Paddle fan wall switching - Electrician Talk - Professional Electrical Contractors Forum
Like Tree32Likes
Old 06-07-2016, 08:30 PM   #1
neutral member
readydave8's Avatar
Rewards Points: 314
Default Paddle fan wall switching
Sometimes we put 2/gang and switch motor and light separate.
Some times we have hot for motor and switched hot for light, wall switch only works light and fan works whether light is on or off.
This was very difficult to explain to a builder today, she asked me to change it so that the wall switch controls the entire unit. (Which I don't like because if someone is running fan only and shuts it off with wall switch, I go into a dark room, turn on switch, and fan starts turning but light does not come on).
Well of course I made the change, but is my switching method really that bizarre?
Dave Ruth
Old 06-07-2016, 08:35 PM   #2
Rewards Points: 24,110
Always use a switch for fan control and separate switch for light. Seems one switch for both is less than par.
lighterup likes this.
The Following 2 Users Say Thank You to MechanicalDVR For This Useful Post:
John Valdes (06-08-2016), readydave8 (06-08-2016)
Old 06-07-2016, 08:39 PM   #3
Gouging Profiteer
Rewards Points: 791
This is a very odd thing because it depends on the user. You can use the pull chain for the fan, no need to go over to the switch. Also, if the fan has a remote, then having two switches won't work.
I generally have a switch for the light and run constant hot for the fan, this allows them to use the pull chain for the fan or the remote if it came with one.
readydave8 likes this.
Old 06-07-2016, 08:48 PM   #4
drewsserviceco's Avatar
My personal preference is two switches. Not that I can always get the customer to agree to that, I still pull a 3wire. Also, with the remotes becoming more commonplace, they kind of render the two switches useless. If I had roughed in for two switches and the fan ends up having a remote I just use the switch closest to the door and cap everything else off.
The Following 3 Users Say Thank You to drewsserviceco For This Useful Post:
HackWork (06-07-2016), John Valdes (06-08-2016), readydave8 (06-08-2016)
Old 06-08-2016, 07:52 AM   #5
Going_Commando's Avatar
Rewards Points: 1,634
Thats how we normally do it. 3 wire to the box, hit the switched to the light and feed the fan hot all the time.
The Following User Says Thank You to Going_Commando For This Useful Post:
Old 06-08-2016, 08:18 AM   #6
Gouging Profiteer
Rewards Points: 791
Even that isn't the right solution because when they have a remote the light buttons on the remove won't work.
That's why I say fan wiring is odd and depends on the situation.
Switched, Flyingsod and Majewski like this.
Old 06-08-2016, 08:24 AM   #7
sbrn33's Avatar
Rewards Points: 3,614
I do the hot for fan switched for light all the time. Then if they don't like it I sell them a dual control.
I like the first method mainly because 9 out of 10 people leave the fan on medium all the time. The other reason is then you don't have to worry about fan hum.
Most of the time I talk them into can lights and a fan only. I have yet to see a decent looking fan/light.
The Following User Says Thank You to sbrn33 For This Useful Post:
Old 06-08-2016, 08:35 AM   #8
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
I would tell builder that NFPA 70 requires habitable rooms to have a wall switched light and that her request is a violation.
As a side bar note , I advise you to not allow a resi builder dictate your
installation techniques.
Down the road , the scenario you articulated about not being able to
control the light in the dark is a trivial law suit waiting to happen..
well the electrician ..blah blah blah and then because I couldn't see , I
fell and injured myself..blah blah ..
The builder is not going to open her mouth..she'll be referring the
lawyers to address how you wired it.
The Following User Says Thank You to lighterup For This Useful Post:
Old 06-08-2016, 10:02 AM   #9
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,820
Ditto. Every time you bank on a no remote, it has a remote. Funny how that goes.
Old 06-08-2016, 10:06 AM   #10
lighterup's Avatar
With regard to motors shring the light on the same switch , I cannot
tell you how many times I have seen the motor burn out cause
happy homeowner went to home depot , bought a light dimmer and
installed it on that shared switch , thus eventually burned out the
motor with an incandescent light dimmer.
Majewski likes this.
Old 06-08-2016, 10:21 AM   #11
Majewski's Avatar
Service call! lol
Old 06-08-2016, 11:24 AM   #12
Rewards Points: 52
They make a switch with a dinner and 3 position slide for a fan on one yoke
TRurak is offline   Reply With Quote
The Following User Says Thank You to TRurak For This Useful Post:
macmikeman (06-08-2016)
Old 06-08-2016, 11:26 AM   #13
Majewski's Avatar
If I had a dinner switch I would never stop flipping it!
Flyingsod likes this.
Old 06-08-2016, 11:43 AM   #14
Rewards Points: 1,028
That's how I do it in my house and would pull a three conductor cable on a job regardless of how they want it to operate.
I like the ability to remove the pull chain if they want to.
2 switches. One for lights and one for fan.
readydave8 and Bird dog like this.
The Following User Says Thank You to John Valdes For This Useful Post:
Old 06-08-2016, 11:45 AM   #15
Rewards Points: 21,531
Lutron or Hampton bay dual slide control wall switch. IF somebody insists on thee way light control , AND they live thru my speech about using your God given legs to walk across a room and not be a lazy asshole, then I will use a two gang box and separately three way or three way dim the light, and put in a fan only wall control in the space next to it.
readydave8 and Majewski like this.
I stand with Tucker Carlson
Old 06-08-2016, 10:40 PM   #16
Rewards Points: 44
Put receiver in canopy, and give them all the remotes the want.
FF301 is offline   Reply With Quote
Old 06-09-2016, 12:01 PM   #17
I hate trying to fit the damn receiver module into the canopy and sometimes its almost impossible.
Unless they are designing much smaller receivers, I don't every see myself using one again.
Sparkchaser1 likes this.
Old 06-09-2016, 12:09 PM   #18
I'm guessing you haven't done one in a while huh? They have grown a bit smaller and easier. And.... some fans are now shipping with a bigger cradle also.
A lot of fans lately I hang have remotes but up at the fan the receiver is built in. I like to hang those, but I don't recommend them because once you loose the remote you are up the creek and no paddle.
Does all this make me a fantrician?
John Valdes and Majewski like this.
Old 06-09-2016, 02:01 PM   #19
Majewski's Avatar
Mike you're like a super duper fantrician now.
Old 06-09-2016, 05:56 PM   #20
Rewards Points: 386
I like the separate wiring so that you can put a fan control and light control on the wall, i'm forever losing the remote. One of our suppliers should pick up on this issue and come up with a remote that accepts both hots independently somehow, It'd be a money maker at supply houses, though not really at box stores
Anathera is offline   Reply With Quote
How to install a new outlets on prexisting wall VanillaSnake21 General Electrical Discussion 2 04-24-2016 07:24 AM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 06:38 PM
Wall anchor Mptoth380 General Electrical Discussion 16 02-25-2016 02:29 PM
Boxes part way in block wall psd7.3 Commercial Electrical Forum 28 02-06-2016 11:54 PM
locating conduit or LV cable behind wall or missing conduit end? lortech Structured Wiring 3 01-18-2016 12:35 PM
