Pictures of your work - Page 12 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree159Likes
Old 06-30-2016, 04:27 PM   #221
Rewards Points: 416
Originally Posted by MikeFL View Post
Are they painting tractor trailers in there? Motorhomes?
A couple of TEE fittings would have saved you having to go around the window and door.
mitch65 is offline   Reply With Quote
Old 06-30-2016, 05:28 PM   #222
220/221's Avatar
Rewards Points: 4,126
I guess it depends on how it's landscaped in the end.... little bit of turf on either side, and they'll look great !
I'm confused.
You know those are the covered parking structure posts, right?
Old 06-30-2016, 07:33 PM   #223
Rewards Points: 3,050
Originally Posted by 220/221 View Post
I'm confused.
"Several years ago I had to remove four parking lot lights/poles/bases to make way for some covered parking."
May have missed this part of your post.
emtnut likes this.
Old 07-10-2016, 01:27 PM   #224
Rewards Points: 172
Originally Posted by triden View Post
Just wondering if that was the new Royal Inland Hospital addition that completed last month.
Are you around kamloops then Triden?
BlackHowling is offline   Reply With Quote
Old 07-10-2016, 03:35 PM   #225
Sparky Girl's Avatar
Rewards Points: 792
I posted these earlier. It's from the last job I did before retiring. I did the layout, with another electrician, determining location and elevation of all the conduits. It took us two months to create the design where we had to coordinate with the other trades to claim underground real estate. We had to start the feeders at 9.5' below grade to fit everything in under the slab.
The 12.8 Kv feeders coming into the building.
If you look in the background at the steel columns, the final grade will be flush with the top of the concrete the columns sit on.
We had to figure every bank run individually so we don't exceed 360 degrees bend in any run. We also had to use long sweep 90's where specs required it.
As we filled in the levels with conduit, we came back with stone to take up the void and moved up from there.
The pitch up of some banks (on the left) was done to keep the bends to a minimum.
Underneath one of the 16 switchgear cabinets. All total, I figured we pulled over 25 miles of 500 MCM.
Sparky Girl is offline   Reply With Quote
The Following 5 Users Say Thank You to Sparky Girl For This Useful Post:
220/221 (07-10-2016), dawgs (07-12-2016), freefreeqaz (07-10-2016), glen1971 (07-13-2016), zac (07-10-2016)
Old 07-10-2016, 03:44 PM   #226
Band Member
emtnut's Avatar
Rewards Points: 2,018
I'm confused.
Apparently I'm more confused than you
I thought they were the luminaire bases
Majewski likes this.
Old 07-10-2016, 03:48 PM   #227
Pretty snazzy.
Sparky Girl likes this.
Old 07-10-2016, 03:52 PM   #228
Rewards Points: 52
That is damn impressive Sparky Girl. What kind of facility is that?
TRurak is offline   Reply With Quote
Old 07-10-2016, 05:37 PM   #229
Rewards Points: 792
It's a 36 megawatt data center. At its peak we had almost 300 electricians working there on 6-12's. We had three electricians working on design (2 on power and 1 on data) and pulled in a few more as the job got underway.
We all know how it usually is, we are handed prints and told to build it. Then we have to make it work. On this job, the electricians took the engineered drawings and we made our own. The guys loved working off electrician-designed drawings.
One of the best jobs I did in my time, and I had some pretty good jobs.
MechanicalDVR, emtnut and Majewski like this.
Old 07-12-2016, 06:52 PM   #230
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,366
Wow!
Signal1 is online now   Reply With Quote
Old 07-12-2016, 09:46 PM   #231
Aegis's Avatar
Rewards Points: 1,726
I wish I could do a job like that! I've never done that much duct bank.
Aegis is offline   Reply With Quote
Old 07-12-2016, 10:31 PM   #232
I seriously doubt many here have done a project like that.
LuckyLuke and Majewski like this.
Majewski (07-13-2016)
Old 07-13-2016, 01:49 PM   #233
Rewards Points: 1,878
All stainless. Had to be demoed out once because the painters didn't cover it the first time and customer wanted to see the $$$ they spent.
No stainless 7/8 available and was told not to shim the disconnects off the wall and concentric KO's so 1/2" 5* offsets on all 8 pipes. Right behind a cooling tower.
Old 07-13-2016, 01:56 PM   #234
dawgs's Avatar
Rewards Points: 1,008
Originally Posted by TGGT
All stainless. Had to be demoed out once because the painters didn't cover it the first time and customer wanted to see the $$$ they spent. No stainless 7/8 available and was told not to shim the disconnects off the wall and concentric KO's so 1/2" 5* offsets on all 8 pipes. Right behind a cooling tower.
Looks really good. But why would anyone pay for SS conduit and fittings and not use SS disconnects?
TGGT and Majewski like this.
dawgs is offline   Reply With Quote
Old 07-13-2016, 04:16 PM   #235
Because dumb. The moisture will absolutely get inside these discos.
Old 07-13-2016, 05:57 PM   #236
dawgs's Avatar
Huh?
Old 07-13-2016, 06:03 PM   #237
Rewards Points: 252
Huh?
He was answering your question of "why would someone pay for SS pipe but not disconnects" with "because they are dumb."
Arc'n'Spark is offline   Reply With Quote
Old 07-13-2016, 06:05 PM   #238
Huh?
They didn't put a whole lot of thought into it. Less than 20' away is another set of disconnects ran in galvanized rigid. It will all see a lot of moisture from the cooling tower mist.
Side work with a solar company Elec tricka Business, Marketing, and Sales 6 04-25-2016 11:34 AM
Work in SW Virginia andytheham Looking For Work 0 03-19-2016 05:43 PM
Looking for Entry Level Electrical work in Blacksburg Roanoke VA area. andytheham Looking For Work 1 03-09-2016 07:59 PM
Work Experience Database NJWVUGrad General Electrical Discussion 0 02-04-2016 01:18 PM
Getting my first car, advice to keep it clean when used for work commute ? David C Tools, Equipment and New Products 27 01-24-2016 11:39 PM
