Pulling Rope - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 04-15-2012, 01:22 AM   #21
BBQ
Salty Member
BBQ's Avatar
Originally Posted by TimChaput69 View Post
Sorry BBQ but when your pulling 500's over 300'
And after break what are we going to do?
We likely have a dozen pullers, a couple feeders and room in the warehouse full of pulling ropes.
It is a big part of what we do.
I do feel slightly bad when I see a rope go right from being dragged through a mud puddle and back on to a spool but that feeling goes away quickly. When the rope looks rough they get tossed out.
Most of our ropes are the double braid type you and Mark describe in 3/4" and 1", we typically use larger ropes than really needed. In smaller sizes it is some other type of synthetic with low stretch.
Now on the other hand .... if I was a climber and I expected my ropes to keep me alive I would be treating them with much love.
Old 04-15-2012, 01:30 AM   #22
This amp goes to 11
Not saying that they can't be used. Christ I've seen 1" ropes in the mud plenty of times and they just get rolled up on a spool and put away and forgotten. What sucks is as a small outfit when a rope breaks and you've only got like 4-6 guys and the wire pull is half to 3/4's of the way in it "really sucks"!! You treat your rope anyway you want but I wash mine ever night, I try to get my wife to clean it but she only does it like once a week!!
TimChaput69 is offline   Reply With Quote
Old 04-15-2012, 01:34 AM   #23
This amp goes to 11
I guess I'm really sensitive about ropes because I use them so much. I used to do tower work and solar so we used to double duty to ropes. Not to mention I'm a climber too so I guess i'm inclined to take care of whats gonna take care of me!!
Old 04-15-2012, 01:43 AM   #24
Data Tech/Apprentice.
Rewards Points: 22
That sounds like a 5/8 rope. There really is no way to "splice" a rope. What you do is use a sheeps bend. Take the damaged part and make a loop then in the working part of the rope tie the knot into the rope, you can't pass that section through and device after though because it will hang on everything.
These are a couple of eye splices I've done and had kicking around the garage. You can join 2 ropes with the same method.
Old 04-15-2012, 01:57 AM   #25
This amp goes to 11
You must be a boater!! I've made a bunch of "eyes" for my dad. He has a 52' Trojan on the ocean. Anyway they make a kit for making those eyes and it works wicked slick. I learned in Boy Scouts how to "whip" ends of rope but eyes are way better. Now if you can just join those two pieces of rope then you splice!!
Old 04-15-2012, 02:04 AM   #26
Rewards Points: 22
Not a boater but have pulled alot of timber out of the bush using eye splices I've made.
I have spliced 2 pieces of rope together, I dont have any with me right now but its pretty simple once you get started, just like making an eye.
Old 04-15-2012, 02:20 AM   #27
This amp goes to 11
Thats awsome!! I've made them by hand its a nice piece of work, its almost a lost art.....you can do the same with steel cable too. Just takes longer, I've mended just about any kind of working rope or cable, especially when on a job site thats about a hundred miles from nowhere! With steel cable if you don't have a welder on hand you cab weave it same as rope. If you do have a welder you tack the two ends of the cable and it will almost be a continuous cable.
Old 04-15-2012, 02:46 AM   #28
Rewards Points: 1,224
I have never seen a single braided rope that was made for use with cable pulling equipment? Do they make single braided rope for that use?
I do know it needs to be a "static" rope and not a "dynamic" rope when you are using it with tuggers and all that I have ever seen was double braided
Old 04-15-2012, 03:05 AM   #29
This amp goes to 11
Usually "braided" rope isn't one weave its three separate ropes braided into one. To have a braid you need prime or odd sets, just like stranded wire. If you look at what you think is a single braided rope its probably three different sets of rope. Now the way to tell a cheap rope from a good rope is:
1) whats the construction of the rope, three braids, five braids, seven braids, and so on.
2) whats it made of: hemp, nylon, cotton, synthetic.
3) weight limit buy size.
4) dry rope or not treated, most dry ropes are gonna be about 25-35% more expensive but they don't absorb water witch saves weight and will not rot.
Old 04-15-2012, 03:11 AM   #30
Originally Posted by GEORGE D View Post
Ok, so that's just round nylon?
absolutely NOT! using nylon rope is extremely unsafe.
it will stretch 60% before breaking, and a 1/2" nylon
rope can store enough energy to be lethal.
for most stuff, 9/16" pulling rope from greenlee, maxis,
or several other places is rated about 12,000 lbs pull
strength, and is sufficient.... i've pulled five 500's
thru 4 90's 250' with a 9/16" pull rope.
user8640521 is offline   Reply With Quote
The Following 2 Users Say Thank You to user8640521 For This Useful Post:
GEORGE D (04-17-2012), guest (04-16-2012)
Old 04-15-2012, 03:23 AM   #31
This amp goes to 11
Not to be a rope geek but any weaved rope has to be an odd number. You can't weave just two strands(just ask you wives or girlfriends) it has to be an odd number. Also the weave is what gives it strength, just like a chinese finger toy, the more you pull the tighter it gets. The cost is product of construction and stretch. ie; dynamic or static. Honestly I don't know why they even sell dynamic rope for pulling, it makes no sense to me. All a dynamic rope does is store a boat load of energy and before you know it your sitting on the floor with a blackeye wondering WTF just happened. Static is the best for pulling and rappeling....no stretch and constructed differently.
Old 04-15-2012, 07:11 AM   #32
BBQ
Salty Member
BBQ's Avatar
I think you are pulling our chain.
guest (04-16-2012)
Old 04-15-2012, 10:51 AM   #33
Rewards Points: 1,106
I know I've never heard such crap about rope. Hook the rope up to the tugger and pull.
Loose Neutral is offline   Reply With Quote
The Following User Says Thank You to Loose Neutral For This Useful Post:
brian john (04-15-2012)
Old 04-15-2012, 11:11 AM   #34
Rewards Points: 252
Better to be pullin rope than pushin it.
Arc'n'Spark is offline   Reply With Quote
The Following User Says Thank You to Arc'n'Spark For This Useful Post:
BBQ (04-15-2012)
Old 04-15-2012, 03:14 PM   #35
Rewards Points: 3,032
True.
When a rope stretches, it's storing energy. If this energy is released suddenly (as in breaking it), the end of said rope will come flying out of the pipe so fast it'll smash/slice/pummel anything (or anyone) in its path. The guy running the tugger is very likely to be hurt.
We use rope specifically designed for wire pulling. It doesn't stretch much, but it's also not possible to weave a new eye if the original one is cut off.
Old 04-15-2012, 03:15 PM   #36
Originally Posted by HARRY304E View Post
This is the kind we use.
Old 04-15-2012, 03:56 PM   #37
Golden Controls
dowmace's Avatar
Rewards Points: 502
Originally Posted by micromind
True.
A couple years ago I broke a 1 inch rope with a tugger. When the end came out of the pipe it slapped the top of my foot hard enough to swell my foot up large enough it wouldn't come out of my boot.
dowmace is offline   Reply With Quote
Old 04-15-2012, 04:14 PM   #38
Southeast Power's Avatar
Rewards Points: 8,618
NO!!
Use polypropylene or another type of non-stretch rope. Nylon is the last thing you will want to use.
I bought a
3/4" x 600' Dacron Combination Rope / 2 Green Tracers on Ebay for $169.00. I thought it was an excellent deal.
He has an inexpensive polypropylene for sale on his ebay site for $129.00:
http://www.ebay.com/itm/3-4-x-600-Ye...item3371c0fbfc
Old 04-15-2012, 04:30 PM   #39
Maybe you don't realize how much people look after you..
Old 04-15-2012, 04:39 PM   #40
Rewards Points: 1,878
A rope like lots of other stuff contractors buy is a tool. Use it, abuse it, and chuck it out when the time comes. I found the supply houses stock these tools and when needed I'll buy a new one.
In 42 years I have had one rope break (3 times) and prior to using i told the EC I was working for to buy a new one, he refused and we lost a day and a half, he paid for his stupidity.
Rope light bid Cletis General Electrical Discussion 4 04-08-2012 12:03 AM
old rope switch fdew Vintage Electrical 20 02-10-2012 05:36 PM
Rope lighting dilema sparky1423 General Electrical Discussion 11 09-22-2010 02:24 AM
Where do you get your pulling rope? nitro71 Tools, Equipment and New Products 13 07-24-2010 08:36 PM
pulling a permit???? stillirnin General Electrical Discussion 10 02-12-2010 04:44 PM
