proper seal tite connector installation - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 01-30-2015, 07:18 PM   #21
Rewards Points: 4,138
Originally Posted by mcclary's electrical View Post
Enough threads? Nobody mentioned explosion proof.
When I asked nobody mentioned it wasn't... Not to mention the strength of one thread engagement vs more... Most sealing locknuts I've seen take up at least two threads...
Old 01-30-2015, 07:30 PM   #22
Rewards Points: 1,224
[quote=John Valdes;1610073]Don, Once again the forum will not allow me to quote you. ...
Putting the lock nut on the connector threads first, then screwing the connector threads into the switch body, then tightening the lock nut up against the outside of the switch body. Is this what you mean?
Exactly.
[quote[I can see no reason to do this as I install the connector first and tighten it well.
In this case, the lock nut does absolutely nothing except possibly lock the connector in place? Whats the reasoning?
It is rare that you can point the 90 or 45 degree connector in the correct direction and still have a tight connection, so in those cases I use the locknut to hold it tight. It often bottoms out short of where I want it to point, and backing out a 1/2 turn or more leaves a loose connection. Most of these are in areas that could get wet and so I use a sealing locknut to keep it pointed correctly and keep the water out.
John Valdes (01-31-2015)
Old 01-30-2015, 07:33 PM   #23
Originally Posted by Borgi View Post
Finally! That's a very important question!
More specifically, is this in a hazardous location? If so what class and division?
Borgi
You can't use a LFMC connector that is directly screwed into an enclosure that is required to be explosion proof.
Old 01-30-2015, 08:19 PM   #24
Rewards Points: 419
From what I've seen, they're approved for use in Class I Div II, and Class II/III locations.
mikey383 is offline   Reply With Quote
Old 01-30-2015, 08:29 PM   #25
Rewards Points: 3,090
The post by mcclary just reminded me to ask if this was in a hazardous location. Didn't mean to imply that an explosion proof enclosure was needed.
Hope I am saying that correctly.
Borgi
Old 01-30-2015, 08:41 PM   #26
MTW
Rewards Points: 677
At my last job I wired industrial machinery and it was company policy to use sealing washers on every connector that wasn't in a non-threaded opening.
Old 01-30-2015, 08:46 PM   #27
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
I'm REALLY going the Hawks win, but I'd be scared to bet that way. ....lol
I'll bet you 100 forum points
Old 01-30-2015, 10:15 PM   #28
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Done and done. I'm a gambling man.
Old 01-30-2015, 11:51 PM   #29
Originally Posted by butcher733 View Post
why are the threads tapered if they aren't for threaded hubs?
In general the male threads on connectors are not tapered threads, they are straight threads.
Old 01-30-2015, 11:54 PM   #30
I said that they can't be used with an enclosure that is required to be explosion proof. I said that because an enclosure that is required to be explosion proof will need a seal fitting between the enclosure and the liquid tight flexible metal conduit. Class II and III enclosures and many Class I, Division 2 enclosures are not required to be explosion proof.
The Following 3 Users Say Thank You to don_resqcapt19 For This Useful Post:
51360 (01-31-2015), glen1971 (01-31-2015), mikey383 (01-31-2015)
Old 01-31-2015, 12:13 AM   #31
Rewards Points: 419
I see what you're saying now. Confusion on my part. My apologies.
Old 01-31-2015, 01:04 PM   #32
Rewards Points: 20
Originally Posted by just the cowboy View Post
I have put the locknut on the outside when the connector would thread too far into the switch and be in the road of the connectors
I have never had an issue with NEMA style switch bodies as the threaded hub is quite deep.
Yes, I see and to be very honest, I never worried to much about aiming and holding position as once the conduit was inserted and tightened, it would not move enough to worry about.
Thanks.
Old 01-31-2015, 05:58 PM   #33
butcher733's Avatar
Rewards Points: 798
I looked into that and appleton/oz-gedney supply them with npt threads and using them in threaded hubs is in the product description. I haven't used any other kind in so long I forgot they came with straight threads!
I'll take therapists for $400.
butcher733 is offline   Reply With Quote
Proper installation of SJ cord Shockdoc NEC Code Forum 12 09-13-2014 09:35 AM
Fishing through 1/2" non metallic seal tite Incubus311 General Electrical Discussion 23 03-13-2014 10:57 AM
Proper Grounding and installation of 200 amp service wdthrush01 Canadian Electrical Forum 25 02-20-2013 09:42 PM
seal tite without compression fittings noarcflash Commercial Electrical Forum 24 04-17-2012 03:26 PM
seal tite grounding dogg Commercial Electrical Forum 4 06-11-2011 05:08 PM
