Replacing light poles - Electrician Talk - Professional Electrical Contractors Forum
Old 05-20-2016, 09:36 PM   #1
Rewards Points: 278
Default Replacing light poles
Hey looking for some advice on how to approach this particular job.
Current installations consists of a 20ft pole with two HPS heads.
Customer would like a 30ft pole with 3 LED heads.
My concern is the existing pile I have no way of checking depth on it to verify it could work with the new pole. Is this something an engineer should be getting involved with or should we just get a new pile drilled beside it ? Any advice is much appreciated
JPRO2 is offline   Reply With Quote
Old 05-20-2016, 10:05 PM   #2
Service Call's Avatar
Rewards Points: 38
Your profile doesn't state your location, but if high winds would be involved, I definitely would have it engineered first.
Service Call is online now   Reply With Quote
Old 05-20-2016, 10:06 PM   #3
CADPoint's Avatar
Rewards Points: 1,852
Your changing the load dynamic's.
I personally would bring in a structural engineer.
They probably have a rate for dealing with these type of situations.
If you are even thirsty, you are two quarts low.
Old 05-20-2016, 10:33 PM   #4
Rewards Points: 21,898
As other guys spoke up about this and i agree with them..
Get engineer out and they can take a look at the pole base...
As you are increasing height that will affect the pole base..
Try to get more info to engineer so they can tell you and the customer what is the situation is..
Most likeky you will have to make larger pole base... ( check with engineer detals for the base )
Old 05-20-2016, 10:50 PM   #5
Rewards Points: 26,868
Don't be surprised if you have to dig a pilot hole to determine the actual depth of the existing...
And that some compaction test will be ordered.
Yes, the compaction around the old pole base has a material impact on any engineering calcs.
Just exactly whose brain wave decided that the poles needed an extra TEN FEET?
You must realize that the industry makes NO END of fixtures that can spray the lumens all over the lot -- even at 20 feet.
Further, that the makers have amazingly detailed engineering WRT wind load tolerances for their stuff.
The folks in the MOST trouble -- the Gulf and Atlantic coasts. ( Hurricanes. )
NOTHING ( much above ground) will survive tornadoes -- so nothing is engineered to do so.
I don't know if "C" is the Carolinas, Canukistan, California -- or -- Connect-I-Cut, the notorious 'electrician's state.'
Old 05-20-2016, 11:42 PM   #6
I own stock in FotoMat!
Rewards Points: 6,520
If you can probe the soil around properly, you should be able to determine the depth using simple math.
Old 05-21-2016, 08:06 AM   #7
MikeFL's Avatar
Rewards Points: 910
There are poles with wind load ratings on the cut sheets. I used to permit them all the time when I was in the bldg dept. I never required an engineer.
The cut sheet will have minimum soil conditions for direct burial and foundation specs & bolt pattern for poles which bolt to a poured concrete foundation.
If you can take a picture of what you have, it will go a long way in advising you on how to proceed. Also give us a little bit more info on what the owner wants. Does the pole appearance matter? Is this industrial or a shopping center? Permanent or temporary? Does it matter if they're wood or concrete?
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Wiring light switch from outlet WPMN General Electrical Discussion 3 05-06-2016 03:24 PM
Stadium Light Poles BDB General Electrical Discussion 8 03-19-2016 10:28 PM
Light dimming squiresj1 General Electrical Discussion 4 03-15-2016 01:01 PM
light switch near shower huntingflower Canadian Electrical Forum 4 02-17-2016 07:09 AM
power loss indicating light te12co2w Lighting Design 5 02-05-2016 09:26 AM
