Pole lights arcing when off - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 10-05-2012, 12:44 AM   #41
Rewards Points: 5,198
Originally Posted by big2bird View Post
Just bond the lift to the pole with a jumper cable. Bond= zero potential difference.
After you leave...then what?
Old 10-05-2012, 12:45 AM   #42
Take off the jumper cable?
big2bird is offline   Reply With Quote
Old 10-05-2012, 12:46 AM   #43
Cletis's Avatar
Rewards Points: 2,050
Default br
neg first..postive sec then reverse just like a car
I'm shakin it boss..I'm shakin it
Old 10-05-2012, 12:50 AM   #44
greenman's Avatar
Rewards Points: 698
what are those lines above the lights, are they hydro wires?
“We the willing, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”THE NUCLEAR ELECTRICIAN
greenman is offline   Reply With Quote
Old 10-05-2012, 12:51 AM   #45
Cletis's Avatar
Default .
130kV Transmission lines
Old 10-05-2012, 12:54 AM   #46
Actually that's backwards. When you jump a car battery, always pos first. When you do negatives last, it won't arc to the chassis.
I hope you realise I said use them to jump from the chasis to chassis, correct?
When you do HV work, you always shut it off, allow x/time/volt for bleed off, then ground it all together in case some knucklehead turns it on somewhere.
Old 10-05-2012, 12:54 AM   #47
What is a hydro wire?
Old 10-05-2012, 12:56 AM   #48
cog
stuiec's Avatar
Rewards Points: 1,180
Trasnsmission line. They have alot of hydroelectric generated power out east.
Old 10-05-2012, 01:11 AM   #49
Rewards Points: 21,898
Originally Posted by nolabama View Post
Your so in southern Ohio. I should try to get a car number off that train and see whereabouts it was today.
Closer inspect of that photo looks like its not our signaling equip.
Either CSX or BN signaling sytem I know CN use differnt one.
Merci,
Marc
nolabama (10-05-2012)
Old 10-05-2012, 01:23 AM   #50
greenman's Avatar
Rewards Points: 698
sorry, Transmission lines
Old 10-05-2012, 01:41 AM   #51
greenman's Avatar
Rewards Points: 698
Limits of Approach
Voltage phase to phase
Metres
Feet
Over 750 V to 75 kV
3
10
Over 75 kV to 250 kV
4.5
15
Over 250 kV to 550 kV
6
20
How close are you?
The Following User Says Thank You to greenman For This Useful Post:
JohnR (10-06-2012)
Old 10-05-2012, 02:04 AM   #52
TTW
TTW's Avatar
Rewards Points: 169
Wow. That wasn't fun at all... It didn't sink in til they were coming down with burn marks on arms then it set it. Actually, they were laughing about it all day. Everyone is safe and home now, but it was no joke at all. Learned a big lesson today and probably won't even work around that stuff anymore or just prep everything up correctly with proper ppe next time.
and you are OK with that?... all's well that ends well?...
"It didn't sink in til they were coming down with burn marks on arms"
Thank whomever it is that you thank that they are not in cold storage in the morgue right now.
Think about it. Really think about it.
Yeah, big joke all right...
* Better... Faster... Cheaper... Pick Two! *
If at first you don't succeed, Try Something Else! (because you're probably doing something wrong)
TTW is offline   Reply With Quote
Old 10-05-2012, 02:10 AM   #53
greenman's Avatar
Rewards Points: 698
We do alot of swith yards, we had a guy about five years ago, that was in a hurry and disconected it the wrong way. that was the last thing he ever did. play it safe.
Old 10-05-2012, 03:45 AM   #54
triden's Avatar
Rewards Points: 382
Originally Posted by Shockdoc View Post
transient voltage from high tension lines? possible but unlikely.
It's very possible. I changed irrigation pipes in a field below high tension lines and when we picked the pipe off the ground the current would arc into our belt buckles. We had to drag chains from the pipe cart to keep it grounded so we wouldn't get shocked
Parking Lot Pole Lights yrman General Electrical Discussion 13 09-05-2012 01:38 PM
pole lights MasterE NEC Code Forum 13 06-21-2012 10:56 PM
Very Long Run EGC Pole Lights Cletis NEC Code Forum 47 10-28-2011 08:02 AM
Pole lights venture Business, Marketing, and Sales 3 12-23-2010 04:06 PM
pole lights question [email protected] General Electrical Discussion 5 12-17-2008 08:23 AM
