One circuit per room (resi) - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree120Likes
Old 01-24-2019, 10:38 AM   #61
Rewards Points: 15,879
If a Canadian is cold, he puts on a sweater .
No. If a Canadian is cold, he moves to Florida, and then Hawaii and leaves all the stupid ones behind to freeze.
Old 01-24-2019, 10:47 AM   #62
Rewards Points: 3,712
The difference is substantial in terms of energy efficiency, comfort and air quality (health). The NRC studies arenít skewed because we have decades of practical experience.
I canít put it any other way. We have lived it both ways. You havenít.
This was directed at Hackworth but...
Just so we're on the same page - for at least 30 years in the US, we've been pretty gung ho on insulation in residential construction, including framing houses with 2x6s, etc. Also dryvit with exterior foam board on top of the 2x6 insulation has been pretty popular at least 20 years.
Around here - people very often upgrade, live in older starter homes when they're young, then build their dream custom home much larger and see much smaller heat bills in the bigger more modern house.
We just haven't been as gung ho with the vapor barrier, although we're pretty gung ho with the moisture barrier and caulking the daylights out of the exterior envelope. I haven't worked on a custom home that wasn't framed with 2x6's in quite a while.
As far as air quality - honestly I think the drafty old places have better air quality than the tight knit modern boxes. We have no smog here, letting in outdoor air is considered pleasant
The thing I am skeptical about is the difference between a decent vapor barrier and a maxed out vapour barrier, and even more so, the importance of tiny defects in the vapor barrier. When a building is sealed up enough that you have to blow in makeup air, what's the difference if you blow in 10000 cubic feet per day with a great vapor barrier, or you blow in 9000 cubic feet per day with 1000 coming in past the vapor barrier? Houses are not sealed up like submarines.
Unless you've lived in a well insulated house with a perfect Canadian style vapour barrier, and an identical well insulated house with a so-so US style vapor barrier, you haven't lived an apples to apples comparison, so it's unlikely anyone will change their mind over anecdotal info.
HackWork, lighterup, MTW and 1 others like this.
HackWork (01-24-2019)
Old 01-24-2019, 10:56 AM   #63
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
I was under the impression one of the big reasons for tight vapour barrier was the mitigation of mold growth due to condensation caused by cool air meeting warm surfaces. The idea being (I thought) that the house should be as close to air tight as possible so that condensation doesn't happen on organic materials (paper, wood) and therefore mold doesn't grow, then air intake is handled in a controlled manner through something like an HRV or at least a duct heater, so the incoming air is conditioned to the interior temperature.
spinninwheels likes this.
Old 01-24-2019, 11:14 AM   #64
Rewards Points: 286
See that is a prime example of conservative logic....I knew you weren't a troll.
Old 01-24-2019, 11:22 AM   #65
Rewards Points: 286
Originally Posted by just the cowboy View Post
When I was an apprentice a long time ago I was told
" If you can't proudly do a job and put your name on it don't do it"
I still go by this.
Cowboy
I learned that same way and tried to instill that same philosophy in my kids.
Old 01-24-2019, 11:56 AM   #66
Rewards Points: 403
This is an absolutely excellent post. The information is both reasonable and factual. Itís well written and easy to understand.
But the two Canadian trolls will just tell you how studies say what they do is so much better and blah blah blah blah blah.
splatz (01-24-2019)
Old 01-24-2019, 05:43 PM   #67
Rewards Points: 11,459
This is an absolutely excellent post. The information is both reasonable and factual. It’s well written and easy to understand.
Except we’re not trolling.
Would you be capable on intelligent conversation if we had the Stars and Stripes tattooed to our asses?
Old 01-24-2019, 06:00 PM   #68
Rewards Points: 403
Except weíre not trolling.
I have intelligent conversations every day while you are coming close to 360max's ratio of 99.9 garbage posts to .1 normal post.
Nothing you brought up in this thread was sensible or realistic. Just some off-base guesses about new home construction in the US.
I think it's time you go complain about Trump some more.
lighterup likes this.
Old 01-24-2019, 06:42 PM   #69
Who made you the site censor? You’re the last person around here I would listen to when it comes to what I can and cannot post.
Did I damage your tender little ego, Hack?
Old 01-24-2019, 07:02 PM   #70
We draw fresh air into the home in a controlled manner. No doubt drafty homes have excellent air exchange but it also creates the need for spot heating in peripheral rooms.
Old 01-24-2019, 07:06 PM   #71
Let me get this straight. The site rules are now:
CT has now become the DJT Idol Worship Club.
Electrical posts must now be cleared through Hack.
Have I got that right?
B-Nabs likes this.
Old 01-24-2019, 07:18 PM   #72
Rewards Points: 403
Can you keep your trolling in the Controversial section please 360, I mean 99cents?
lighterup (01-25-2019)
Old 01-24-2019, 07:51 PM   #73
Rewards Points: 424
Originally Posted by catsparky1 View Post
If it is a custom we do what we are paid to do . If it is a tract you get what the minimum that we can do to make the most money . I care less about space heaters and window units . When you buy mass produced housing you get a garbage house and you can pay a stupid amount in extras for us to do what you want . The last time I checked we are here to make money so I aint giving you anything more that what I have to .
Now with customs when you hire us we sit down with the customer and go over what you want and what you need . Although one power circuit per 500 square is more than adequate in most cases . Power and lighting are always separated in customs but not in tracts .
If it is an apartment . Well ha ha ha ha ha ha giggle we do what we can get away with . If 3/4 of the pad is on one breaker with 50 recepts on it and another circuit with 2 recepts on it oh well . Right now we are doing a 90 unit loft set up section 8 housing garbage . I told the boys if I see a tape measure you're fired . Blow and go don't care if the lights are lined up or if counter plugs look like the waves at north shore . It is gov funded dirt bag housing and I could careless what the fools living there think . PW resi is awesome . Ten units every 5 days . One more week of rough in left and we are at less that 40% of bid labor . Im getting a huge bonus at the end of this one .
Prevailing wage? no specifications? anyone as clerk of works inspecting?
farmantenna is offline   Reply With Quote
Old 01-24-2019, 07:54 PM   #74
Rewards Points: 424
Originally Posted by manchestersparky View Post
When I wired my house each bedroom got its own receptacle circuit. Each of the bathrooms got their own circuit. The lights are not on the receptacle circuit. WHY ??
I have 2 daughters and a wife. You say SO ????
3 females equals 3 hairdryers and 3 curling iron being used at the same time.
I also built the house with 3 full bathrooms
I never had a problem with the circuits getting overloaded and tripping the breakers !
separating lights and receptacles also minimizes actually seeing the voltage dropping when those hair dryers are turned on
Old 01-24-2019, 08:06 PM   #75
Rewards Points: 286
I think it's the best way to wire up a job.
In addition I wire everything in 20 amp circuits rather than 15.
Old 01-24-2019, 08:50 PM   #76
Rewards Points: 7,520
I like that idea, but here we would have to use 20 amp rated (t-slot) receptacles on 20 amp circuits by code. Not a big deal but they do cost more
Old 01-24-2019, 09:06 PM   #77
Who made you the site cop or did you just appoint yourself?
Old 01-24-2019, 09:07 PM   #78
Rewards Points: 403
Youíre on thin ice buddy.
Old 01-24-2019, 09:19 PM   #79
Really? Are you the new hall monitor? Are you going to tell the teacher on me?
Old 01-24-2019, 09:24 PM   #80
CoolWill's Avatar
Rewards Points: 2,012
He did. That's why I'm here. Settle down or there will be consequences.
lights, outlets go out, but circuit breaker doesn't trip???????????????????????? fvpirrone Residential Electrical Forum 22 08-15-2018 02:00 PM
20 amp dining room circuit MTW NEC Code Forum 46 12-19-2017 10:18 AM
Dining room arc fault circuit 321sparky Residential Electrical Forum 3 12-07-2017 01:33 PM
is the new code require the bath room sink receptacles to be dedicated circuit? mike883 Canadian Electrical Forum 6 09-04-2017 09:48 PM
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
