Recessing a receptacle in finished brick - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 1 Post By robertandjada
  • 1 Post By joebanana
  • 1 Post By HackWork
  • 5 Post By drspec
  • 1 Post By readydave8
  • 3 Post By 3DDesign
  • 1 Post By 3DDesign
Old 05-21-2017, 03:59 AM   #1
carryyourbooks's Avatar
Rewards Points: 1,292
Default Recessing a receptacle in finished brick
Does anyone do this? If so, do you mind sharing your technique? I've installed many in tile walls with a diamond grinder. In my mind (scarry), I think the same technique should work, but the brick is a bit thicker than tile.
We have always mounted in on the surface with a bell box.
TIA
carryyourbooks is offline   Reply With Quote
Old 05-21-2017, 04:05 AM   #2
robertandjada's Avatar
Tapcon bit and some imagination
Sent from my XT1058 using Tapatalk
360max likes this.
robertandjada is offline   Reply With Quote
Old 05-21-2017, 04:14 AM   #3
Rewards Points: 26,438
This task is COMMON in Europe.
There are a TON of British YouTube videos showing technique and tools.
It's a rarity in North America.
Old 05-21-2017, 04:20 AM   #4
Rewards Points: 21,896
How thick the brick it is ?? a full sized brick or the thin brick style ??
that will make the differnce how you remove the brick and install the receptale in the brickwall.
I have done few of them in Philippines so it simaur to the European metholds of installing it.
Old 05-21-2017, 06:43 AM   #5
Rewards Points: 7,525
Here ya go
Old 05-21-2017, 09:45 AM   #6
Rewards Points: 867
If it's soft brick you can use an oscillating tool with a grit blade. Harder brick is going to need an angle grinder. Drill some holes with a masonry bit to define it's shape and make the corners.
Old 05-21-2017, 09:55 AM   #7
drspec's Avatar
Rewards Points: 1,116
Like this?
For this one we used an angle grinder, SDS drill and a cold chisel. We had to do 2 like this. Took about 15 minutes per hole. We also had to cut in a receptacle box.
Not a good pic but you get the idea
Finish it off with some mortar in a tube and youre good to go
The Following 3 Users Say Thank You to drspec For This Useful Post:
carryyourbooks (05-21-2017), markore (09-12-2017), MechanicalDVR (05-21-2017)
Old 05-21-2017, 10:18 AM   #8
Rewards Points: 2,982
I use the angle grinder, chipping hammer method myself with good results much like drspec posted.
Old 05-21-2017, 10:34 AM   #9
Rewards Points: 3,078
I take a Handy box and and outline the box with a pencil. Bring the box up against the upper brick so that the entire mortar joint is removed. Do the same on the left edge.
Use a 1/4" masonry bit at least 6" long the drill out the center of the pencil line all the way around keeping the holes as close as possible. Drill a few holes in the center and the brick will fall apart. Install the Handy box using Old Work Clips
Usually two in the bottom is all you need. This will permanently support the box and lock it in place. Fill in any gaps with mortar.
It looks original when I'm done.
Greg
The Following User Says Thank You to 3DDesign For This Useful Post:
Old 05-21-2017, 10:37 AM   #10
Rewards Points: 867
Hmmmmm, OWC's hold it that well?
I would typically screw it into the sheathing behind it, shoving something behind the box to keep it spaced out. Or a few tapcons thru the sides into the brick.
Old 05-21-2017, 10:37 AM   #11
neutral member
readydave8's Avatar
Rewards Points: 116
Why a handy box rather than another type?
Dave Ruth
Old 05-21-2017, 10:43 AM   #12
I use a Handy box or Masonry box.
The threaded holes for the screws are inside the box area. Some other boxes have the threaded holes outside the box area and screws can hit the brick or get covered with mortar
readydave8, HackWork and telsa like this.
Greg
readydave8 (05-21-2017)
Old 05-21-2017, 10:56 AM   #13
Yes, OWC's push the box against the brick on the other edge and lock it in place. If there's room, I'll use four, two top and two bottom, but usually just two on one side.
I've never had it fail.
readydave8 likes this.
Greg
Old 05-21-2017, 11:32 AM   #14
Rewards Points: 1,714
If you look at the pic above you will see that the box fits between the mortar joints vertically. You can use a chisel or a hammer drill- hammer drill is easier to screw things up but I have done it.
Best is to drill a series of holes on the break where you want to cut and then chisel it oput where the mortar joint is. Basically remove about half a brick
Old 05-21-2017, 11:56 AM   #15
Rewards Points: 4,998
Diamond blade on a grinder for a BC1110 box or a 4" core drill for a BC54151-K box. Never secured the box with anything except I might use a shim to center the box if required. Mortar in place and you are golden.
Use the same approach with block too. Try to place the boxes near mortar joints or in the webs of blocks is possible.
Cheers
John
Cheers
John
Receptacle for TV mounted in chimney brick Sparkykaboom Canadian Electrical Forum 12 04-20-2017 09:12 AM
208V receptacle and 120V receptacle ejon1801 General Electrical Discussion 15 03-12-2017 04:17 PM
Melted split receptacle tabs otif Residential Electrical Forum 21 10-26-2016 10:07 PM
Gfci receptacle feeds pool receptacle. Pool pump trips gfci and an hour or less Chevyman30571 Residential Electrical Forum 21 06-08-2016 01:47 PM
Are those little round ears on a receptacle grounded? JasonCo General Electrical Discussion 13 01-26-2016 11:42 AM
