Romex in Channel : Wood Cabinet - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
  • 2 Post By backstay
  • 5 Post By splatz
  • 3 Post By PlugsAndLights
  • 1 Post By onilozay
  • 2 Post By hardworkingstiff
Old 12-27-2016, 08:56 PM   #1
Rewards Points: 241
Default Romex in Channel : Wood Cabinet
I've got a contractor who wants to install a cabinet next to a window in the bedroom. It has a small sitting area with 2 sconces for reading area.
He wants to run romex inside the cabinet wood by routing a channel so its buried in the wood. Then he covers it with a 1X4 which is part of the cabinet design. Goes to pancake box for sconce. He doesn't want MC Cable because of custom cabinet.
My understanding is Romex can go in walls but is it ok to embed it inside the wood like this?
My gut feeling is no, for 2 reasons (NEC 334.15(B) Protection from Physical Damage),
1) heating of wire has no way to cool should it heat up in the channel
2) if cabinet gets loose from wall or moves even a small amount, romex has week spot from wall to cabinet.
Has anyone run into this before, is it up code to embed romex in wood?
Thanks in advance for any feedback!
onilozay is offline   Reply With Quote
Old 12-27-2016, 09:09 PM   #2
German Spy
Helmut's Avatar
Rewards Points: 4,477
Yes, and yes.
The Following User Says Thank You to Helmut For This Useful Post:
onilozay (12-27-2016)
Old 12-27-2016, 09:28 PM   #3
backstay's Avatar
Rewards Points: 296
A built-in cabinet is part of the wall. That said, you protect the wire with steel. In log homes, I buy long strips of steel from Menards and make the groove big enough to lay it in over the romex. Then I will cover it with 1x material.
hardworkingstiff and Majewski like this.
Old 12-27-2016, 09:30 PM   #4
Rewards Points: 241
That sounds like an interesting method, thx for the pointer.
So just like a bottom flat peice, then romex then top piece, sandwiched.
Old 12-27-2016, 09:39 PM   #5
Rewards Points: 1,260
Try this method
http://www.finehomebuilding.com/2001...-vintage-house
If you use a channel at least 1/16th inch thick you should be OK
The Following 2 Users Say Thank You to splatz For This Useful Post:
onilozay (12-27-2016), telsa (12-28-2016)
Old 12-27-2016, 09:48 PM   #6
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
And don't worry about the heat build up. If it can be encased in spray foam
it'll be ok anywhere.
P&L
backstay, five.five-six and Max C. like this.
Old 12-27-2016, 10:03 PM   #7
Rewards Points: 241
Thank all of you, this answers my questions! Yes, that diagram is sweet, so I'll just have to let the contractor know, he's a very good woodworker, clearly we'll have to protect it with steel casing, just like nail plates protect for screws. Thanks!
PlugsAndLights likes this.
Old 12-27-2016, 11:11 PM   #8
Rewards Points: 18,235
You'd love living around where I live. Older houses have cables running in a channel on all the baseboards capped with a little 1/2''x 1/2 '' cover nailed on over top . Then they go up a chase cut in door frames , all the way around any door, and sometimes are run below the aluminum floor jamb of glass sliding doors, and in thousands of houses the lights and many home runs are just run across the top of the roof plywood sheeting with a 2''' wet mop job right on top. At least thats how the older days. We still run lots of wood molding to cover wiring. 7/8'' thick, 1-5/8 '' wide . A U cut out of one side for covering the cables. But all new houses have to be framed by minimum 2''x 4'' construction nowadays. Those get drilled holes. In the middle.....
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 12-27-2016, 11:25 PM   #9
five.five-six's Avatar
Rewards Points: 10,226
Why not just run it in MC?
five.five-six is online now   Reply With Quote
Old 12-28-2016, 12:35 AM   #10
Rewards Points: 241
I initially thought MC cable too, but he doesn't want it showing, aesthetics I guess.
Old 12-28-2016, 02:03 AM   #11
NDC
NDC's Avatar
Rewards Points: 2,410
I think he means run MC and also have it covered. This would eliminate having to add a protection plate.
Old 12-28-2016, 05:29 AM   #12
Rewards Points: 14,714
I read 300.4(F) to require a protection plate for any cable or raceway installed in a shallow groove (like the OP is considering).
Also review 300.4(A)(2), the exceptions list some metal conduits but not MC.
splatz and Byte like this.
Romex in conduit Incubus311 General Electrical Discussion 38 12-27-2016 07:16 PM
Hole saw for drilling wood HackWork Tools, Equipment and New Products 20 06-12-2016 08:22 PM
Caps for LED tape channel electric_mayhem Residential Electrical Forum 7 05-28-2016 06:53 AM
Under cabinet lights with NM chknkatsu Residential Electrical Forum 58 03-24-2016 07:39 AM
