photocell with time on control - Electrician Talk - Professional Electrical Contractors Forum
Like Tree10Likes
  • 1 Post By 220/221
  • 2 Post By HackWork
  • 1 Post By emtnut
  • 2 Post By John Valdes
  • 1 Post By jw0445
  • 1 Post By John Valdes
  • 2 Post By Majewski
Old 07-07-2016, 05:43 PM   #1
Rewards Points: 49
Default photocell with time on control
I was asked to submit a bid on the installation of new LED flood lights to light up a subdivision entrance sign. the client wants the lights to come on at dusk, and stay on for 4 to 5 hours, and i cant seem to figure out what to use here. Any help would be appreciated.
electricdrummer is offline   Reply With Quote
Old 07-07-2016, 05:50 PM   #2
Band Member
emtnut's Avatar
Rewards Points: 1,974
Time delay off relay would do the trick.
Others may know of an 'of the shelf' solution though.
Old 07-07-2016, 05:57 PM   #3
Rewards Points: 26,502
http://www.intermatic.com/en
Intermatic has canned solutions for every manner of lighting control... plug-n-play simplicity.
You won't even need a photo-cell as their stuff comes with a digital memory that knows when the Sun sets. You merely dial in the latitude and pick a time zone // longitude.
You're better off just picking up the telephone and talking to their tech rep.
MechanicalDVR (07-07-2016)
Old 07-07-2016, 06:50 PM   #4
220/221's Avatar
Rewards Points: 4,108
I'm certain by now (2016) someone has built a decent PC on, timer off unit.
I've been using a cheap and easy method for decades with a simple photocell and "standard" T101 intermatic single pole timer.
Put the photo cell switch leg on one terminal of the mechanical contacts and the switch leg to the lights on the other terminal.
Set the timer to come on way early and you won't have to adjust it seasonally.
120V......PC.....timer contact A.......timer contact B........lights.
The only "hack" is, you must remove the timer motor lead from the contact terminal and make it hot.
Old 07-07-2016, 07:08 PM   #5
Rewards Points: 1,191
They are LED lights, tell the Majewski's to just leave the sign on all night. Connect a photocell and be done with it.
splatz and Majewski like this.
Majewski (07-07-2016)
Old 07-07-2016, 07:53 PM   #6
ponyboy's Avatar
Rewards Points: 709
Intermatic ej500 or 600. It's a digital astronomical in wall timer that will do what you want and adjust for dusk and dawn throughout the year according to your region
Old 07-07-2016, 08:11 PM   #7
daveEM's Avatar
Rewards Points: 2,382
Aube T1072-3 or Honeywell RPLS740B1008/U << same company.
Programmable astronomical timers.
^^ Totally blow the doors of 70's photocell control. I've got 30 foot trees covering up the old photocells.
I like perfect.
Old 07-07-2016, 09:14 PM   #8
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Clearly they don't want to part with that extra nickel.
Old 07-07-2016, 09:22 PM   #9
Band Member
emtnut's Avatar
I just thought they were being kind to the neighbours
Majewski likes this.
Old 07-08-2016, 01:15 PM   #10
Rewards Points: 224
Photocell and clock contacts in parallel with each other.
Either one will take control depending on state. Simple and nothing required except a parallel circuit.
Actually I'm wrong. The photocell would still be closed even though the clock opens.
The clock would have to open the photocell contact as well. Easy enough.
Sorry about the mistake.
jw0445 and Majewski like this.
Old 07-08-2016, 02:19 PM   #11
jw0445's Avatar
Rewards Points: 1,818
hit the timer first then the photocell. As an example, set timer for on at 5pm and off at eleven. If it's not dark at 5 the light won't be lit but it will still turn off at 11.
Dash Dingo likes this.
Old 07-08-2016, 08:55 PM   #12
neutral member
readydave8's Avatar
Rewards Points: 128
Many or most common photocels turn light on when power applied (normally closed?), light stays on for a few minutes until photocel opens.
So I would try going to photocel first and then to timer, clock motor always hot of course.
Dave Ruth
The Following User Says Thank You to readydave8 For This Useful Post:
220/221 (07-16-2016)
Old 07-08-2016, 09:02 PM   #13
Digital electronics has gotten so cheap that ROM replaces photocells.
You just DON'T NEED THEM ANY MORE.
The device is booted up -- and its clock is set -- and its location is entered.
The electronics does ALL THE REST.
Think of it as a specific purpose PLC.
Old 07-08-2016, 10:51 PM   #14
Dash Dingo's Avatar
Rewards Points: 318
Simple... Have the TC control the photo cell and the photo cell control the lights or contactor.
Set the TC to come on at 4 pm and set to shut off when ever you want.
Dash Dingo is offline   Reply With Quote
Old 07-08-2016, 11:08 PM   #15
Rewards Points: 224
See. It is easy. But I get the new stuff, the next great thing. My point was you could accomplish what the OP wanted without any special equipment.
Thanks Dash Dingo. Good post.
Old 07-08-2016, 11:11 PM   #16
Majewski's Avatar
It's because everyone in Minnesota is smart.
John Valdes and Dash Dingo like this.
Old 07-09-2016, 01:03 AM   #17
MikeFL's Avatar
Rewards Points: 588
Macy's uses an astronomical timer for their sign lighting to make the lights come on in the evening and a local time clock to turn them off when the store closes. The store manager can control the time clock for whatever time they're closing. Here's how it's connected:
Sorry about the image being there 2x. First time posting a picture on this forum.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 07-09-2016, 01:04 AM   #18
corn-fused
papaotis's Avatar
Rewards Points: 620
only problem i have with that is the old mechanical timers last for a long time, electronic **** is designed to fail! depends on if you want reliable or replaceable
The Following User Says Thank You to papaotis For This Useful Post:
Old 07-16-2016, 10:34 AM   #19
Proud Navy Veteran
Greg's Avatar
Rewards Points: 592
I would use an Intermatic 8215C time clock. It's multi-voltage and fully configurable for anything you want including pulse operation for mechanical contactors. Plus it is astrological. No photocell required. I've used them for all kinds of applications. Right now I have 4 of them controlling mechanically held contactors with an over-ride switch. They control the interior perimeter lights on four different wings in my hospital.
Memorial Day: All gave some but some gave all.
Take the time to tell a Veteran Thank You, You owe him/her at least that much. After all Freedom is not Free.
Do you need an engineer to design control systems? JimmyBond PLCs, VFDs, Motors and Controls 13 07-04-2016 01:15 PM
I need help finding some control board compnents, can anyone help me out? Hippie PLCs, VFDs, Motors and Controls 25 05-31-2016 04:42 PM
Not feasible or necessary at this time... Jhellwig Workplace Safety 27 05-26-2016 01:40 PM
Single Phasing burning out control coils WMick General Electrical Discussion 7 03-16-2016 06:44 PM
