Residentail Floor Receptacles - Electrician Talk - Professional Electrical Contractors Forum
Like Tree8Likes
  • 1 Post By HackWork
  • 1 Post By Majewski
  • 1 Post By TRurak
  • 2 Post By TRurak
  • 2 Post By drspec
Old 03-09-2017, 02:36 PM   #1
Rewards Points: 1,523
Default Residentail Floor Receptacles
Which product would you recommend for residential floor receptacles, I need one for carpet and one for hardwood flooring?
There is a garage underneath so I can cut out the drywall for access from underneath if necessary.
Old 03-09-2017, 02:48 PM   #2
Rewards Points: 3,018
https://www.westsidewholesale.com/orbit-flb-r1g-br.html
Old 03-09-2017, 02:50 PM   #3
https://www.westsidewholesale.com/or...-d-r-c-br.html
Old 03-09-2017, 03:12 PM   #4
Rewards Points: 14,229
I have never seen them but these guys seem to make a quality product:
http://www.lewelectric.com
We have a great little manufacturer in Canada called Wellmark Electric but that won't do you any good.
A few things to consider:
A flip up lid with a gasket is best for wash down.
A round cover means you don't have to line anything up straight (particularly nice in tile). I know you're not doing tile.
It's nice to offer a choice between brass and stainless steel.
Old 03-09-2017, 03:17 PM   #5
These will be under tables in a living room and great room, never seen.
I like the idea of the Sillite with the floor ring. I want something easy to install with a holesaw.
Old 03-09-2017, 03:25 PM   #6
I like the look of that.
Old 03-09-2017, 03:29 PM   #7
Nice and clean right?
The main thing is that I want to be able to use a holesaw instead of jigsawing out a square hole.
Old 03-09-2017, 05:05 PM   #8
Switched's Avatar
Rewards Points: 9,244
I use something similar for the very same reason, it comes with its own hole saw too. I would much rather use the hole saw than the multi-tool.
Also, most of those covers accept a new color pretty easily from a rattle can. I've painted a number of them bronze to keep them from standing out so much.
https://www.platt.com/platt-electric...px?zpid=588184
Old 03-09-2017, 05:17 PM   #9
Oh Jeez, remember the other day when you said I read too far into the fine print??
I actually saw that outlet you linked to on Home Depot's website earlier and thought it would be perfect. But when I read all the reviews a lot of them said that the plastic part inside that holds the outlet is very flimsy and breaks.
Did you notice that?
telsa (03-09-2017)
Old 03-09-2017, 05:26 PM   #10
Switched's Avatar
I've used these a number of times and never had that issue. I think too many guys are using drills/impacts and just overdoing it, instead of learning how to use their tools.
I like the cover on the one you posted though, it can't get lost if it is attached.
Old 03-09-2017, 05:34 PM   #11
Going_Commando's Avatar
Rewards Points: 1,542
Arlingtons from amazon. They are something like $28 a piece with plastic covers. They have white and brown.
https://www.amazon.com/gp/aw/d/B00AA...40_FMwebp_QL65
Eta: didnt read the part about holesaws, but the arlingtons are cheap.
Old 03-09-2017, 07:40 PM   #12
Rewards Points: 531
I like these, and the customers like that they can shut the lid and still have things plugged in. I've also used them for cat5 outlets. they come in several different finishes.
http://www.homedepot.com/p/Single-Ga...39BP/202605741
JohnJ65 is offline   Reply With Quote
Old 03-09-2017, 07:45 PM   #13
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
These are all I have ever used and it worked....
Looks nice!
I want!
Old 03-09-2017, 08:03 PM   #14
Rewards Points: 52
I've used the law electric round one. I've only done them old work in hardwood. You cut the finished floor first but don't go through the subfloor. Then you cut a smaller hole,in the subfloor and the box has a lip that sits on the uncut subfloor. They work great.
TRurak is offline   Reply With Quote
Old 03-09-2017, 08:03 PM   #15
Rewards Points: 52
Lew electric not law
Old 03-17-2017, 10:23 PM   #16
drspec's Avatar
Rewards Points: 1,116
Arlington makes a new drop in floor box you can install with a holesaw
http://www.aifittings.com/catalog/fl...kits/FLB4362MB
splatz and Majewski like this.
Old 03-17-2017, 11:20 PM   #17
mdnitedrftr's Avatar
Rewards Points: 1,131
This is what we use. Super simple to install. If you're going through hardwood, their holesaw sucks. They also make it aluminum.
- Rich
mdnitedrftr is offline   Reply With Quote
Old 03-18-2017, 01:59 AM   #18
I forgot to come back and mention that I used the Silite method which worked very well. It cost $40 in total and looks great. It's very small and low profile.
