question: how you guys to check the transformer after wiring up? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
  • 5 Post By brian john
  • 3 Post By gpop
  • 1 Post By Cow
  • 1 Post By brian john
  • 1 Post By varmit
  • 2 Post By B-Nabs
Old 03-20-2019, 05:48 PM   #1
Rewards Points: 530
Default question: how you guys to check the transformer after wiring up?
as we know, there are continuity between the phases for the primary side and the secondary side, like H1 to H2, X1 to X2, X3 to X0, etc
the question is after wiring the transformer up, how to check if the transformer is OK? I mean no short circuit, no ground fault, I turn on the transformer, it will work instead of blowing up
mike883 is offline   Reply With Quote
Old 03-20-2019, 06:32 PM   #2
Rewards Points: 25,344
In production work, I just stand clear.
( I never heat up a (feeder power) transformer with a connected load. )
In such a case a bolted-short will pop a fuse or a breaker in a flash.
The usual fiasco in Service gear: loose bolts// forgotten tools.
The other issue: some transformers vibrate too much as delivered.
They can be quieted down by tweaking their mounting bolts. This involves powering down and pulling all of the covering panels off. Usually you have to come at the relevant bolts from both directions.
If your transformer is too noisy -- contact the factory for advice. Their tech desk is as busy as a Maytag repairman.
Old 03-20-2019, 08:37 PM   #3
Rewards Points: 1,266
Prior to terminating we megger the transformer and feeder separately. Depending on the specifications we will also TTR the transformer and finally, use a Tilt II
https://www.amazon.com/Greenlee-TL-M...ag=googhydr-20
I am never concerned about what we energize because we test everything prior to powering up.
Old 03-20-2019, 09:04 PM   #4
Rewards Points: 694
under 5 grand we megger then power up and test before closing load side breakers. Anything more expensive we bring in someone like brian who has invested in the tools and training to do the work as the cost of the tools and the learning curve is more hassle then its worth.
brian john, dronai and glen1971 like this.
Old 03-20-2019, 09:31 PM   #5
Rewards Points: 530
Tilt II really works? is it any other similar tool like Tilt II?
Old 03-20-2019, 09:33 PM   #6
Rewards Points: 530
how to use the megger to test the transformer? can you describe the details how you do it?
Old 03-20-2019, 09:51 PM   #7
Cow
Rewards Points: 4,336
I turn the breaker on.
Off the top of my head, I can only think of one time in the last 14 years that we got one bad from the factory. And we install quite a few transformers per year.
So for that reason, with the VERY low failure rate from the factory, I don't spend any time megging before commissioning.
telsa likes this.
Old 03-20-2019, 10:34 PM   #8
Megger Primary to Ground
Disconnect the neutral to ground bond and Megger Secondary to Ground
Megger Primary to Secondary
micromind likes this.
Old 03-21-2019, 06:19 AM   #9
Rewards Points: 694
I must admit i have never seen one fail either. Years ago i did see a new 25k/480v leak oil from the bushing. The install window was small so having the rep got us priority repair in place services. Had the rep not been on site we might have re-installed the old one.
Old 03-21-2019, 07:47 AM   #10
Only failure I remember on start up was an EC called with an issue, they had parallel feeds on the primary and they screwed up the feeder identification, nothing with the transformer. Not even a boom the Main CB kept tripping (they closed it 3 times and in the end had to replace the CB.
But in my opinion still worth the 5 minutes, it takes to test
glen1971 likes this.
Old 03-21-2019, 05:34 PM   #11
Rewards Points: 530
but that only prevent the ground fault
what about phase to phase short,
like H1 to H2, X1 to X3 short
Old 03-21-2019, 05:53 PM   #12
Rewards Points: 1,522
The most practical method is to check the wires with at least an ohm meter, (a megger is better) both line and load, phase to phase and phase to ground before terminating the transformer.
frenchelectrican likes this.
Old 03-21-2019, 06:03 PM   #13
Rewards Points: 16,470
Just pull out your favor tool .,, megger ., that will show up when you do the test on megger.
I only got 2 bad one brand new over the years so it was super rare for me to see new one bad straight from factory.
But used one that you need to test more deeper and need more specialist tool like what Brain John do have and Zac I think he deal with too if I recall it correct.
Old 03-22-2019, 09:47 AM   #14
canbug's Avatar
Rewards Points: 1,378
Megger used xformers, new ones I rely on the overcurrent protection. I don't recall ever having a problem.
I had a customer roll a new one down a set of stairs when it fell off the dolly. It still tested fine but I was standing clear when we energized it.
Tim.
Old 03-22-2019, 09:57 AM   #15
Watt Pusher
B-Nabs's Avatar
Rewards Points: 466
Get everyone out of the Electrical room, have an apprentice punch 911 into his phone and hover his finger over the send button, turn on the breaker with a broomstick, breathe a sigh of relief and go for lunch.
brian john and catsparky1 like this.
Transformer Question Blayney86 Commercial Electrical Forum 9 04-01-2016 04:39 AM
Transformer wiring pugz134 General Electrical Discussion 21 03-02-2016 07:38 PM
Transformer question ESPelectricNC Commercial Electrical Forum 20 02-17-2016 12:13 PM
Question for the POCO guys meadow General Electrical Discussion 7 02-07-2016 02:01 PM
Question for the Canadain guys meadow Off Topic (Non Trade) 15 02-03-2016 08:56 AM
