Resistance and splicing - Electrician Talk - Professional Electrical Contractors Forum
Old 02-21-2015, 12:37 PM   #1
Rewards Points: 24
Default Resistance and splicing
Can someone please explain to me how resistance is affected when there is too many splices on a circuit. Thanks
cj8278 is offline   Reply With Quote
Old 02-21-2015, 01:08 PM   #2
Rewards Points: 18,265
Put a bunch of split bolts in a circuit, tighten them down to the correct torque and install properly and the resistance of the circuit will go down.......
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 02-21-2015, 01:29 PM   #3
Rewards Points: 1,224
Can you cite a source for that?
Old 02-21-2015, 03:23 PM   #4
Rewards Points: 1,367
Depends on the splice, could make resistance go up or down
Old 02-21-2015, 05:52 PM   #5
Rewards Points: 2,950
It all depends on how good/bad the splice is. It may have absolutely no affect at all, and shouldn't if it is done correctly.
The Following User Says Thank You to btharmy For This Useful Post:
TheWireNut (02-21-2015)
Old 02-21-2015, 06:20 PM   #6
Rewards Points: 265
I would argue that a proper splice should have negligible resistance. What kind of splice are you talking about? Low med or high voltage?
TWN
TheWireNut is offline   Reply With Quote
Old 02-21-2015, 08:55 PM   #7
NacBooster29's Avatar
Rewards Points: 1,018
I'm calling bs. No way it would drop.
The Following 2 Users Say Thank You to NacBooster29 For This Useful Post:
millelec (02-27-2015), samgregger (02-21-2015)
Old 02-21-2015, 09:03 PM   #8
The only way it would go down is if your splice made the wire shorter, like a wire was cut and you spliced it with a split bolt and overlapped a lot of material.
The only way it would make it go up is if you added material or used a spice material with a resistance greater than your conductor, like a steel crimp on copper wire.
Old 02-21-2015, 09:07 PM   #9
Same here.
The resistance of the wire for a given length will always be a constant, and splices will almost always (90+ % of the time) add a very small (or large if corroded or poorly made) amount of resistance to the overall resistance of the conductor. There is no way the addition of splices will cause a drop in resistance.
About the only way to drop the resistance of a conductor (and MAYBE the splice(s) ) is to supercool it.
Old 02-21-2015, 11:35 PM   #10
Rewards Points: 419
In comparison to....conductors in free air with no physical connection?
Unless you're being sarcastic, I fail to understand your logic.
mikey383 is offline   Reply With Quote
Old 02-21-2015, 11:51 PM   #11
You are cutting the wire, and striping an inch or two of insulation off, and then joining the wire together again in the split bolt. Now you have shortened the conductor, and split bolts done properly will hold the now shorter sections of wire together without loss of voltage across the splice. Ask a Burndy engineer, they will confirm. So although it won't be a great reduction, it will be a reduction. Class dismissed. There is going to be a test on Tuesday so make sure to read all the way thru chapter three.
JOBS GROWTH SOARS
RECORD WORKING
Drudge Report
Old 02-22-2015, 12:28 AM   #12
There is no way that the splice itself has lowered the resistance. Now if you have shortened the total length, sure, but that is not because the split bolt connection has reduced the resistance.
The resistance of the connection may approach that of the the unspliced conductor, but it will always be higher.
Old 02-22-2015, 12:42 AM   #13
Rewards Points: 419
There is no possible way that a splice can be made where the resistance is lower than if the conductor hadn't been spliced.
The Following User Says Thank You to mikey383 For This Useful Post:
guest (02-22-2015)
Old 02-22-2015, 05:30 AM   #14
Very Long Vacation
Rewards Points: 5,262
Originally Posted by mxslick View Post
Same here.
A properly done splice will contribute unnoticeable resistance. But any real loss, something for example that generates one, one/half or 1/4 of a volt in voltage drop across the splice is a server fire hazard. At that point you would have a glowing connection.
guest (02-22-2015)
Old 02-22-2015, 09:27 AM   #15
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
Maybe if someone could break out a micro ohm meter we could get to the bottom of this.
The Following 3 Users Say Thank You to Jhellwig For This Useful Post:
BuzzKill (02-22-2015), guest (02-22-2015), John Valdes (02-22-2015)
Old 02-22-2015, 10:19 AM   #16
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
I very very seriously doubt that
Old 02-22-2015, 11:47 AM   #17
cuba_pete's Avatar
Rewards Points: 3,005
...Class dismissed. There is going to be a test on Tuesday so make sure to read all the way thru chapter three.
Nice try...this wool is making my face itchy, though.
Old 02-22-2015, 12:07 PM   #18
Very Long Vacation
Wheres BigJohn or Badelectrican when you need them?
Old 02-22-2015, 12:43 PM   #19
Tapeman's Avatar
Rewards Points: 135
Splices don't make resistance go down, period.
Retired without ever breaking Ohm's Law.
Tapeman is offline   Reply With Quote
The Following User Says Thank You to Tapeman For This Useful Post:
guest (02-22-2015)
Old 02-22-2015, 02:39 PM   #20
So far it is your conjecture vs my conjecture. At least I have spoken to Burndy about this in the past, and while they man was somewhat cadgey because of the fact that almost no one in our trade will properly install split bolts, so mostly they will add resistance, he maintained that there will be no added resistance to a proper bolted connection. I just don't remember his name sadly. I did this using google about a half decade back maybe to get to that source, so get your engines going, and lets get the proof and dunk the macmikeman into the water. Or not....
JOBS GROWTH SOARS
RECORD WORKING
Drudge Report
Torque vs resistance Cantafford General Electrical Discussion 6 02-19-2015 12:07 PM
[email protected] 95 from Resistance @35 bibincjoy General Electrical Discussion 3 07-18-2014 03:26 PM
UF splicing brichter General Electrical Discussion 14 05-26-2014 06:11 PM
high resistance? 3tigerz Services and Service Equipment 8 04-18-2009 01:52 PM
high resistance? 3tigerz Site Help and Suggestions 3 04-09-2009 04:34 PM
