Pool heater - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 1 Post By just the cowboy
  • 1 Post By macmikeman
  • 1 Post By lighterup
Old 07-12-2018, 10:11 AM   #1
Default Pool heater
Hey guys,
I recently installed a 50A circuit for a pool heater, it’s been a about 2 weeks since the install & now the homeowner is telling me that the 50A breaker for the outside ac condenser is tripping when both circuits are running together, but the ac won’t trip if the pool heater is off.
Advice?
Lefty23 is offline   Reply With Quote
Old 07-12-2018, 10:54 AM   #2
Rewards Points: 3,002
Test for voltage drop on the ac when its starting
Old 07-12-2018, 11:42 AM   #3
just the cowboy's Avatar
Rewards Points: 812
Default Two things
First Please fill out your profile so we know more about you, not a DYI.
Second is the new breaker under the ac breaker in panel, if so heat from heater breaker may be tripping ac breaker. If so move breakers apart from each other.
Good luck
Cowboy
"DID THIS FIX IT??"
Old 07-12-2018, 12:18 PM   #4
Rewards Points: 22,809
Air conditioner's are closed minded xenophobic types. They particularly dislike pool heaters. I wish we could all just learn to get along................
Ctsparky93 likes this.
Start buying American
Old 07-12-2018, 12:58 PM   #5
Rewards Points: 8
Good luck
Cowboy
+1
If breakers are adjacent, they're tripping on thermal not overload
Sent from my HTC6545LVW using Tapatalk
Shaneyj is offline   Reply With Quote
Old 07-12-2018, 04:59 PM   #6
Breakers are nowhere near each other
(Sorry about the bio)
Old 07-12-2018, 05:38 PM   #7
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
I would love to get involved int his conversation
but i can't until profile is filled out Op explains
what an outside wireman is.
John Valdes likes this.
Old 07-12-2018, 05:48 PM   #8
Rewards Points: 3,768
Originally Posted by Shaneyj View Post
+1
An overload results in a thermal activation.
Molded case circuit breakers trip for two reasons thermal, due to an overload and magnetic (instantaneous trip) due to a fault or any high inrush current that exceeds the rating of the Cb typically 6-10 times the CB rating.
Old 07-12-2018, 05:51 PM   #9
Rewards Points: 8
Is it possible for 2 loads in close proximity to each other on the bus to cause heating to the point that it trips a breaker without either being overloaded?
Old 07-12-2018, 05:58 PM   #10
If the panel has a problem supporting a 50 amp water heater and the start up amps required by the AC compressor then it will cause a low voltage situation. The heater doesn't care about voltage but the AC will struggle to start leading to higher amps which equals lower voltage which equals higher amps (up until the breaker trips).
Thats why i asked if theres a voltage drop when the ac starts. A hard start capacitor may be required.
Old 07-12-2018, 06:12 PM   #11
It says “inside”wireman .
Old 07-12-2018, 06:25 PM   #12
lighterup's Avatar
correct...begging the question what's an outside wireman?
Isn't an AC and pool heater outside?
Old 07-12-2018, 06:31 PM   #13
Rewards Points: 6,421
I think there was a military MOS for outside wireman. Not really something we use in the civilian world. Most people would call them a lineman. I call them pole monkeys.
Old 07-12-2018, 06:38 PM   #14
MTW
Rewards Points: 12,973
Call an electrician.
Old 07-12-2018, 06:42 PM   #15
Advice?
I'd love to give you some, but I'd like to know what visual observations and meter measurements you've made so far to calibrate the advice a little more specifically for you.
Old 07-12-2018, 09:22 PM   #16
Rewards Points: 1,564
What type of breaker is it, that is tripping ?
Is it just a standard over currant cut out ?
Or is it something more like a GFCI or AFCI ?
Old 07-12-2018, 11:02 PM   #17
Rewards Points: 24,442
Becoming a leftist?
Old 07-12-2018, 11:05 PM   #18
In the military it isn't linemen that run large gensets to provide power to various temporary facility loctions.
Old 07-13-2018, 01:33 AM   #19
Rewards Points: 21,898
Hey guys,
Advice?
Here the thing .,,
If you have outdoor panel if you have them facing south then the sun can get the tempture inside of the outside panel more hotter so it will trip more earlier.
espcally if you have both are running at the same time.
Ya can check the current drawage with ampclamp but with the AC unit running you should be above the min. running amps if stated on nameplate.
and check the voltage drop when the heater is on too.
Old 07-13-2018, 02:34 PM   #20
Rewards Points: 1,204
Welcome to Electrician Talk.
Thanks for taking the time to fill out your profile.
residential swimming pool heater lighterup NEC Code Forum 28 08-25-2017 05:45 PM
Distance from pool for pool heater NDC Canadian Electrical Forum 13 06-13-2017 08:36 AM
Pool heater without a neutral TechieBecky General Electrical Discussion 6 06-07-2017 08:21 PM
Pool Heater Interior Wiring Methods? Kaffeene NEC Code Forum 8 05-11-2017 08:51 AM
Need help installing this pool heater NDC Residential Electrical Forum 0 08-04-2016 09:31 AM
