repaired problem circuit - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree45Likes
Old 04-02-2018, 12:15 AM   #21
04gixx6's Avatar
Rewards Points: 79
Just had something similar in a mobile home. Half the home lost power after turning on the tv. No breakers tripped. And I had ground/hot reversed on all of the outlets. I broke the circuit in half until I found the culprit. I upsold the job by replacing all of the backstab with side wire and pig tailing. Found 3 more receptacles with insulation burned off, and most were brittle. Oh, and put the correct size breakers back in since they decided to up the breaker size
MechanicalDVR and readydave8 like this.
04gixx6 is offline   Reply With Quote
Old 04-02-2018, 02:26 AM   #22
Rewards Points: 1,560
readydave8 likes this.
Old 04-02-2018, 08:58 AM   #23
Rewards Points: 2,302
I use to do mobile work . Never again . At best from the factory they are hack jobs.
LC
Old 04-02-2018, 09:12 AM   #24
Rewards Points: 6,421
I always did do mobile home calls without a second thought. It was pretty easy money since a heck of a lot of electricians flatly refuse to do mobile home calls. You sort of have to "shift gears" in your mind to "mobile home mode" to think about they're typically wired and the somewhat unique materials used before you start troubleshooting and it's not so bad. I generally kept them towards the end of the day, if I could, in case I had to suit up and crawl underneath to sort something out. Their money is just as good as anyone else's.
readydave8, splatz and Takideezy like this.
Old 04-02-2018, 08:49 PM   #25
Rewards Points: 140
Originally Posted by emtnut View Post
I knew you were kidding when you started with the 'changing all the staples'
I still think a 30A (or maybe a double 60) woulda fixed it
Absolutely! Tim Taylor. Ya! More power!!!
Sent from my SM-G900V using Tapatalk
Mike_kilroy is offline   Reply With Quote
Old 04-02-2018, 09:19 PM   #26
neutral member
readydave8's Avatar
Rewards Points: 342
Originally Posted by dmxtothemax View Post
so what time is lunch?
Dave Ruth
Old 04-03-2018, 12:44 AM   #27
Old 04-03-2018, 05:11 AM   #28
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
I turn down mobile home work .
(a) Where do you get these materials from?
Supply house and box stores don't carry them
(b) From what I understand about my commercial
liability insurance , this would fall in the category
of boats , rv's & mobile homes (which is not
included in mine)
Old 04-03-2018, 08:28 AM   #29
Rewards Points: 24,212
included in mine)
You order those parts from an RV supply house.
A former work friend was on call for a few mobile home parks and had calls daily after work to go run, I helped him out a time or two but didn't care for working in slums too much.
Old 04-03-2018, 09:43 AM   #30
lighterup's Avatar
Yep...just as I suspected ..you have
to order them. This is not practical for
handling mobile homes in "Service Call"
arena...kinda what I thought .
Old 04-03-2018, 11:35 AM   #31
My friend kept a box of the common items in his van for after work service calls.
Bird dog likes this.
Old 04-03-2018, 08:51 PM   #32
neutral member
readydave8's Avatar
Rewards Points: 342
included in mine)
mobile home electrical rarely needs special parts, change self-contained devices to box w/ standard receptacle. If the plug that connects the 2 halves together is bad, change to junction box. Have tandem breakers and square-head screwdriver on truck already
Dave Ruth
Points per circuit (LED's) meggerman Canadian Electrical Forum 36 08-23-2016 07:27 PM
Arc fault option Anathera General Electrical Discussion 175 07-08-2016 06:35 PM
Combining circuit types in a conduit dkone NEC Code Forum 15 05-20-2016 06:08 PM
Is this overkill? MTW NEC Code Forum 81 03-20-2016 09:26 PM
