Question about parallel groove clamps - Electrician Talk - Professional Electrical Contractors Forum
Like Tree6Likes
  • 1 Post By Bird dog
  • 1 Post By MikeFL
  • 2 Post By splatz
  • 1 Post By brian john
  • 1 Post By Jlarson
Old 05-24-2017, 10:34 PM   #1
Default Question about parallel groove clamps
Can an aluminum alloy parallel groove clamp be used to splice stranded copper to copper wire feeders to an emergency panel or are they only for aluminum to copper splices? If not what would be the reasoning behind that? Thank you for your time
Volt32 is offline   Reply With Quote
Old 05-24-2017, 10:37 PM   #2
Rewards Points: 18,295
Got a picture?
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 05-24-2017, 11:21 PM   #3
Bird dog's Avatar
Rewards Points: 982
Your profile says apprentice. Why do ask? They need to be listed for what you're using them for.
John Valdes likes this.
Old 05-25-2017, 08:40 AM   #4
MikeFL's Avatar
Rewards Points: 630
Look up the manuf's data sheet and see what it says. That's what an inspector is going to do if it comes into question. Make sure it's listed and that you use it in harmony with the manuf's instruction sheet and you're good to go. That's how it works with pretty much everything.
dielectricunion likes this.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 05-25-2017, 08:49 AM   #5
Rewards Points: 1,360
Check the spec. It will tell you what wire materials are acceptable.
Seems to me, if it can splice an aluminum to a copper, it would be fine to splice a copper to another copper.
Old 05-25-2017, 08:55 AM   #6
Rewards Points: 1,328
That's what I'd have guessed too, but check this out ...
http://www.hubbellpowersystems.com/c...oove-aluminum/
... apparently, you have to be careful what goes to what in these, so it's another thing I wouldn't try and guess about.
Old 05-25-2017, 09:37 AM   #7
Rewards Points: 21,898
Are you refering to the compression groove clamp what the ulities been using or split bolts ?
The main thing is the compression or split bolt is that you have to check that manufacter listing to show what it approved like alum to alum or alum to copper or copper to copper so it make a big differnce there.
As far for emergency panels there are some rules it will be in effect so there is few editions of 700's so get someone experinced on this to help you on this one.
Old 05-25-2017, 11:20 AM   #8
Rewards Points: 1,986
If the connector is good for aluminum and copper somewhere on the connector it should say AL/CU. if it is good for AL/Cu it is good for CU/CU
frenchelectrican likes this.
Old 05-25-2017, 02:24 PM   #9
Rewards Points: 254
Parallel groove clamp?
Sounds like its to hold up conduit, not to connect wires.
This is what I imagine he means?
Old 05-25-2017, 02:38 PM   #10
Jlarson's Avatar
Rewards Points: 4,074
No this is what he's probably talking about.
It's more of a utility connector, not as common in inside work.
If it's not marked then you'll need a spec sheet to know for sure.
The Following User Says Thank You to Jlarson For This Useful Post:
John Valdes (05-26-2017)
Old 05-25-2017, 03:21 PM   #11
The only thing we have used close to those is the Burndy 􀀼YGHC-C Hypress and this was used for grounding.􀀪But they are Cu only.􀀫􀀦􀀐􀀦
Transformer internal wiring question JasonCo General Electrical Discussion 11 03-22-2017 06:10 PM
Series or Parallel? JasonCo General Electrical Discussion 13 03-19-2017 04:11 PM
Question about interview score disclosure EmilyRose Electrician Apprentice Forum 18 10-30-2016 12:06 PM
Question about Solenoids (Relay/Starter/Contactor) JasonCo General Electrical Discussion 14 10-03-2016 01:04 PM
Parallel Feeds - Wire length? quarky2001 General Electrical Discussion 10 07-30-2016 04:41 AM
