Nube Question - Can I Direct Wire LED Type A Bulbs? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree21Likes
Closed Thread
Old 11-17-2019, 12:10 PM   #1
Default Nube Question - Can I Direct Wire LED Type A Bulbs?
Hey All! Just purchased a box of 16 Utilitech 32w direct replacement LED T8 tubes, model #T81636F16-40 only to discover they aren't compatible with my old ballasts.
So my question for the pros is, can I direct wire these tubes and bypass the ballast? I'm also not certain if these are dual or single ended, so any comments or suggestions would be very much appreciated! Thanks in advance for your time!
Mo from SD
Motinez_Mardesto is offline
Old 11-17-2019, 12:12 PM   #2
Rewards Points: 1,829
What did your electrician say to do?
HackWork is online now
Old 11-17-2019, 12:16 PM   #3
He wasn't familiar with it, so I thought I'd ask some of you! Any ideas?
Old 11-17-2019, 12:18 PM   #4
What do the instructions say?
Old 11-17-2019, 12:26 PM   #5
The instructions didn't mention direct wiring, however was curious if there was another safe option. Just looking for some insight on it, thank you.
Old 11-17-2019, 12:31 PM   #6
Rewards Points: 1,206
I think you should return the lamps you bought and hire an electrician because you obviously have no clue what you are doing.
The way to make the lamps work is easy but its far cheaper and less time consuming to buy new LED fixtures in your case
bostonPedro is offline
Old 11-17-2019, 12:34 PM   #7
Yup. This is very true. It took me under a minute to lookup those lamps and see that they will not work with a direct 120V feed. They need a functioning electronic ballast to work. The fact that he can't figure that out shows that he should not be doing this. There are too many other little things that can pop up and he can accidentally do wrong without knowing it that could lead to someone getting hurt.
bostonPedro likes this.
Old 11-17-2019, 12:44 PM   #8
bostonPedro, thanks for your professional opinion. I'm no electrician and yep, humbly admit that I don't have a clue of what to do. I am, however, capable of following some simple instructions and directions just like we all did when we asked for help at one time. Anyone else?
Old 11-17-2019, 12:45 PM   #9
Appreciate the concern guys, thank you!
Old 11-17-2019, 12:46 PM   #10
CoolWill's Avatar
Rewards Points: 3,914
Just do it and see what happens.
Kevin_Essiambre likes this.
CoolWill is offline
Old 11-17-2019, 12:51 PM   #11
You can't even follow the directions on this forum which specifically told you it was only for professional electrician and not for homeowners and DIYers.
The_Modifier (11-18-2019)
Old 11-17-2019, 12:52 PM   #12
Whoops! Thanks for the heads up!
Old 11-17-2019, 12:55 PM   #13
My apologies for the inconvenience, thank you for clarification Gents. Back to Home Depot!
Old 11-17-2019, 01:02 PM   #14
Rewards Points: 1,761
Pro Tip: The ones at Wally World are dirt cheap and work with T8 & T12 ballasts.
JoeSparky is offline
Old 11-17-2019, 01:06 PM   #15
Band Member
emtnut's Avatar
Rewards Points: 1,840
The guy in the orange apron will be able to accurately answer all your electrical related questions, and provide professional electrical advice
Awg-Dawg likes this.
emtnut is offline
Old 11-17-2019, 01:08 PM   #16
You don't follow instructions or directions otherwise you would not have bought the wrong lamps in the first place. Instead of just being humble and smart and returning them and then buying the proper lamps you choose to ignore your mistake. So because you bought the wrong lamps you now are looking to retrofit your old fixtures because that is what you have to do as you can not just direct feed them. That is just plain stupid and costly because LED fixtures are affordable and readily available.
Its like buying a can of stain by accident when you want to paint your woodwork so you then strip off all the old paint just because you are too stubborn to admit you should have bought paint ......ok extreme example but fitting
Old 11-17-2019, 01:40 PM   #17
Old 11-17-2019, 02:13 PM   #18
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
The title of this thread had me imagining somebody soldering wires onto Edison base bulbs.
B-Nabs is online now
Old 11-17-2019, 02:21 PM   #19
Band Member
emtnut's Avatar
Lol .... I didn't even notice that part !!
emtnut is offline
Old 11-17-2019, 03:27 PM   #20
Rewards Points: 52
Are you sure Home Depot wants them?
Sent from my SM-G970U1 using Tapatalk
Forge Boyz is offline
Closed Thread
