Portable generator hookup to panel - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 2 Post By HackWork
  • 2 Post By 460 Delta
  • 2 Post By Nutmegger777
  • 1 Post By joebanana
  • 1 Post By Max C.
  • 4 Post By frenchelectrican
Closed Thread
Old 10-27-2018, 05:24 PM   #1
Default Portable generator hookup to panel
I installed an interlock switch on my panel for my generator and when I went to try turning on some breakers using only generator power, only a couple breakers worked.
The generator is 7200 running watts and I was only turning on one breaker at a time to test each one.
I have a 10/3 240v extension cord running from generator to house inlet (L1430) and 10/4 from inlet to 40a breaker in panel.
Any help as to why I'm getting no power to some breakers would be greatly appreciated.
Thanks
Jmh1111 is offline
Old 10-27-2018, 05:27 PM   #2
tjb
Cool Kid
Rewards Points: 363
Have and electrician put his meter across both poles of the breaker, and go from there.
tjb is offline
Old 10-27-2018, 05:28 PM   #3
No Longer Here
Rewards Points: 578
Thanks
You did it wrong. And since A) you did it wrong and B) you don't know what you did wrong, you proved that you should not have done it in the first place.
Call an electrician, this is NOT a DIY thing. Electrical installations are not trial and error. You are risking other people's lives.
tmessner and Max C. like this.
HackWork is offline
Max C. (10-27-2018)
Old 10-27-2018, 05:58 PM   #4
460 Delta's Avatar
Rewards Points: 2,180
You likely are only heating up one half of the panel, every other one. Please call a pro in before you or your family or a lineman get hurt.
Overkill Is Underrated
460 Delta is online now
Old 10-27-2018, 06:42 PM   #5
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
I just had a call yesterday.
HO asked if I could give free estimate to install "Transfer Switch"..
not generator...he wanted to do that himself....
Once I heard that , I knew i was not gonna get up off my chair , but
I humored the call.
He went about he just bought the house , wants TS (and "remote outlet")
installed...he would go to store for a generator...
Said he wanted his geo thermal heating , heat pump , electric Hot water
tanks etc....to be ready for winter back up power
Yeah conversation went no place in a hurry either. He did not want to
hear it.
I wonder?
lighterup is offline
Old 10-27-2018, 06:54 PM   #6
Can't Remember
Rewards Points: 1,542
Sure...
nrp3 is offline
Old 10-27-2018, 08:04 PM   #7
Nutmegger777's Avatar
Rewards Points: 408
ibtl
electricguy and Max C. like this.
Nutmegger777 is offline
Old 10-27-2018, 09:21 PM   #8
Rewards Points: 8,233
Is it a 3 phase generator? How many phases is your panel? Does that 10/3, 240 volt extension cord have a ground? Where are you located? Is this Canadian wiring?
Max C. likes this.
joebanana is offline
Old 10-27-2018, 09:23 PM   #9
Rewards Points: 888
YouTube always has all the answers...
Nutmegger777 likes this.
Max C. is offline
Old 10-27-2018, 10:10 PM   #10
Rewards Points: 21,898
Thanks
Just STOP right there and just get a electrician to come out and they can fix the system before you destory something along the way.
I can see few things are allready wrong so I just refered to let the electrician see it themself and they can fix this mess.,,
I am closing this thread and ., no I am not going to pôst the DIY link at all .,
frenchelectrican is offline
Max C. (10-29-2018)
Closed Thread
low voltage security panel mounting gpop Other Codes and Standards 5 10-17-2018 03:23 PM
New Main Panel in Residence dalizardking427 Residential Electrical Forum 6 09-15-2018 08:51 AM
Need advice for mouting a pony panel NDC Canadian Electrical Forum 10 04-05-2018 02:52 PM
Double panel design question. JohnJ65 Services and Service Equipment 23 07-07-2017 08:19 PM
Main panel, subpanel, detatched structure, objectionable current and 3-phase cdw904 Residential Electrical Forum 4 05-10-2017 02:47 PM
