No power needed?? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
  • 1 Post By joebanana
  • 1 Post By MechanicalDVR
  • 1 Post By samgregger
  • 4 Post By micromind
  • 1 Post By frenchelectrican
  • 1 Post By micromind
Old 02-18-2018, 01:13 PM   #1
Rewards Points: 18
Default No power needed??
So Iíve not run across this yet. Friend says these lamps have a soft glow when (standard toggle) switch is turned off...can only see at night. Original 1970ís wiring. Any thoughts?
jerjwillelec is offline   Reply With Quote
Old 02-18-2018, 01:17 PM   #2
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,198
There are some previous threads about this here on ET
with regard to LED's doing this. I have not seen this
yet on any of my jobs or personal use of LED's.
I believe the consensus is lack of quality in a
particular brand allowing some stray voltage
passing thru the neutral may be the culprit
Old 02-18-2018, 01:47 PM   #3
Rewards Points: 7,493
Check for leakage current through the switch. Cheap switches, and heavy loads can cause contact vaporization inside the switch, which can cause leakage.
Old 02-18-2018, 02:17 PM   #4
Rewards Points: 13,555
I had this happen. Problem went away. No explanation.
Old 02-18-2018, 02:31 PM   #5
Rewards Points: 2,868
I agree with Joe, install a better switch.
Could also be a pilot light on a device in that circuit.
active1 likes this.
Old 02-18-2018, 03:09 PM   #6
Rewards Points: 1,335
Current leakage through switch or enough power inducted from a parallel wire on another circuit
samgregger is online now   Reply With Quote
Old 02-18-2018, 03:16 PM   #7
electrorick
RICK BOYD's Avatar
Rewards Points: 225
if the neutral is sw then you get capacitive inductance
some times led blinks with sw off
I know you understand
what you thought I said
but what you heard
is not what I meant
RICK BOYD is offline   Reply With Quote
Old 02-18-2018, 05:55 PM   #8
Rewards Points: 3,052
One of my friends had LEDs that would glow dimly with the switch off. After extensive testing, all circuits were ok so I suspected capacitive coupling.
It was a single pole switch and passed a 1000 VDC merger test, as did the switched leg up to the lights.
My solution was to install a 3 way switch. I connected the hot to one of the travelers, grounded the other and connected the light to the common.
It worked. No glow at all with the switch off.
Yes it seems wrong to ground a switch terminal but there's no possible way the 2 travelers can be connected to each other.
Wonder if this would be a code violation.......
Old 02-18-2018, 07:00 PM   #9
Modťrateur
Rewards Points: 21,880
That is one good way to slove the induction voltage on dammed leds .,
However if someone try to replace the three way switch and not pay attetion to the connection can really ruin the day.
but it possible a code violation but the set up you did I dont think it a issue until some baka handyperson see it and they will get brain freeze on that.
micromind likes this.
Old 02-18-2018, 08:17 PM   #10
DashDingo's Avatar
Rewards Points: 22
Happens at my own house. I have LED disk lights in the hallway, when the switch is off for the hallway lights and the bedroom lights get turned on the LED disks in the hallway will burn a little dim.
DashDingo is offline   Reply With Quote
Old 02-18-2018, 10:24 PM   #11
Capacitive coupling with nearby hots. The more current, the more capacitance.
active1 likes this.
Old 02-20-2018, 11:38 AM   #12
Rewards Points: 88
Maybe the nuetral is being switched instead of the hot.
numbers is offline   Reply With Quote
Old 02-20-2018, 11:50 AM   #13
Doubt that would make a dim glow.
Problems with Power Company Lythropus Services and Service Equipment 6 08-26-2017 04:36 AM
Clean / Dirty Power with Furnace byezb General Electrical Discussion 38 03-26-2017 10:24 PM
Power Surge on One Leg with high amp appliances crum2243 General Electrical Discussion 1 09-20-2016 03:24 AM
