Overheating problem, Help! - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree39Likes
Old 11-02-2017, 09:00 PM   #21
Rewards Points: 3,062
Originally Posted by Bird dog View Post
I would think you'd get all three! We can't have questions like "Explain the difference between T250.66 & T250.122." or could we?
Not everyone uses the same codes.
So that could be racist!
Old 11-02-2017, 09:01 PM   #22
0.66
Nailed it.
When did you become an engineer?
Bird dog likes this.
Old 11-02-2017, 09:21 PM   #23
goodtimesgladly's Avatar
Rewards Points: 288
Yea my suggestion is to get a licence.. He says he switched the poles. Main lines coming into the building? I do not think he will live long enough to call an electrician. He will electrocute himself first.
goodtimesgladly is offline   Reply With Quote
Old 11-02-2017, 09:55 PM   #24
Rewards Points: 3,078
Since this oven will be on for more than 3 hours, shouldn't it be #8 wire with a 50 amp breaker?
Greg
The Following User Says Thank You to 3DDesign For This Useful Post:
Knightryder12 (11-03-2017)
Old 11-02-2017, 10:10 PM   #25
Rewards Points: 1,651
The heating element probably cycles on and off.
Old 11-02-2017, 10:58 PM   #26
Rewards Points: 1,631
Get a wood fired pizza oven and whamo it is fixed like that yo .
MikeFL likes this.
catsparky1 is offline   Reply With Quote
Old 11-03-2017, 01:06 AM   #27
Rewards Points: 1,512
you need to replace the cable to the oven with a bigger one,
As the current one is NOT up to the task,
And if it has been constantly over loaded ?
Is probably now damaged.
All this is assuming your main panel/general service
can handle the extra load
Which we don't know for sure
Old 11-03-2017, 05:25 AM   #28
Rewards Points: 1,328
0.66
Nailed it.
An engineer would have said .56 that's why they make the big bucks.
hardworkingstiff and drsparky like this.
Old 11-03-2017, 08:49 AM   #29
Southeast Power's Avatar
Rewards Points: 8,728
Originally Posted by BuzzingZ View Post
So I’m working at a pizza place. They have an electric oven. 220v 37.5amps. Whenever we turn the oven on, one of the main lines coming into the building overheats. It’s always the same one. We have already gotten a new breaker, tried switching the poles, eve broke the oven down looking for bad connections and shorts. Does anyone have any other troubleshooting suggestions that we may have missed. Thanks!
You have to consider the other loads on that leg.
If you had an amp meter, you might discover your handiman put most of the lighting load on one leg.
Just my guess due to you only mentioning one load.
That # 10 or really rated for 40 amps but we usually fuse them at 30 with some very specific exceptions. I'm not seeing that as the main problem.
Heat could be an overload or a poor connection. If a wire burns, it always burns towards the source.
One more thing before this thread gets closed.
How do you know the oven draws 37.5 amps?
Are you looking at a name plate?
Do you know the voltage coming into the building?
208 or 240?
Old 11-03-2017, 10:07 AM   #30
An engineer would give you a correct answer but like Hack's completely useless for the intent of the question asked.
Old 11-03-2017, 01:33 PM   #31
Rewards Points: 256
Originally Posted by matt1124 View Post
Maybe someeday we will be able to look licenses up online and whoever takes in new applicants can just check before approval.
Licenses? Who needs a ****ing license?
circuitman1 likes this.
Old 11-03-2017, 01:37 PM   #32
And the fact that some locations don't require them.
Old 11-03-2017, 02:36 PM   #33
Electrical-EE's Avatar
Rewards Points: 142
Might be your gauge is not appropriate.
One thing about life: it goes on!
Automation solutions:
Electrical-EE is offline   Reply With Quote
Old 11-03-2017, 06:13 PM   #34
Magic Smoke Remover
Rewards Points: 1,966
Ok fine enter your license number or answer this quizlet. Send the new applicants to me, I'll weed them out
Tags
circuit panel, oven, overheating
PowerFlex 700 Drive problem SergKom PLCs, VFDs, Motors and Controls 4 08-31-2017 04:11 PM
Problem in Kollmorgen Servo drive Servostar 620 Signode PLCs, VFDs, Motors and Controls 7 04-06-2017 10:07 AM
G24 2-pin to G24 LED problem RobbySals Lighting Design 3 01-02-2017 03:01 PM
how you guys trouble shooting the loose connection problem? mike883 General Electrical Discussion 87 12-05-2016 11:47 PM
