Is putting a 20A receptacle on a 15A circuit a violation? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree55Likes
Old 06-24-2017, 07:09 PM   #21
Band Member
emtnut's Avatar
Rewards Points: 2,146
I'm curious if I can put 12 50A receptacles on one 40A circuit... or would I have to bump it up to a 50A breaker ?
I don't really see a problem with it, but wanted to put it out there
You should 3D print a toe attachment for your shotgun
Old 06-24-2017, 07:10 PM   #22
Rewards Points: 23,344
Cletis you hacked an account?
emtnut likes this.
Old 06-24-2017, 07:11 PM   #23
Come on now, would I do anything that isn't code compliant???
Sure you would!
Old 06-24-2017, 09:08 PM   #24
Rewards Points: 792
"They"...the powers in charge of electrical smoke ; keep saying how the "code " is a minimum standard ...so does that mean whatever "flights of fancy " take your mind ; I read that at school !...you can convince yourself to feel confident that it's way above that minimum standard ?
Some days when I look at troubleshooting how someone wired a Marina ....I'm convinced they do !
Old 06-24-2017, 09:49 PM   #25
Rewards Points: 3,236
Is it within code to do so?
Table 210.21(B)(3) specifically allows either a 40 or a 50 amp circuit to supply a 50 amp receptacle.
Old 06-24-2017, 09:52 PM   #26
Just for stoves?
Old 06-25-2017, 01:09 AM   #27
Just for stoves?
It doesn't specify the type of load so it's apply to any load.
Old 06-25-2017, 01:11 AM   #28
Rewards Points: 969
I told you I would never, ever break the code.
Old 06-25-2017, 01:22 AM   #29
MTW
Rewards Points: 10,568
I go above and beyond the code because it's better and safer.
Old 06-25-2017, 01:29 AM   #30
Rewards Points: 969
Yeah, that's why I put outside disconnects on all services, because it's 100% safer.
Old 06-25-2017, 01:33 AM   #31
Haven't seen that guy in a while.
Old 06-25-2017, 02:24 AM   #32
Rewards Points: 19,045
Yeah, that's why I put outside disconnects on all services, because it's 100% easier.
Fify. Not kidding.
If you start feeling the effects of a possible Corona infection, do not take Ibuprofen (ADVIL) to relieve pain, it increases the ability of the virus to replicate itself.
Old 06-25-2017, 09:12 AM   #33
Rewards Points: 969
Fify. Not kidding.
Silly boy. Installing another large piece of equipment that needs large cable termination, having to bring the GEC outside, having to run 4 wire SER inside, having to separate the grounds and neutrals, etc. is far from easier.
Old 06-25-2017, 09:19 AM   #34
Practical thinking.
Old 06-25-2017, 10:03 AM   #35
Rewards Points: 14,919
I had an unpackaged 20A GFCI in the van and wanted to get rid of it. I was just thinking bigger is better; never thought past it. Now I know .
Old 06-25-2017, 10:11 AM   #36
Band Member
emtnut's Avatar
Good to hear you put it back to a 15A
Someone could have plugged in a 2200VA UPS on their kitchen counter
Handy to make coffee and toast in a power outage
Old 06-25-2017, 10:18 AM   #37
Tomorrow morning it gets changed out. It stands between me and my money .
emtnut likes this.
Old 06-25-2017, 10:28 AM   #38
Rewards Points: 969
If your inspector even notices he is gayer than normal inspectors.
Old 06-25-2017, 11:13 AM   #39
Rewards Points: 1,360
He already noticed. That's what this thread is about. He happened to see it when he and 99 were cuddling about to watch The Notebook.
Old 06-25-2017, 11:20 AM   #40
I wasn't even there. It was a note on the GREEN sticker.
Vehicle charger receptacle circuit Paul S. General Electrical Discussion 14 05-25-2017 09:04 AM
CEC regulation on light and receptacle on same circuit katwalatapan Canadian Electrical Forum 13 10-19-2016 02:39 PM
New sump pump receptacle on an old circuit. Mugs Canadian Electrical Forum 14 07-30-2016 10:30 PM
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
Is this overkill? MTW NEC Code Forum 81 03-20-2016 09:26 PM
