Old Fused Main Panel - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 01-23-2018, 05:23 PM   #1
Rewards Points: 1,360
Default Old Fused Main Panel
I found this old Westinghouse 150 A fused main breaker panel in my mechanic's shop. Late 60s building. I installed a 20 A circuit for one of his machines and convinced him to change the breakers out too, at least. Interestingly, the building is old enough to have 2-wire T-slot receptacles, but the cable contained a ground, but just #16 copper.
Also inspected the grounding electrode conductor. Some hack back in the 60s obviously didn't have a Kenny clamp and just drilled a hole for the GEC. Despite it not being listed for the purpose, the hole and conductor are in great shape, even in a dirt old mechanic's shop.
Old Fused Main Panel-20180123_152422.jpg   Old Fused Main Panel-20180121_150350.jpg   Old Fused Main Panel-20180121_150329.jpg
Old 01-23-2018, 05:24 PM   #2
MTW
Rewards Points: 12,241
Did you have 480sparky photoshop that for you?
RePhase277 likes this.
Old 01-23-2018, 05:44 PM   #3
Rewards Points: 3,522
BUT how many house fires have they had?
Old 01-23-2018, 05:51 PM   #4
MTW
Soooo....did you correct this egregious violation and install a proper bonding clamp?
Old 01-23-2018, 06:06 PM   #5
Liberal Lesbian
Rewards Points: 100
That's enough joking around.
You people disgust me.
Would you laugh at a nuclear bomb? Huh?
Didn't think so...
The nightmare only erupts when a voltage spike hits. When that happens, we'll all be dead. Yeah, that's funny, right?
Darn you.
nolabama likes this.
Old 01-23-2018, 06:39 PM   #6
sbrn33's Avatar
Rewards Points: 3,616
The really sad part is that SE cable in a commercial environment. That is the dangerous thing. Makes me worry about your friend, and pisses me off at you for not thinking about the big things.
Old 01-23-2018, 06:48 PM   #7
MTW
Cool story Sabrina.
Old 01-23-2018, 07:36 PM   #8
Rewards Points: 24,152
Didn't think so...
Darn you.
Well, when you put it that way!
circuitman1 likes this.
Old 01-23-2018, 07:39 PM   #9
Liberal Lesbian
Rewards Points: 100
Listen here buster, this is serious business.
Old 01-23-2018, 08:05 PM   #10
Rewards Points: 1,230
Beautiful Romex installation.
bostonPedro is offline   Reply With Quote
Old 01-23-2018, 08:05 PM   #11
If you say so.....
Old 01-23-2018, 08:48 PM   #12
Rewards Points: 8,079
Where'd you find breakers for #16AWG?
Old 01-23-2018, 08:52 PM   #13
Liberal Lesbian
Rewards Points: 100
You don't terminate grounds to breakers.
Can I have your points?
Old 01-23-2018, 09:17 PM   #14
Yeah, not much supervision here back in the 60s, but it is a cinder block building with wood framing, so SE and romex isn't too far out of place. All the romex run to a trough in the garage bays and transition to TW in EMT. I ran my new circuit in romex as well, gasp!
Old 01-23-2018, 09:19 PM   #15
Who?
Old 01-23-2018, 09:23 PM   #16
Light Bender
eddy current's Avatar
Rewards Points: 8,122
That is not a listed hole!!!!! Looks like someone just drilled their own!!!!
Quick, PM me the address so I can run over there and install some type of non ferrous connector before the conductor rots away from abrasion or dissimilar metals touching.........oh the horror
Is there a lightning storm in the forecast?
Old 01-23-2018, 09:28 PM   #17
It's only been 50 years. Give it some time.
eddy current likes this.
Old 01-23-2018, 09:28 PM   #18
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 842
It must be Canadian too because it's sideways.
Cowboy words of wisdom.
Never approach a bull from the front, a horse from the rear, or a fool from any direction.
Old 01-23-2018, 09:29 PM   #19
I thought that was Asian... nevermind.
LARMGUY likes this.
Old 01-23-2018, 09:39 PM   #20
MTW
Unbonded GEC, romex, SE cable...what other horrors lurk within this dangerous building?
125 amp breaker feeding and sub panel with a 200 amp main dham206 General Electrical Discussion 6 01-12-2018 12:02 AM
Sub Panel or main panel Agewon Residential Electrical Forum 12 09-06-2017 09:53 PM
Make the old main panel into a sub panel 746 Watts Canadian Electrical Forum 8 09-06-2017 09:32 PM
Feeding a main panel triden Canadian Electrical Forum 13 06-30-2017 08:44 PM
Main panel, subpanel, detatched structure, objectionable current and 3-phase cdw904 Residential Electrical Forum 4 05-10-2017 02:47 PM
