Recessed Oversize trim ring - Page 6 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree62Likes
Old 10-01-2016, 09:39 PM   #101
Rewards Points: 14,293
NDC linked to a better option in the other thread, a grit 4-3/8" holesaw. Works on drywall and plaster and never dulls. It's $25 here but like $100 up there
Bring your gold card when you move up here, Hack. We'll give it a good beating .
Majewski likes this.
Old 10-01-2016, 09:44 PM   #102
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
I wish I could visit CA so bad.
Old 10-02-2016, 02:33 PM   #103
Rewards Points: 26,610
The HC-10 needs the smooth shaft pilot + slow revs + plenty of pressure.
It's original bit leaves a wide kerf... so I ground mine to a much thinner profile.
Said reduced profile does WONDERS for the quality of the cut.
There is a strong tendency during use to use excessive speed.
One must back down the revs so as to maintain rock-steady control.
You'll be through the sheetrock soon enough, anyway.
This particular hole cutting tool is so rigid that the pilot mostly serves to position the location -- the octagon lip has a cushion face that should hold the tool steady, mostly.
The original design used standard tooling for the cutting tip. It's too 'fat.'
Hence, one is wise to grind it down -- a lot -- so that its kerf is not so absurdly huge.
This also decreases the dust, the tip resistance... while increasing the elegance of the cut.
It's the one flaw in the tool... bit it's easy to fix.
This tool also has the considerable advantage of having only one cutting tip -- and absolute freedom to determine the size of hole cut -- from 3" on out to 9"+ !
Recessed Light Brand shocksystems General Electrical Discussion 7 09-14-2016 11:35 PM
Recessed lights /no access WronGun Residential Electrical Forum 297 09-14-2016 08:57 PM
Need LED can retrofit trim with magnetic removeable trim Hippie Lighting Design 7 02-15-2016 10:05 PM
Beauty / Trim ring for 4S Box oldschoolvdub General Electrical Discussion 3 02-02-2016 05:29 PM
Exterior Box trim for recessed boxes psgama Residential Electrical Forum 7 01-22-2016 07:18 PM
