
Rewards Points: 5,262
I'm glad I haven't seen one of those yet.
We're getting ready to do a new corn dryer facility with several bins. I hope they're providing regular bindicators for bin level and not these turds.
Old 10-30-2018, 12:20 PM   #13
Cheers
John
Putting the whole thing in an enclosure with a clear cover would make a nice install but I think that might make it hard to read from the ground.
Navyguy and tmessner like this.
#HACKLIVESMATTER
Old 10-30-2018, 03:07 PM   #14
Rewards Points: 998
These things might 50' or from the ground so an enclosure will render them unable to be seen from ground level, especially as dirt and dust builds up on the window.
Old 10-30-2018, 03:37 PM   #15
Rewards Points: 22,819
When I get a couple of wires poked out thru a bushed hole in something (usually an ac compressor of some sort or a VAV box, I knock out the center ko in a 4 square box and mount that directly over the wiring poking out without bothering to add any further bushing or box connectors or the like. By the time the inspector shows up the blank cover is on the box anyway.
Start buying American
Suspending security camera from conduit ElectMe NEC Code Forum 8 02-19-2017 04:20 PM
PV conduit inside exterior wall permitted? katwalatapan Alternative Energy Forum 11 12-05-2016 12:09 PM
Conduit fill for water feature fountain Sprink General Electrical Discussion 3 04-27-2016 07:03 PM
Getting the most from an existing U/G conduit Gaussios Residential Electrical Forum 16 04-25-2016 10:11 PM
locating conduit or LV cable behind wall or missing conduit end? lortech Structured Wiring 3 01-18-2016 12:35 PM
