Residential AC disconnect - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 05-17-2012, 12:22 PM   #21
Sunny 1's Avatar
Rewards Points: 150
I say no
Sunny 1 is offline   Reply With Quote
Old 05-17-2012, 03:33 PM   #22
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
Originally Posted by carryyourbooks View Post
there is no need for a disconnect if it is "within sight". see definitions, article 100. within sight means 25 feet. if its 30 feet and you can still see it, its not within sight. don't forget, you still need a convenience outlet. the purpose behind the disconnect and the receptacle is for the hvac tech. he wants to make sure no one energizes it while he is servicing it. the receptacle is for his use.
Then I guess he would hate an old co worker of mine who always used a single pole switch for the 240volt air handler
Old 05-17-2012, 03:36 PM   #23
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
An error like that could put you out of business if someone (anyone) was injured because of negligence, I suspect.
Replies based on NEC 2014
The Following User Says Thank You to Magnettica For This Useful Post:
Semi-Ret Electrician (05-17-2012)
Old 05-17-2012, 03:49 PM   #24
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
The boss tagged him a couple times for it , but life went on beyond the pallisades.
Old 05-17-2012, 05:42 PM   #25
220/221's Avatar
Rewards Points: 4,328
Originally Posted by Clarky View Post
I'd also do the disconnect and service GFI, makes it easier and safer for the tech guy.
IMO, that is just adding more potential failure points (four more terminals and the female&male contact points on the pullout). All modern breakers are HACR so I see no purpose.
Old 05-24-2012, 02:29 AM   #26
HVAC equipment also includes internal or "hidden" (from the user) controls and switches that are necessary for proper system operation. Just knowing that these items exist is the first step in diagnosing & repairing an air conditioner, heat pump, refrigerator, freezer or other HVACR equipment that is not working or not working properly..
moshei is offline   Reply With Quote
Old 05-24-2012, 02:33 AM   #27
Do not set the thermostat for cooling below 68 degrees. This can cause a multitude of problems with your air-conditioner, including freezing up.
Remember to turn off your humidifier for the summer cooling system..
The Following User Says Thank You to moshei For This Useful Post:
Semi-Ret Electrician (05-24-2012)
Spa Disconnect as a service disconnect? Sparkman1234 General Electrical Discussion 14 03-04-2013 10:10 AM
Service disconnect - 400A residential Vermaraj Residential Electrical Forum 31 08-04-2012 09:22 PM
Disconnect Apprentice_617 General Electrical Discussion 4 05-03-2011 11:53 PM
hot tub disconnect. charlie Bob General Electrical Discussion 1 03-04-2010 07:05 AM
40 amp disconnect Absolutetruthz General Electrical Discussion 3 08-01-2008 10:08 PM
