Old Motor Starter Wiring Help - Electrician Talk - Professional Electrical Contractors Forum
Like Tree30Likes
  • 4 Post By varmit
  • 3 Post By canbug
  • 7 Post By CoolWill
  • 6 Post By John Valdes
  • 1 Post By tmessner
  • 3 Post By JRaef
  • 2 Post By MechanicalDVR
  • 2 Post By splatz
Old 02-13-2019, 11:15 PM   #1
Maintenance2's Avatar
Rewards Points: 6
Default Old Motor Starter Wiring Help
Anyone familiar with this old style Westinghouse Linestarter 11210-SX? Wiring diagram would really help or any info on the wiring connections on this particular starterOld Motor Starter Wiring Help-20190212_123526_1550117652327.jpg
Maintenance2 is offline   Reply With Quote
Old 02-14-2019, 08:25 AM   #2
Rewards Points: 1,878
It appears to be a reversing starter (run forward or run reverse). The coil circuit for forward will series through a NC contact on the reverse contactor. The coil circuit for reverse will series through a NC contact on the forward contactor. The power wiring jumpers, on the line side, will swap two phases going from the forward to the reverse contactor to allow the motor to run opposite directions. The overload relay(s) will be as any other starter and if tripped will drop out the contactors and prevent motor operation until reset. This is the basics.
Old 02-14-2019, 09:34 AM   #3
Rewards Points: 914
It probably has a mechanical interlock in the back under the mtg plate. They can get gummed up and not allow things to move freely.
Old 02-14-2019, 09:52 AM   #4
canbug's Avatar
Rewards Points: 2,032
If you are really going to fix that thing, you need to make your own wiring diagram, take a lot of pictures, tear it apart so you can clean it and bench test it.
Once that's all done, put it back in service and be the hero.
Tim.
Old 02-14-2019, 10:06 AM   #5
CoolWill's Avatar
Rewards Points: 644
Looks to me like a new starter would be in order. Go ahead and put in for a new disconnect too.
Old 02-14-2019, 12:04 PM   #6
Rewards Points: 920
The only thing worse than keeping that POS for one more day is to keep it for two more days.
Rip it out and replace it. Today.
The Following 2 Users Say Thank You to John Valdes For This Useful Post:
MechanicalDVR (02-15-2019), TGGT (02-15-2019)
Old 02-14-2019, 12:16 PM   #7
Rewards Points: 5,614
I would guess it is unlikely you would get replacement coils, contact or heaters for that thing if there was a problem with any of that stuff.
Cheers
John
Old 02-14-2019, 12:19 PM   #8
Rewards Points: 914
Cheers
John
If you can't find it on Fleabay you do not need it.
Navyguy likes this.
Old 02-14-2019, 02:45 PM   #9
Rewards Points: 516
The actual wiring diagram for that particular starter is somewhat irrelevant. Westinghouse has been gone 25 years now (since 1994), that version of their starters goes back to the 50s or earlier so nothing is going to be available to fix it that itself is not 60+ years old. What you will want to do, as the others have suggested, is just replace it with something new from a trusted supplier and use the diagram of that new starter. The control devices are the only thing in question, so take a look at what they are using (i.e. push buttons, selector switch or relays) and adapt it as necessary using the diagrams from whatever new reversing starter you find.
Old 02-14-2019, 07:53 PM   #10
Yep, that is the black arms at 45 degrees between the coils.
Old 02-15-2019, 09:09 AM   #11
Rewards Points: 2,108
Just get a premounted panel with all the item in one panel (starter, overload, disconnect,...) Any panel builders or motor shop could do it.
Old 02-15-2019, 09:17 AM   #12
sbrn33's Avatar
Rewards Points: 3,576
It looks to me like that baby needs replaced and also needs to be in a stainless enclosure.
Old 02-15-2019, 09:19 AM   #13
Rewards Points: 914
Build your own. Why pay somebody else to do basic stuff.
Old 02-15-2019, 09:52 AM   #14
Rewards Points: 23,896
Doesn't look like that place likes to pay for much.
I'd have planned replacement for that piece the first time I saw it.
circuitman1 and splatz like this.
Old 02-15-2019, 10:07 AM   #15
Rewards Points: 2,468
That's what I was thinking. I wouldn't get into any long conversations with the management about that starter. Some things are shot on sight.
circuitman1 and tmessner like this.
This too shall pass.
Old 02-15-2019, 10:13 AM   #16
Yeah, it's dead!
It needed a new one years ago!
You need to look at our preventive maintenance contracts so this doesn't happen to you again.
Line voltage and control wiring in same JB katwalatapan Canadian Electrical Forum 10 10-21-2017 08:00 AM
Fire Alarm wiring stdave General Electrical Discussion 7 10-03-2017 08:45 PM
Attic wiring, is this code compliant? NDC Residential Electrical Forum 38 04-06-2017 12:07 AM
Wiring Left in Distribution Panel Hdinj Code Violation Discussion 26 02-07-2016 11:31 PM
NPLFA circuit wiring khfiei General Electrical Discussion 5 02-05-2016 11:03 PM
