Receptacle Behind a Gas Range - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 2 Post By frenchelectrican
  • 1 Post By A Little Short
  • 2 Post By HackWork
  • 2 Post By Going_Commando
Old 09-15-2017, 09:27 PM   #1
A Little Short's Avatar
Rewards Points: 1,146
Default Receptacle Behind a Gas Range
Customer wants a receptacle for a gas range. It is a "free standing" range. What is the height needed for these?
Does it need to go low like an electric range so it can go against the wall?
Don't remember ever having to do one for a gas range and don't know if there is a void anywhere on the back of them so the plug can go into that to allow it to be pushed back to the wall.
Old 09-15-2017, 09:32 PM   #2
Rewards Points: 21,898
The freestanding gas ranges useally cant slam aginst the wall due the gas pipe come up from the wall or floor .,
I useally keep the gas range receptacle low side due some of the gas range the back part of the range get pretty hot.
but most modern gas range do have some type of cavity in back so they can countersunk it more deeper I think about 3 inches the most.
but the customer will have to be aware about the gas shut off valve location ( that will show up on gas code / state codes )
A Little Short (09-15-2017)
Old 09-15-2017, 09:47 PM   #3
Do they have a drawer at the bottom like an electric range?
If so, that usually allows the recep to clear.
Old 09-15-2017, 10:04 PM   #4
Rewards Points: 804
The gas range should have an area towards the bottom of the appliance. Put the receptacle low. Get the model # and google it. You should be able to find information online such as specs and possible areas to locate the receptacle.
Old 09-15-2017, 10:05 PM   #5
MTW
Rewards Points: 11,332
I found out about this the hard way once.
Old 09-15-2017, 10:07 PM   #6
Rewards Points: 804
I feel your pain.
Old 09-15-2017, 10:50 PM   #7
Lady just moved in and hasn't ordered the range yet. So I don't have a model yet.
frenchelectrican likes this.
The Following User Says Thank You to A Little Short For This Useful Post:
Chris1971 (09-15-2017)
Old 09-15-2017, 11:00 PM   #8
Rewards Points: 1,261
In my experience gas stoves have a large cutout behind them for the gas piping. It's not like electric in which the back is flat other than the bottom behind the drawer.
Old 09-16-2017, 11:31 AM   #9
Magic Smoke Remover
Rewards Points: 1,966
I used to put them high but lately the stoves have shown up and where the box ended up was nailed horizontal to the bottom plate of the wall! Gas convection can be really really tight for hookups.
Old 09-16-2017, 03:46 PM   #10
Rewards Points: 131
Your telling me I spent 4 hours moving a gas line 2.5 inches back above a WH, in between framing, water and gas lines going every which way. 4 hours just to get the stove 2.5 inches farther back and I still couldn't get it far enough back to get it all the way against the wall. At least they were happy and paid for my time. The 2 and half inches did make a pretty big difference when your talking the stove sticking almost 4 inches out from the wall originally.
oldblue is offline   Reply With Quote
Old 09-16-2017, 03:57 PM   #11
Magic Smoke Remover
The problem come from these online only companies. Any time a customer orders appliances online from some Chinese middleman it's going to be a pain. Had a customer buy THOR KITCHEN one time, we were there all day hooking that junk up!
The Following User Says Thank You to matt1124 For This Useful Post:
rrolleston (09-20-2017)
Old 09-16-2017, 08:12 PM   #12
Going_Commando's Avatar
Rewards Points: 1,620
That's what I do now. Nail the box right on the shoe of the wall.
frenchelectrican and matt1124 like this.
The Following User Says Thank You to Going_Commando For This Useful Post:
Old 09-17-2017, 02:20 PM   #13
neutral member
readydave8's Avatar
Rewards Points: 258
I don't do many gas ranges but suspect that there is no location that will work with every model
So far been lucky and had range or cut sheet
Dave Ruth
208V receptacle and 120V receptacle ejon1801 General Electrical Discussion 15 03-12-2017 03:17 PM
Melted split receptacle tabs otif Residential Electrical Forum 21 10-26-2016 09:07 PM
New sump pump receptacle on an old circuit. Mugs Canadian Electrical Forum 14 07-30-2016 10:30 PM
Gfci receptacle feeds pool receptacle. Pool pump trips gfci and an hour or less Chevyman30571 Residential Electrical Forum 21 06-08-2016 12:47 PM
Are those little round ears on a receptacle grounded? JasonCo General Electrical Discussion 13 01-26-2016 10:42 AM
