Romex near chimney of fire place - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By MechanicalDVR
Old 02-20-2018, 09:02 PM   #1
Rewards Points: 36
Default Romex near chimney of fire place
I'm really curious to find out if there's somewhere in the code book that states to keep wiring away from a chimney of a fire place. Today I ran romex through a few studs in front of a chimney of a fire place. It doesn't seem right for so many reasons. The wire must be 10" away from the stone wall of the chimney. Can somebody either prove me wrong to make me feel a little better or tell me where in the code book it says so, so I can change this up asap. I'm not the type of electrician who's ok with the quote "looks good from my house".
mikedl361 is offline   Reply With Quote
Old 02-21-2018, 08:22 AM   #2
The Accidental Welder
CTshockhazard's Avatar
Rewards Points: 1,738
That close it is going to melt and burn the house down.
Nah, you're absolutely fine.
I hate to see her go, but I sure love watching her walk away.
Old 02-21-2018, 08:26 AM   #3
Rewards Points: 24,438
if the wooden framing has survived since the place was constructed your wiring should survive.
readydave8 likes this.
Old 02-21-2018, 09:39 AM   #4
Rewards Points: 36
It's a new construction home.
Old 02-21-2018, 09:42 AM   #5
Air is not a good conductor of heat.
Is it a masonry or metal chimney?
If it's metal triple wall doesn't really throw that much heat either.
Old 02-21-2018, 10:58 AM   #6
Rewards Points: 36
Its masonry.
Old 02-21-2018, 01:37 PM   #7
Rewards Points: 8,233
What's the ambient? De-rate as necessary.
Old 02-21-2018, 02:03 PM   #8
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,722
It's fine.
Doing old work, the chimney chase is the most popular express to the attic.
And most houses around here are OLD.
"Hanging ceiling fans for grandma"
M E T G A !
Signal1 is online now   Reply With Quote
Old 02-21-2018, 10:59 PM   #9
MikeFL's Avatar
Rewards Points: 950
Its masonry.
The masonry takes care of thermal protection. If you're in framing outside of the masonry you are fine. You can hold your hand on any part of the outside of the brick chimney, even where it passes through the framing, as long as they built the chimney correctly, and you won't feel excess heat.
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 02-22-2018, 06:14 AM   #10
Rewards Points: 36
Its masonry.
Thanks for that explanation Mike. So would that mean if it was a modern duct style chimney you couldn't pass in front of it.
Old 02-22-2018, 08:52 AM   #11
MikeFL's Avatar
Rewards Points: 950
If by "modern duct style" you mean the triple wall metal flue in a framed chase, you should be fine anywhere outside of the flue, including in the framing which contains that flue. Best practice is to check with the data sheets from the fireplace.
And if you ever need to run into the masonry, such as for a heatilator fan, the specs for the fan are likely to spec high temp wire which is readily available on the open market.
GPS Timers
(833) GPS-TIME
Fire alarm guy hancholo General Electrical Discussion 20 08-01-2017 12:35 PM
Romex in Channel : Wood Cabinet onilozay General Electrical Discussion 11 12-28-2016 04:29 AM
In-floor radiant heating cause fire freddmc General Electrical Discussion 19 12-12-2016 11:43 AM
Fire Alarm How To Book LanceBass General Electrical Discussion 19 03-26-2016 04:40 PM
anbody up? fire place safety... !?!? Electrical Student Off Topic (Non Trade) 11 01-29-2016 09:18 PM
