Question about in floor heating - Electrician Talk - Professional Electrical Contractors Forum
Old 01-20-2015, 10:19 AM   #1
Rewards Points: 14
Default Question about in floor heating
Hey all, I'm replacing an old thermostat from analog to digital. http://imgur.com/vZjbunG I have this at hand and the digital thermostat says maximum 3000w at 240v so obviously the thermostat needs to be higher rated given the wattage of the floor system is 4145 watts. Hypothetically if a low voltage transformer were installed and low voltage wire were run to the existing thermostat would that change things? The new thermostat also says 2 wire on the package and I have yet to open up the old one
Thanks
fernlane is offline   Reply With Quote
Old 01-20-2015, 11:21 AM   #2
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Thanks
No.
So you need the right sized thermostat.
Old 01-20-2015, 11:27 AM   #3
I own stock in FotoMat!
Rewards Points: 6,520
If the new t'stat were connected on the load side to a transformer, which in turn drove a contactor or relay, which in turn was sized properly for the load.....
I can see it working just fine.
Jerry-rigged to be sure, but it would work.
Old 01-20-2015, 10:33 PM   #4
Rewards Points: 1,568
Thanks
You could use that T stat to control a relay/contactor
which would in turn control the heater.
But why would you want to ?
Easyer to just get a bigger T stat surely ?
Old 01-20-2015, 11:44 PM   #5
Rewards Points: 1,379
Back up here. The stats I normally use are rated 3600W. I would have separated that into two zones. You need #12 conductor and a 20 amp breaker. What do you have?
In Floor Heating besc Residential Electrical Forum 3 10-03-2014 07:03 AM
In Floor Heating-Stelpro CEC09 Canadian Electrical Forum 9 12-13-2013 10:18 AM
Radiant in floor heating themostats nmackintosh Structured Wiring 17 07-27-2012 12:43 AM
Floor heating question Seannorva General Electrical Discussion 14 01-27-2012 12:08 PM
Floor heating cdnelectrician General Electrical Discussion 12 01-27-2009 04:03 PM
