Noob pipe bending question - Electrician Talk - Professional Electrical Contractors Forum
Old 09-14-2012, 05:48 PM   #1
Default Noob pipe bending question
I was attempting to bend back-to-back 90s with both stubs pointing in the same direction. It was 3/4 pipe. The stubs were both to be 2', and the distance from the back of one 90 to the back of the other was to be 39 7/8".
I marked the first end of the pipe at 18 inches and bent the first 90. I then measured 39 7/8" down the pipe from the back of the first 90 and marked it. I bent my second 90 with the hook of the bender pointing towards the other end of the pipe. My pipe came up short by about 1 3/4". If I had made the mark at 45 7/8" instead and bent it there, would my pipe have come out correctly?
The reason I did not point the hook towards the first bend when I was making the second bend is that I did not want to have to bend that whole length of pipe up in the air.
black is offline   Reply With Quote
Old 09-14-2012, 05:51 PM   #2
360max's Avatar
Rewards Points: 1,234
http://www.porcupinepress.com/_bending/BackToBack.htm
on the above site, there is a gray rectangle on the left with two arrows, put your arrow over that and different bends will pop up, 3 and 4 point saddles, offsets, etc .
Old 09-14-2012, 05:55 PM   #3
Mouser's Avatar
Rewards Points: 104
your second bend should have been on the teardrop or star point on your bender and then bend back to your first bend.
Mouser is offline   Reply With Quote
The Following User Says Thank You to Mouser For This Useful Post:
JohnR (09-14-2012)
Old 09-14-2012, 05:58 PM   #4
aDudeInPhx's Avatar
Rewards Points: 268
Did you use the star & not the arrow for your second bend?
aDudeInPhx is offline   Reply With Quote
Old 09-14-2012, 05:59 PM   #5
JohnR's Avatar
+1 on post #3 , you were almost there, you had the bender the correct way. OR, you should have put the arrow at 45 7/8 yes.
Signed out.
Old 09-14-2012, 06:02 PM   #6
Thanks all
Old 09-14-2012, 06:02 PM   #7
220/221's Avatar
Rewards Points: 4,328
Your second bend was also a stub.
Bend the first one then measure your 39 7/8" from the back of the conduit and use the arrow just like you did on the first one.
I'm sure there is a way to make both marks then bend but I never took the time to learn it.
Old 09-14-2012, 06:10 PM   #8
Mouser's Avatar
Rewards Points: 104
Basic math... 24" + 24" + 39 7/8" - 6 1/2" (gain for 2-90s). cut pipe to lenght, then do your 2 stubs = done
Multiple Pipe Bending tc7447 General Electrical Discussion 19 06-12-2012 03:49 PM
Future of Pipe Bending Cletis General Electrical Discussion 57 10-17-2011 08:15 AM
Pipe bending TEX General Electrical Discussion 15 07-25-2011 06:35 PM
Bending pipe that's 1 1/2" EMT. kaboler Commercial Electrical Forum 59 02-13-2011 12:57 PM
New Pipe bending video failelectric General Electrical Discussion 30 06-25-2010 09:12 AM
