proper seal tite connector installation - Electrician Talk - Professional Electrical Contractors Forum
Old 01-30-2015, 09:57 AM   #1
butcher733's Avatar
Rewards Points: 798
Default proper seal tite connector installation
On this specific example how would you install the connector?
I'll take therapists for $400.
butcher733 is offline   Reply With Quote
Old 01-30-2015, 10:18 AM   #2
Rewards Points: 2,136
no need for the plastic seal if entry is threaded
Old 01-30-2015, 10:21 AM   #3
Rewards Points: 134
I would install it as shown on the left. The limit switch body is threaded and will accept the connector without the locknut. I don't see any advantage of putting the sealing locknut on the outside of the fitting.
Sparky48 is offline   Reply With Quote
Old 01-30-2015, 12:07 PM   #4
220/221's Avatar
Rewards Points: 4,352
1) Screw part A into the hub (or hole w/locknut)
2) Install flex (with wires) with part B attached
And, I haven't used metallic sealtite in decades.
The Following User Says Thank You to 220/221 For This Useful Post:
MHElectric (01-30-2015)
Old 01-30-2015, 12:16 PM   #5
butcher733's Avatar
Rewards Points: 798
This is industrial work, they don't know what carflex is.
Old 01-30-2015, 12:47 PM   #6
Rewards Points: 1,224
If you read the UL information, it will tell you that the LFMC connector is only to be used with locknuts, it has not been evaluated for use with threaded entries.
That being said, it is done every day for industrial applications. I often use sealing locknuts with 90 or 45° connectors to lock them in the position that I want them to be in, but don't use them with straight connectors.
Old 01-30-2015, 01:07 PM   #7
Rewards Points: 20
Don, Once again the forum will not allow me to quote you.
I am not familiar with the UL writings.
In most every instance, entering a switch body like this, there would be no available threads for a lock nut unless you were to use it under the switch body.
I have always thought this was a waste of time. But have seen it plenty times.
Putting the lock nut on the connector threads first, then screwing the connector threads into the switch body, then tightening the lock nut up against the outside of the switch body. Is this what you mean?
I can see no reason to do this as I install the connector first and tighten it well.
In this case, the lock nut does absolutely nothing except possibly lock the connector in place? Whats the reasoning?
Old 01-30-2015, 01:11 PM   #8
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
I think he's right if you want to "aim" a 90 in a certain direction, it may not"bottom out" pointing the way you need it to. A locknut would allow you to lock it in at any point.
Old 01-30-2015, 01:26 PM   #9
butcher733's Avatar
Rewards Points: 798
why are the threads tapered if they aren't for threaded hubs?
Old 01-30-2015, 01:54 PM   #10
Some connectors are listed to be treaded and other only with locknut and seal
Old 01-30-2015, 02:12 PM   #11
Rewards Points: 134
I don't know how we get off topic but the question was/is "on this specific example". Where did the conversation on 90 degree fitting come from? That sure appears to be a straight connector to me.
Old 01-30-2015, 02:18 PM   #12
Mad Skills
Celtic's Avatar
Rewards Points: 2,050
left side
póg mo thóin
Old 01-30-2015, 02:22 PM   #13
Rewards Points: 4,138
Are there enough threads engaged in the installation on the right?
I'd install like the one on the left...
Old 01-30-2015, 02:49 PM   #14
Rewards Points: 20
Yep, that's the point I needed to hear. Thanks Jerry.
Hey who you like in the game? Cheaters? or Hawks?
Old 01-30-2015, 02:55 PM   #15
just the cowboy's Avatar
Rewards Points: 24
Default So it don't go in to far
I have put the locknut on the outside when the connector would thread too far into the switch and be in the road of the connectors
"DID THIS FIX IT??"
The Following 2 Users Say Thank You to just the cowboy For This Useful Post:
John Valdes (01-31-2015)
Old 01-30-2015, 04:05 PM   #16
evil bastard
Rewards Points: 746
I'm REALLY going the Hawks win, but I'd be scared to bet that way. ....lol
Old 01-30-2015, 04:07 PM   #17
evil bastard
Rewards Points: 746
Enough threads? Nobody mentioned explosion proof.
Old 01-30-2015, 04:22 PM   #18
Rewards Points: 3,090
Finally! That's a very important question!
More specifically, is this in a hazardous location? If so what class and division?
Borgi
Old 01-30-2015, 05:06 PM   #19
butcher733's Avatar
Rewards Points: 798
Borgi
It is not a classified location AFAIK. Tire press, steam, nitrogen, compressed air and hydraulics. oily and messy as hell in the pit where these are going.
The Following User Says Thank You to butcher733 For This Useful Post:
51360 (01-30-2015)
Old 01-30-2015, 05:31 PM   #20
A Little Short's Avatar
Borgi
Senior class & South Eastern Division!
Proper installation of SJ cord Shockdoc NEC Code Forum 12 09-13-2014 09:35 AM
Fishing through 1/2" non metallic seal tite Incubus311 General Electrical Discussion 23 03-13-2014 10:57 AM
Proper Grounding and installation of 200 amp service wdthrush01 Canadian Electrical Forum 25 02-20-2013 09:42 PM
seal tite without compression fittings noarcflash Commercial Electrical Forum 24 04-17-2012 03:26 PM
seal tite grounding dogg Commercial Electrical Forum 4 06-11-2011 05:08 PM
