Proper goop to protect battery terminals? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree28Likes
Old 04-23-2019, 12:23 PM   #21
Rewards Points: 1,266
I had a part time job in a service station when I was a kid, did minor repairs and etc. The mechanic was a friend of mine and knew I was handy with electricity and electronic issues, so once in a while he'd have me look at one that had him stumped.
I fixed a lot of things by just brightening up the battery and ground strap terminals and lugs, greasing them up with silicone grease, and putting them back together. I go to where I did that before I'd even try to figure things out. A lot of times the connections looked fine and were tight, but this fixed things. I imagine the oxidization can creep in there, swell a bit and you wind up barely connected or no connection.
Years later maintaining the batteries for a telco CO, everyone used the manufacturer supplied terminal grease, those systems worked great and I don't ever remember getting a bad connection on a terminal.
With lead acid battery you can have acid migration, that is where the acid creeps up the post as no post seals are perfect. This causes a hard crust that is not conductive and leads to high resistance connections.
The_Modifier and splatz like this.
Old 04-23-2019, 12:45 PM   #22
Rewards Points: 2,782
I wonder if gooping up the base of the post just halted the creep up, filling the gaps in the seal around the post.
Old 04-23-2019, 12:46 PM   #23
Rewards Points: 1,428
Originally Posted by trentonmakes View Post
Ive always used this stuf on car batteries
Clean with baking soda and vinegar, then spray things on
That’s the sort of stuff I’ve used in the past, but am just trying to get by with what I have on hand. Won’t be the first. Time to be called a cheapskate!
brian john likes this.
Old 04-23-2019, 02:59 PM   #24
Bird dog's Avatar
Rewards Points: 830
It's a lawnmower, so, I wouldn't use anything that is flammable like auto grease. Is the battery under the seat or near a hot engine?
Old 04-23-2019, 03:07 PM   #25
It has to do with the post seals newer batteries they use a better sealant, little stops it completly, but you can slow it down
Old 04-23-2019, 03:48 PM   #26
trentonmakes's Avatar
Rewards Points: 138
CHEAPSKATE!
bill39 likes this.
trentonmakes is online now   Reply With Quote
Old 04-23-2019, 10:12 PM   #27
Rewards Points: 36
Dump some bug juice on it before you tighten. Good drink, and problem solved
mjbasford is offline   Reply With Quote
Old 04-26-2019, 06:51 PM   #28
Rewards Points: 94
Sparling I hope, dielectric grease will conduct and if it melts and contacts any metal components of the engine will lead to self-discharge of the battery, in a UPS system it results in ground fault alarms..
Where did you get the idea dielectric grease conducts?
John Valdes likes this.
Old 04-26-2019, 09:15 PM   #29
My mistake dielectric grease does not conduct, they do make a Conductive grease. Different animals.
Old 04-26-2019, 10:40 PM   #30
Rewards Points: 90
I would think you would want something di-electric
Eddie702 is offline   Reply With Quote
Old 04-26-2019, 10:54 PM   #31
Rewards Points: 1,520
On all of my vehicles, I have always used regular wheel bearing grease. Most anything to seal the connection will be beneficial.
Old 04-26-2019, 11:31 PM   #32
Jlarson's Avatar
Rewards Points: 3,812
I use either silicone rubber grease like I use on load breaks or super lube multi purpose, I always have a couple tubes of each in the trucks. Always have my battery brushes too, common fix on gensets and engine driven compressors is messed up batteries.
Jlarson is online now   Reply With Quote
Milwaukee Tools and 9.0ah battery problems Going_Commando Tools, Equipment and New Products 27 11-22-2018 09:33 PM
M12 Fuel Free 6.0Ah Battery Promo - May 2018 UncleMike Tools, Equipment and New Products 6 05-02-2018 04:56 AM
Milwaukee M18, 9.0 battery warning 3DDesign Tools, Equipment and New Products 25 07-14-2017 07:22 PM
