Over Tightening - Electrician Talk - Professional Electrical Contractors Forum
Like Tree26Likes
  • 3 Post By Forge Boyz
  • 3 Post By brian john
  • 2 Post By micromind
  • 1 Post By Sam22
  • 5 Post By HertzHound
  • 1 Post By electricguy
  • 1 Post By flyboy
  • 7 Post By 3DDesign
  • 2 Post By Incognito
  • 1 Post By macmikeman
Old 04-13-2019, 07:15 PM   #1
Sam22's Avatar
Default Over Tightening
Over tightened lugs in residential panels can bite through a couple strands of 4/O stranded aluminum conductor. Although obviously not ideal, does anyone see this causing major problems if it’s just one or two strands? Re terminate?
Sam22 is offline   Reply With Quote
Old 04-13-2019, 07:18 PM   #2
Bird dog's Avatar
Rewards Points: 530
Please fill out your profile. If on a smart phone select pc view & turn phone sideways.
Old 04-13-2019, 07:25 PM   #3
Rewards Points: 3,096
Use the recommended torque and see what happens ya we are suppose to torque to the manufactures specs I go by feel lol I know if i over torque the hex screw will want to strip.
Old 04-13-2019, 07:30 PM   #4
Rewards Points: 60
When I torque terminations, I tighten it to specs, wiggle the wire, which will loosen it, and torque again. I usually do it several times, till it stops getting loose. The first time I torqued something, I just went till it clicked and the inspector made me tighten them more because they were loose.
Sent from my Moto Z (2) using Tapatalk
glen1971, Rora and DashDingo like this.
Old 04-13-2019, 08:26 PM   #5
Rewards Points: 3,538
Since the first electric lines were connected to a house electrical connection in the range of 99.9% have been over tightened.
manchestersparky, 360max and telsa like this.
The Following 2 Users Say Thank You to brian john For This Useful Post:
360max (04-13-2019), manchestersparky (04-18-2019)
Old 04-13-2019, 11:54 PM   #6
Rewards Points: 3,422
Given the torque specs I've seen, I'm pretty sure that some stuff would burn up if they were followed........
macmikeman and DashDingo like this.
macmikeman (04-16-2019)
Old 04-14-2019, 12:01 AM   #7
Sam22's Avatar
The question is more about the fact that the over tightened lug cut through a couple strands of the 4/O aluminum service conductor. Wondering how likely it is that this would cause a safety issue.
DashDingo likes this.
Old 04-14-2019, 03:41 AM   #8
HertzHound's Avatar
Rewards Points: 1,476
If youíre cutting through strands, itís a safety issue.
<<<< CHIP ME >>>>Not
Old 04-14-2019, 05:46 AM   #9
TTR in BC makes us use 250 mcm Al for 200 amp services
Max C. likes this.
Old 04-14-2019, 06:18 AM   #10
Small Potatoes
flyboy's Avatar
Rewards Points: 4,377
It is probably less likely to be a safety problem then a loose connection would be.
The only safety concern I can see with over tightening is that alll the components of the lug/termination points are potentially stressed beyond their tinsel strength and could conceivably fail with vibration and/or excessive ambient temperatures.
I think you'll have a hard time finding specific data on overnighting of electrical connections, but it's probably out there.
micromind likes this.
Old 04-14-2019, 07:12 AM   #11
Rewards Points: 2,314
I have never seen over tightening cut thru strands of the wire.
I can't help it if I'm lucky
Old 04-14-2019, 07:13 AM   #12
Rewards Points: 3,078
It's more likely that the installer used a razor knife/utility knife to strip the conductor, nicking it, and that caused the strand to break.
Greg
Old 04-14-2019, 12:27 PM   #13
RSE Master Electrician
Incognito's Avatar
Rewards Points: 954
I’ve seen this when guys do a “clean and torque “ on existing equipment. Some customers shut down and do one every five years. I’ve worked with guys feel they need to actually tighten every lug and many don’t use a torque wrench which causes the wires to get over torqued.
Paul S. and glen1971 like this.
Old 04-14-2019, 01:01 PM   #14
Conductor Protector
Funksparky's Avatar
Rewards Points: 72
Table 39 allows 4/0 for 200 amp residential services...
Funksparky is offline   Reply With Quote
Old 04-16-2019, 01:00 AM   #15
Rewards Points: 333
I'd say it's best to re-terminate. I don't like seeing cut or damaged conductors. Yes, aluminum is easy to squash in a terminal but I don't like seeing the conductors cut into. - I'd say it decreases the conductor's surface area thereby decreasing the overall ability to carry it's rated current without overheating. - I typically like to ere on the side of caution.
Paul S. is offline   Reply With Quote
Old 04-16-2019, 05:39 AM   #16
DashDingo's Avatar
Rewards Points: 22
Over tightened lugs in residential panels can bite through a couple strands of 4/O stranded aluminum conductor. Although obviously not ideal, does anyone see this causing major problems if itís just one or two strands? Re terminate?
Nope, itís the same as throwing a chair off the titanic.
DashDingo is offline   Reply With Quote
Old 04-16-2019, 06:19 AM   #17
Rewards Points: 21,843
I've torqued feeders to manufacturer engineering spec and then gave them a wee tug and out they came.
Somebody sitting in a comfy chair in an engineer's office needs to put down his pencil and actually get out to the field and try his chit out sometime.
tmessner likes this.
I stand with Tucker Carlson
Old 04-16-2019, 09:00 AM   #18
canbug's Avatar
Rewards Points: 2,162
I had a buddy help me on a panel change, yes he's a j-man, and he used his little Makita impact on the breakers. Now those were over torqued.
Tim.
Old 04-16-2019, 05:08 PM   #19
JoeSparky's Avatar
Rewards Points: 2,191
Tim.
Meh. I use the M12 on all the branch breakers, neutrals and grounds and the 18 on the feeders. I'll let you know when and if I get a call back or a fire results
To the OP
Residential services never see close to their FLA and the rare occasion that they do, it it's only for a split second. You could probably shave half of the strands off of your feeders and nothing bad would ever happen. I don't suggest this, just saying.
Power Conduit Tightening. Lone Crapshooter Tools, Equipment and New Products 25 08-04-2018 08:37 PM
