Portable label maker - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree27Likes
Old 08-26-2016, 08:58 AM   #21
Rewards Points: 1,191
Do you use an Excel template?
I made up a simple template in the word processing program in Open Office, I just put it under my company letterhead. I adjust the size when printing so that it will fit on the panel door.
How do you match it up with the panel slots?
I don't. The breakers are numbered so I just attach the panel schedule to the door.
Old 08-26-2016, 09:03 AM   #22
Rewards Points: 14,049
The number thing gets a little confusing if I mount the panel upside down. Sideways, it's okay .
Flyingsod likes this.
Old 08-26-2016, 09:42 AM   #23
Rewards Points: 114
I hate label makers. I prefer to make labels with label stock, you fill out a spreadsheet template, print it from your computer, and away you go. You can make a whole page at a time, or just one label. It's a much better way to work. If you absolutely have to make labels one at a time on the job, and you won't know what you're labeling until you're up there, it won't work out, but that's almost never the case.
http://www.cableorganizer.com/ziptap...el-sheets.html
That depends on what kind of work you do. It's almost always the case for me since I rarely even know what the job really is until I get there.
Old 08-26-2016, 09:45 AM   #24
Rewards Points: 114
Originally Posted by Speedy Petey View Post
Any Brother P-Touch that uses TZ tapes.
Tapes are laminated and last forever. You can get flexible tape to put on cables. You can get high-strength tape. You can get tape from 1/4" to 1"+ wide. Tape backing is split so it's easy to remove. Replacement tape on Amazon is almost 1/2 the price it is at Staples and such.
A Sharpie is fine for quick corrections and additions to an existing crappy directory. For a new panel nothing beats a label maker.
No! It's not fine at all. Pencil only in a panel directory please. At least in an industrial setting. Grrrr
Majewski and Signal1 like this.
Old 08-26-2016, 03:43 PM   #25
Speedy Petey's Avatar
Rewards Points: 600
When a panel schedule needs to be neat, I like to print it out with my company logo and info at the top. I find it a little easier to type it all up at home and print it out, but it requires a return trip to the job.
I will agree there. Some panels, like new installs, I like to use a full page directory with a sheet protector. I was more referring to a panel swap with the label maker.
HackWork likes this.
Old 08-26-2016, 03:44 PM   #26
Rewards Points: 600
What, you don't carry a thing of white-out on your truck? I though that was SOP.
Old 08-26-2016, 04:01 PM   #27
Tip of the day.
Those blank address labels that come on a sheet of paper ready to be printed on are the perfect size to cover over a space on the panel schedule when you need to change or correct something.
Old 08-26-2016, 04:10 PM   #28
LuckyLuke's Avatar
Rewards Points: 546
Originally Posted by gluiec View Post
Being you and I live in the same city I'd caution against Rhino....nothing wrong with the labler......just that all the supply houses dropped it so cartridges are a little like hen's teeth. I forget the brand Westburne and the likes are carrying, Eecol stocks K-sun. I'd base my purchasing decision on availability of cartridges...in the format I use (heat shrink, black on clear, black on white etc), and......must have QWERTY keyboard.
I get mine from Eecol or from http://neumannmarking.com/products/ as they have good stock selection and fast delivery.
It's not that I am afraid to die, I just don't want to be there when it happens.
LuckyLuke is offline   Reply With Quote
Old 08-26-2016, 04:52 PM   #29
just the cowboy's Avatar
Rewards Points: 140
Default P touch
Originally Posted by kered View Post
Thank you, I thought was going nuts. I searched through every menu option, trying each & every margin & cut option, but to no avail.
It's ridiculous the waste on every label you print. After labeling up a data cabinet there's a blizzard of wasted tape at your feet. Great printer, but jeez the waste of tape
I must check out the 3m printer you suggested
On the P touch it is the CODE (red) + TAPE buttons, the XXXX is the number of blanks to print after each label. Use no X's then when you finish printing Press CODE + SPACE to Feed out to end of cutter. NO waste.
The Following 3 Users Say Thank You to just the cowboy For This Useful Post:
Flyingsod (08-27-2016), kered (08-27-2016), telsa (08-27-2016)
Old 08-26-2016, 05:57 PM   #30
wcord's Avatar
Rewards Points: 1,654
The Rhino doesn't like falling on the ground or being cold.
Our first Rhino, stripped the gears when 1 of the guys didn't let it warm up when he brought it in from the van (only -20c)
Another one fell, maybe 4 feet and the cutter stopped working.
The Brady is cheap enough and seems to be a bit more robust( not as many printing options as the Rhino)
For panel directories, an Excel program and card stock works very well
Old 08-26-2016, 06:47 PM   #31
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 678
I'm looking for a labeler as well. Thought I would post this though to help everyone out with panel directories.
telsa and Majewski like this.
HackWork for Moderator
~ I believe in Hax ~
TheLivingBubba is offline   Reply With Quote
The Following 2 Users Say Thank You to TheLivingBubba For This Useful Post:
Takideezy (11-11-2017), telsa (08-27-2016)
Old 08-27-2016, 03:57 AM   #32
Rewards Points: 24
Ill give that a try just the cowboy thanks
kered is offline   Reply With Quote
Old 08-27-2016, 08:19 AM   #33
Can't Remember
Rewards Points: 502
I had the one that used the TZ tapes and it printed just fine. Second the wasted tape, never bothered to figure out how to change it. Carried scissors. It got dropped too many times. I bought a 3m. Easy enough to use but the print quality isn't as good as the brother and the tapes are lousy. Maybe a suggestion from someone for a different model of tape. Really only need white with black lettering. Sometimes clear with black lettering.
Old 08-27-2016, 09:23 AM   #34
I'm going to try the Brother. It's an investment of about fifty bucks for the printer and a cartridge. I've spent fifty bucks on worse things. It's for low usage anyway and I just want my work to look a little more professional than a Sharpie.
Old 08-27-2016, 10:03 AM   #35
Rewards Points: 114
Fwiw the brady bmp's have a bunch of built in templates designed specifically for electricians. Just my opinion but the template for panel schedules that run along side the breakers looks way more professional than ones printed from a desk top. Plus you can get cartridges that make self laminating wire markers and the only thing more professional than that is printed shrink wrap wire markers..imo of course.
Old 08-27-2016, 12:41 PM   #36
Can't Remember
Rewards Points: 502
I don't have to make a whole lot of labels. The Brother was fine when I had it, but being the tool fool that I am, I bought something fancier. I'll talk to the 3m guy at the Rexel show. Think I did last year too, but forgot to follow up.
Old 08-29-2016, 09:50 AM   #37
Rewards Points: 140
Default Cable markers
They have a cable marker that is flexable and works great also.
TZe-FX231
Old 08-29-2016, 10:32 AM   #38
Watt Pusher
B-Nabs's Avatar
Rewards Points: 472
I like the Brother P-Touch because it's dirt cheap and really simple. We really only use them to label receptacles and other small equipment. I always print full page panel directories.
As to the wasted tape, if I'm making several labels, I enter as many as I can until the screen is full, with TWO SPACES in between each one. Then it prints out a big long strip, and I use scissors or dykes to cut them up. Then you only get that wasted inch at each end. Saves tons of tape.
Old 08-29-2016, 10:45 AM   #39
Rewards Points: 3,006
I use them too for the same reasons. When I started paying for them and the tape myself I got frugal.
Old 08-29-2016, 08:19 PM   #40
Rewards Points: 52
I have a 3m label maker. I can't remember the name but it will print some electrical symbols. It. Uses 1/2" or 3/4" tape.
TRurak is offline   Reply With Quote
Label for Murray Top-Hinge 18 space 125a Combo Panel kfm Services and Service Equipment 3 08-17-2016 05:15 PM
Paid Label Research ( 50mm - 100mm ) ( 2 inches ) AllenHan Tools, Equipment and New Products 0 08-11-2016 08:20 PM
100 KW Portable Generator Modification ROCKDOG Services and Service Equipment 7 08-06-2016 10:39 PM
Portable generator requiring signage??? jsmart84 Residential Electrical Forum 5 02-23-2016 07:01 PM
Portable Job trailer grounding? JPRO2 General Electrical Discussion 1 01-21-2016 01:44 AM
