Pvc coated rigid unistrut straps ? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-08-2015, 04:57 PM   #1
Rewards Points: 6
Default Pvc coated rigid unistrut straps ?
Are these UL listed to be used with schedule 40, or 80 PVC also besides pvc coated rigid ?
bullet is offline   Reply With Quote
Old 02-08-2015, 05:33 PM   #2
Senior Moment
drsparky's Avatar
Rewards Points: 106
That would fall under the manufacturers listing. Whats the box say?
Old 02-08-2015, 05:40 PM   #3
Rewards Points: 1,224
Not likely. Straps for PVC conduit have to let the conduit slide because of the thermal expansion and contraction issues.
360max (02-08-2015)
Old 02-08-2015, 06:54 PM   #4
Rewards Points: 6
Thanks for the replies. I don't have a box of them. Does anyone know where I can find literature stating that these type of straps cannot be used? Schedule 40 and schedule 80 conduit are Rigid conduit. Some may say since pvc rigid conduit unistrut straps are for rigid pipe and pvc is rigid pipe then they may be used. ??? I need to show literature showing that it's either not UL, or manufacturer listed for the application.
Old 02-08-2015, 07:00 PM   #5
Rewards Points: 6
We use Stainless/Metal Heavywall straps or Rigid straps with PVC and I believe this is acceptable. The contraction and expansion which is written in the code book is very vague.
Old 02-08-2015, 07:34 PM   #6
Retired Account
Rewards Points: 14,650
I went down this road last year Bullet , thread is here , made on heck of a mess too! ~CS~
Old 02-08-2015, 09:22 PM   #7
Rewards Points: 6
Thanks a lot.
Did you wind up using PVC coated unistrut straps with schedule 40/80 ? Was this acceptable to the inspector ? I only have vertical runs from ground up to 4'.
Old 02-09-2015, 06:43 AM   #8
Retired Account
Thanks a lot.
Yes i did use pvc coated unistrut clamps on sch 40/80 bullet. It was acceptable to the ahj because pvc coated were listed. Know that they are expensive and not as available as normal strut clamps.
Old 02-09-2015, 07:20 AM   #9
Southeast Power's Avatar
Rewards Points: 8,648
This would depend on the length of the run.
Are you at a length where you need to have an expansion fitting?
Old 02-09-2015, 07:34 AM   #10
Rewards Points: 6
No short run 4' out of the ground to bottom of equipment mounted on stainless strut racks.
If these ar
Old 02-09-2015, 07:36 AM   #11
Rewards Points: 6
Is there going to be a listing saying that these are acceptable or it's just the AHJ who will decide whether to accept that or have me change it to stainless strut straps. I really wanted to see it in writing from the manufacturer or see it listed as for use with pvc also
Old 02-09-2015, 08:03 AM   #12
If these ar
I think it would be a very good practice to strap it tight in this situation.
Is the conduit emerging out of concrete or is it an underground run coming up out of soil/ gravel?
Old 02-09-2015, 09:14 AM   #13
Rewards Points: 13,693
Expansion and contraction of 4 feet of pipe is nothing to be concerned about. If it's hard fastened in the middle, then you're talking about expansion and contraction in two 2' sections and that's even less to worry about.
Old 02-09-2015, 09:37 AM   #14
Rewards Points: 6
So I assume this means that these straps are UL listed to be used with PVC sch 80. Where does it say in the code that I can't use an EMT strap for schedule 80 conduit. Because this seems like an issue with using the correct materials.
Old 02-09-2015, 10:55 AM   #15
I think you are going to find the code says something like securely fastened.
I might be more like "does it fit" nothing I the code says we have to use unistrut, it's just easy to use. Not cheap but, easy.
Old 02-09-2015, 11:07 AM   #16
I don't think you are going to find any kind of electrical NRTL listing on strut straps. They are considered hardware. You are going to have to look at what the conduit manufacturer tested the conduit with. I suspect it will be very vague.
I think you are looking for something that doesn't exist.
Old 02-09-2015, 11:30 AM   #17
Ty Wrapp's Avatar
Rewards Points: 2,044
If coming out of freshly disturbed soil, wouldn't an expansion fitting be a good idea for soil shrinkage issues?
Ty Wrapp is offline   Reply With Quote
Old 02-09-2015, 12:06 PM   #18
We just sleeve it inside a larger diameter piece of pipe if that's a concern.
Old 02-10-2015, 09:10 PM   #19
Rewards Points: 6
Thanks for all of your replies.
Old 02-11-2015, 11:24 AM   #20
Lurker...
LJSMITH1's Avatar
Rewards Points: 322
Actually, there are NRTL Listings on all cable and conduit straps, beam clamps, and other related support hardware. Applicable products are manufactured to UL2239 - "Hardware for the Support of Conduit, Tubing, and Cable.", and also in the UL Whitebook as DWMU - "CONDUIT AND CABLE HARDWARE".
Many jurisdictions around the country are requiring Listed products to support conduit and MC/AC cable.
Larry
LJSMITH1 is offline   Reply With Quote
The Following User Says Thank You to LJSMITH1 For This Useful Post:
pete87 (02-11-2015)
Running PVC coated rigid Ninety General Electrical Discussion 21 11-14-2013 10:32 PM
90 Rigid to PVC Cletis General Electrical Discussion 35 03-15-2013 10:27 AM
PVC or Rigid pipes. Kevin McDonald General Electrical Discussion 23 08-28-2011 10:37 PM
PVC Coated Rigid Brechi98 General Electrical Discussion 11 11-05-2010 02:16 AM
coated pvc 3197193 Commercial Electrical Forum 34 01-30-2010 05:19 AM
