reducing washers! - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree34Likes
Old 10-14-2018, 07:15 PM   #21
Rewards Points: 790
The new Canadian electrical code is going to disallow reducer washers on a bonding connector.
Old 10-14-2018, 07:58 PM   #22
Rewards Points: 3,010
can they be used with bonding bushings . 1 issue I have is the connectors that fit #2 acwu sometimes are 1 in throat and the panel does not have a 1 inch KO in the service conductor section
Old 10-14-2018, 09:23 PM   #23
Rewards Points: 763
Yes, the rule just says you can't use reducing washers if the bond path is through the washer. A bond bushing provides a bond to the connector with out using the reducing washers.
John Valdes and eddy current like this.
Old 10-15-2018, 10:38 AM   #24
Rewards Points: 2,074
you can make your own ko, dont need to use the factory ones
oliquir is online now   Reply With Quote
Old 10-15-2018, 06:24 PM   #25
Chops146's Avatar
Rewards Points: 1,032
In an industrial setting I prefer a meyers hub with an RE. For commercial work I will use a knocked out blank if the reducing washers won't tighten up enough.
glen1971 likes this.
None of us is as important as all of us.
Same plight, same fight.
An injury to one is an injury to all.
Chops146 is offline   Reply With Quote
Reusing Bellville Washers Lone Crapshooter Industrial Electrical Forum 12 05-05-2018 04:19 PM
Reducing Washers A Little Short General Electrical Discussion 15 02-03-2018 11:22 PM
Steel bolts carrying current farlsincharge Industrial Electrical Forum 19 11-12-2017 08:42 PM
Reducing impedance for a machine that requires close to none 3rd Rail Commercial Electrical Forum 8 08-03-2017 06:53 PM
Sealed/Sealing Reducing Washer rexElectricianTalk General Electrical Discussion 17 01-20-2016 12:04 PM
