Recessed lighting in grid ceiling - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 2 Post By JoeSparky
  • 1 Post By tmessner
  • 1 Post By splatz
  • 3 Post By B-Nabs
  • 1 Post By 99cents
  • 1 Post By quarky2001
  • 2 Post By readydave8
  • 2 Post By Cl906um
Old 06-13-2019, 10:44 PM   #1
WPNortheast's Avatar
Rewards Points: 184
Default Recessed lighting in grid ceiling
Hey everybody. I am wondering techniques you guys use to cut out 6 inch recessed lights in 2 x 2 drop ceiling tiles. I have like 90+ to do. I used to have this stupid thing with the dish that would catch the dust but sometimes it would start walking around and make a mess. It was adjustable and had a blade. Also to Tesla, I bid the job with the snap to in Arlington snap in MC connectors that also push in instead of screwing down. No locknut fiddling, no screwing in the clamps, you are 200% right about laborsaving materials be worthwhile. It’s just fantastic. The singles cost .87 vs regular locknut/screw type at .36.
WPNortheast is offline   Reply With Quote
Old 06-13-2019, 11:05 PM   #2
Rewards Points: 1,445
If they are all going center in the tile, drill them over a trash barrel. Stack them face to face and back to back or if they are not installed yet, leave them shrink wrapped in the case. Measure 1 and drill through the whole pile a few at a time. Use a carbide grit hole saw - 6 3/8" size is like 20-30 bucks at the big box store
splatz and SummitElectric1 like this.
Old 06-13-2019, 11:12 PM   #3
Rewards Points: 184
Sweet that’s what I was looking for
Old 06-13-2019, 11:13 PM   #4
Rewards Points: 782
forget the cans and use surface mount retros
Forge Boyz likes this.
Old 06-13-2019, 11:43 PM   #5
Modrateur
Rewards Points: 21,782
X2 what he say above this one of the fastest way to deal and leave shrinkwrap on cuz it will hold all the titles in place when you make a plunge cut on them.
with standard hole saw as he posted the size you can blast thru about 2 or 3 depending on thickness and type of grid tile is. if you ever find a deep well verison you should able do at least 4 or 5 at once.
Old 06-14-2019, 06:13 AM   #6
Mensa Player
Rewards Points: 1,517
I never liked going thru a whole case at once, too much risk widening or chipping the ones you already drilled. I just took out as many as the holesaw would drill and put them over a garbage can.
Perfection is the enemy of perfectly adequate.
Old 06-14-2019, 06:42 AM   #7
Rewards Points: 16
If you're doing 90 and have plywood on hand it might be worth making a simple pattern / jig.
J F Go likes this.
Old 06-14-2019, 09:33 AM   #8
Watt Pusher
B-Nabs's Avatar
Rewards Points: 468
Also if you're using a standard hole saw, running the hole saw backwards through the tile helps prevent it tearing chunks out at the edge of the cut. And always drill on the finished side to prevent the hole spalling out.
shocksystems, splatz and armsjac like this.
Old 06-14-2019, 11:26 AM   #9
Rewards Points: 12,221
Did some last week. Took the tiles outside and drilled them.
Old 06-14-2019, 04:59 PM   #10
Rewards Points: 228
I mount the lights with brackets to the T-bar, wire it up, and then listen to the ceiling tile installers curse at me a few weeks later as they cut the tiles themselves :P
Then I go back later and pop the actual lamps into the cans.
quarky2001 is offline   Reply With Quote
Old 06-14-2019, 07:17 PM   #11
Providing you’re given a window of time between installing the grid and tile.
Old 06-14-2019, 08:20 PM   #12
neutral member
readydave8's Avatar
Rewards Points: 30
double-check hole saw size, all cans and wafers not the same
Dave Ruth
Old 06-14-2019, 11:32 PM   #13
Cl906um's Avatar
Rewards Points: 1,206
Heck with the hole saw. Take a straight edge and scribe close to center diagonal both ways to find center, then use roto zip with circle cutter arm and let her rip. It's like two seconds a piece, and never ruins a tile when done from the backside.
jbfan and delaware74b like this.
Old 06-14-2019, 11:40 PM   #14
Cl906um's Avatar
And if you decide to use a hole saw in ceiling tiles for say a 4" hole, don't be afraid to run the drill in reverse for it all. It cuts like butter and won't grab this way.
