One for the books - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree43Likes
Old 09-23-2016, 09:33 PM   #21
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,659
So does the coil still have voltage the whole time it is dropped out until it restarts?
I would have said bad aux contacts if you hadn't said the power stays on to the coil.
Check the shading coils on the armature. If they are loose or broken it could cause problems. If all else fails change the coil and armature.
Moonshot180 likes this.
Old 09-24-2016, 11:49 AM   #22
Rewards Points: 366
Yes
We checked that first
Checked that 3rd or 4th and did not appear to be an issue
Jhellwig likes this.
Brain John is offline   Reply With Quote
Old 09-24-2016, 12:39 PM   #23
Jhellwig's Avatar
Where did you reference your tester to when you hooked to it? Both terminals on the coil or the neutral somewhere else in the panel? Could be a bad overload block.
Old 09-24-2016, 12:46 PM   #24
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
The problem is voltage on a closed field winding looks exactly like voltage on an open field winding. I think current would be the only way to prove the circuit.
Always wear your gloves.
Old 09-24-2016, 06:45 PM   #25
Rewards Points: 366
When Our guy discovered it was most likely the coil he monitored voltage and current at the coil.
Old 09-24-2016, 06:51 PM   #26
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
So, did he see the coil circuit drop out or not?
Old 09-25-2016, 09:42 PM   #27
AWW
AWW's Avatar
Rewards Points: 42
We did coil voltage was present coil dropped out, cools off and automatically restarts
If the voltage applied to the coil stays at the coils rated voltage, I would suspect the coil and change the coil or contactor.
Monitoring the coil current during failure as mentioned earlier could also show it drop, but I'd like to see the voltage on the coil at the same time.
Automatically restarting concerns me. Normally when a starter shuts down it doesn't restart until something orders it to start (Operator / PLC / etc...)
AWW is offline   Reply With Quote
Old 09-25-2016, 09:45 PM   #28
AWW
AWW's Avatar
Rewards Points: 42
Can you supply the Make/Model of the starter? All suggestions are valid but I'd like to see a wiring diagram as I don't understand why it "automatically restarts".
Old 09-25-2016, 09:47 PM   #29
AWW
AWW's Avatar
Rewards Points: 42
Oops, I see your comment about autorestart in the program, I missed that earlier.
Old 09-25-2016, 10:15 PM   #30
AWW
AWW's Avatar
Rewards Points: 42
(Note: uninformed question follows, not the helpful suggestion you were probably hoping for.)
I don't know much about infrared, although I am planning to learn more. Do you break out an infrared camera and set it up and take video on this kind of thing? See if the contacts of the starter heat up over time, or maybe some connection is intermittent, or some other hotspot develops under certain conditions?
I have to admit I'd like to do this 50% because it seems like a useful tool, 50% because it would be a real cool gadget and impress the Shiite out of customers. Maybe 49%-51%.
With limited experience using IR camera's they are more suited for finding bad connections on buss's and such. A simple hand held IR sensor would tell you if equipment is out of range much easier and cheaper. Trying to spot a hot spot inside a coil, inside a contactor isn't easy, if not impossible.
Hand Held IR Sensor's
Majewski likes this.
Old 09-26-2016, 11:02 AM   #31
AKA Luketrician
Moonshot180's Avatar
Rewards Points: 1,101
without having a baseline for what a healthy coil is supposed to be reading (in regards to current) then may be hard to determine if there is or isn't an issue with the shading coil.
Like what was previously said, the shading coil may be degraded, hindering its ability to spread the magnetic pull across the entire the entire armature, (over time).
Moonshot180 is offline   Reply With Quote
Old 09-26-2016, 11:09 AM   #32
Rewards Points: 21,529
meanwhile, having lost valuable time and money while other companies are trying to figure out what is going wrong, the customer flew in ACME Electric at great expense (All the way from Honolulu) who ripped the old equipment out and replaced everything with brand new in a single 8 hour shift and it is all working just fine now...............................
Man those private jets sure are expensive....
LARMGUY, Majewski and AWW like this.
I stand with Tucker Carlson
Old 09-26-2016, 02:33 PM   #33
AWW
AWW's Avatar
Rewards Points: 42
Okay.... I'm retired but still getting educated....
If the shading coil was bad, wouldn't the coil make an obviously loud buzzing? Correct me if I'm wrong but isn't a shading coil just a heavy ring of copper wrapped around some part of the laminations of the contactor to create a "2nd-phase" to prevent the magnetism from dropping to zero during the AC's Zero-Voltage point?
If the shading coil was open there should be chatter. If it open's due to heat, then it should start to chatter after the heating period. I wouldn't expect it to drop the contactor out but when it starts chattering it may cause something else to drop it out, like excessive current on the motor due to the chatter, if it's severe enough.
Old 09-26-2016, 04:21 PM   #34
AKA Luketrician
I wouldn't say it could be open, only that there may be degradations within the coil. I agree that if that there would be chatter and/or immediate failure of the contactor pulling in if the shading coil was open.
I am not retired, but I am still learning, & I am always open to constructive criticism. I try to stay humble. My description of the shading coil, was a general description. I agree and understand the science behind it. In the future, I can describe as saying that the shading coil maintains an average magnetic field across the coil to ensure the armature is held in while the contactor coil is energized.
AWW likes this.
Old 09-26-2016, 04:26 PM   #35
AWW
AWW's Avatar
Rewards Points: 42
You say "may be degradations".
Let's explore that. What I remember of shading coils is that they are usually a heavy copper coil.
Faults:
1) Open.
2) Loosened somehow but still closed.
What other types of degradation can we have, other than dirty laminations which is more an armature/stator fault.
Old 09-27-2016, 07:56 AM   #36
AKA Luketrician
Good point AWW. Hard to imagine it being open, considering the size of them (typically).
Loose? Or maybe it's missing one..
I do like your other option of an issue with the laminations of the coil itself. Something is going on in there to degrade that magnetic field.
AWW likes this.
Old 09-27-2016, 11:49 AM   #37
Rewards Points: 21,898
I am glad you guys bring up few items .,,
There one item I almost forgot for many years I should know this one better but anyway.,,
but a wild guess but it did happend before did the phase conductor got too close to the coil ?? it may cause oddball magatanic signture or something like that cause the coil get overheated and drop out.
but a hidden crack on lamation plates can cause this too..
AWW likes this.
Upfront Pricing Books Ec88js Business, Marketing, and Sales 5 09-08-2016 01:31 PM
Books / first hire Fire Electrician Apprentice Forum 2 08-11-2016 04:33 PM
why we need the code book's motor FLA tables for? mike883 General Electrical Discussion 40 05-21-2016 05:12 PM
Estimating books bodo Business, Marketing, and Sales 2 03-24-2016 12:03 AM
Cost books fireryan Business, Marketing, and Sales 15 02-14-2016 10:13 PM
