Reasons for voltage loss? - Electrician Talk - Professional Electrical Contractors Forum
Old 07-02-2012, 01:50 PM   #1
Rewards Points: 192
Default Reasons for voltage loss?
Troubleshooting a couple light fixtures that had the lamp holders blown out in an office building and found that the voltage at the fixtures was 96V to ground/neutral. Checked voltage at the breaker and got 117V. The run is only about 75 feet but it does splice at a couple boxes before the fixtures that burned out. Thinking that there must be a bad splice somewhere but I am not the buildings electrical vendor so I had to bow out before I dug to deep. Still would like to know what the likely problem for the voltage drop is.
Thanks in advance!
wow
newspark80 is offline   Reply With Quote
Old 07-02-2012, 02:35 PM   #2
Rewards Points: 3,464
Multi-wire branch circuit? If so neutral issue.
newspark80 (07-02-2012)
Old 07-02-2012, 02:41 PM   #3
Rewards Points: 192
Yes three phase 208/120. Can you define neutral issue? My first guess was a loose neutral in one of the boxes....
wow
Old 07-02-2012, 04:02 PM   #4
Start at the panel and work your way ot. TURN OFF ALL LOADS, what you have is a potential equipment destroyer and fire hazard.
Old 07-02-2012, 04:15 PM   #5
Rewards Points: 192
That was my plan but I had to let the buildings electrician do the troubleshooting.
The light fixtures (Special Italian made things) toasted. Cost to replace $4000 a fixture....
wow
Old 07-02-2012, 04:22 PM   #6
Agreed loose neutral somewhere and that = heat and potential fire.
Liqued is offline   Reply With Quote
Old 07-02-2012, 04:23 PM   #7
Rewards Points: 192
Are halogen lamps dimmable? Could not find the switch but this could very well be the problem.
wow
Old 07-02-2012, 04:35 PM   #8
Yes, but not all. If theres no kind of transformer or ballast in between, if there is it also has to be compatible with a dimmer. So in short most are but not all.
Help with voltage loss Auselect General Electrical Discussion 7 06-11-2012 09:03 PM
Reasons to not start a business wildleg Business, Marketing, and Sales 5 06-23-2010 06:46 PM
Eight Good Reasons Not To Go To Afghanistan JayH General Electrical Discussion 84 01-01-2010 03:06 PM
Voltage loss problem. winright007 Services and Service Equipment 12 09-12-2009 11:37 PM
2 other reasons why I like this site as opposed to some others steelersman General Electrical Discussion 41 03-28-2009 10:56 AM
