Resistance and splicing - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2015, 03:51 PM   #41
Rewards Points: 374
By that thinking, stranded wire would be a mess of impedence. On the contrary, splitting up a conductor into the strands lowers resistance.
I think I did not explain myself well enough, I am thinking skin effect would come into play and the splice would reduce it. I could be wrong, hey, it would not be the first time!
Hawkrod is offline   Reply With Quote
Old 02-28-2015, 01:15 AM   #42
Rewards Points: 314
What is "Glyped"? I was just taught to clean the wire best I could, tighten the split bolt, wrap with rubber tape then wrap with regular electrical tape (Usually Scotch 33 if it was on hand)
Briancraig81 is offline   Reply With Quote
Old 02-28-2015, 04:18 AM   #43
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 244
Macmikeydude, did you parallel the bolts?
I see your theory. The EG at Burndy says the splice won't add resistance to the cable so therefore the cable has miraculously been shortened thus the resistance has been lessened. If they splice it properly which means a mechanical bond creating an electrical bond.
Cowboy words of wisdom.
Old 02-28-2015, 10:26 AM   #44
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
At under 600 volts?
Old 02-28-2015, 10:39 AM   #45
Rewards Points: 18,281
I stated an electrical fact. I blew a few people out of the water with it, nobody challenges their perceptions of the world order better then how I do. Now people think I am a big proponent of split bolts... One guy is asking me my methods for installing them. The best part is who in their right mind would add splices just to reduce vd.... Them bugs ain't so cheap..
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 02-28-2015, 02:01 PM   #46
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
In a perfect world, splices are fine.
In the real world, the more splices you have, the more points of failure you have. The more points of failure you have, the more likely that one of them will cause a problem. If you look at any well designed system (take the space shuttle as an example), the best way to make it work well, and make it as easy as possible to fix, is to reduce the number of points of possible points of failure.
As others have mentioned, the likely causes of each splice (point of failure) are:
  • poor installation resulting in later failure
  • connector failure
  • oxidation
IMO connector failure is usually due to poor installation as well, which brings us to the last one, oxidation.
Oxidation will likely be a factor of the environment, and in most buildings with standard environmental controls, it is negligible, but in a lot of environments it can be a major cause of multiple failures.
I'm assuming the OP was talking about general line (low) voltage issues.
If you are dealing with any type of communication or control wiring that is not a simple analog signal, you have multiple other issues with connections as well, that go beyond resistance as an issue. (had to mention that)
Torque vs resistance Cantafford General Electrical Discussion 6 02-19-2015 12:07 PM
[email protected] 95 from Resistance @35 bibincjoy General Electrical Discussion 3 07-18-2014 03:26 PM
UF splicing brichter General Electrical Discussion 14 05-26-2014 06:11 PM
high resistance? 3tigerz Services and Service Equipment 8 04-18-2009 01:52 PM
high resistance? 3tigerz Site Help and Suggestions 3 04-09-2009 04:34 PM
