Rough in tools and accessories? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree14Likes
Old 06-10-2017, 12:23 PM   #1
Default Rough in tools and accessories?
What do you guys do as far as your rough in supplies? Wire nuts, staples, etc. Do you have a separate tool pouch that you wear or just carry the containers with you? I know the pros have there set routines and stuff that way they are not wasting time as they go through the process.
Mcswain is offline   Reply With Quote
Old 06-10-2017, 12:34 PM   #2
trentonmakes's Avatar
Rewards Points: 138
Dont forget nail plates!
Seen As A Tiny Blip From Space
Old 06-10-2017, 12:58 PM   #3
Rewards Points: 400
Rough in, like trim out, requires few tools.
I would say no pouch is required.
I would put on a cloth nail apron. And for sure would use one of those cable reels (dispenser) talked about so much here.
Old 06-10-2017, 01:28 PM   #4
I have my Ideal 14/2,12/2 strippers, Klein linesman, Klein needle nose, Klein Phillips and straight, and Klein hammer and some electrical tape. That's what I was thinking some kind of apron for the accessories so can just grab and go not have keep getting from containers.
If I don't have belt and pouch I spend more time looking for tools lol
John Valdes and splatz like this.
Old 06-10-2017, 02:37 PM   #5
Rewards Points: 26,780
What are you roughing in ?
Residential ? ( wood framed ? )
Boxing-in means a hammer, and the occasional usage of a tape measure// story pole... and a Sharpie// fat pencil.
Punching holes means a cordless Super Hawg// Impact driver or some such.
You stay on one task until done... or close to it.
Roping in Romex means spools for the cables... and goes fast.
Poking-in, strapping and make-up... does not take many tools.
Old 06-10-2017, 02:46 PM   #6
Rewards Points: 7,735
One task at a time. Boxin', hammer, tape measure......Drillin', drill/cord..........Ropin', hammer, nailbag.........Make-up, strippers, util. knife, nailbag. Lunch.
Switched likes this.
Old 06-10-2017, 03:14 PM   #7
Switched's Avatar
Rewards Points: 9,804
I was just telling my apprentice this week that when you look at the job, look at it as a series of tasks. Assembly line the installation and in the end you will be much faster and efficient than when you do not do it.
The Following User Says Thank You to Switched For This Useful Post:
Knightryder12 (06-12-2017)
Old 06-10-2017, 03:31 PM   #8
Rewards Points: 21,898
All it depending on if it is on resdential or commercal side the amout the tools and materals will varies some.,,
basically start with boxes first then bore holes or punch holes on steel studs if need to be., then run the romex or MC/emt to the shortest route as possible.
a tip .,, start the homeruns first that will save ya alot of headache then after that then go from there just hit it hard and fast.,,
Old 06-10-2017, 03:39 PM   #9
Rewards Points: 23,302
Like the others have said, one task at a time.
I like a Carhartt apron and a small Klein pouch that will hold linemans, needlenose, strippers, and a screwdriver.
If there is more (larger) hardware involved I use a Klein bolt bag that has a large pouch and a pocket.
Old 06-10-2017, 08:51 PM   #10
Yeah that's the routine I'm working on. In residential right now at school I'm attending. Was already knowledgeable just trying speed my game up and process.
Old 06-11-2017, 08:10 AM   #11
Then it's track shoes and work outs for you.
Old 06-11-2017, 08:21 AM   #12
Rewards Points: 14,871
I use Nalgene screw top jars for bits and pieces.
Old 06-11-2017, 08:42 AM   #13
Rewards Points: 2,262
Back in 73 when I did residential we carried
A Vaco 1/4 X 6 screwdriver a pair of Klein's a 6' wood rule and a nail apron with all of the trinkets we needed. The only time we used a hammer was to nail up boxes. The wiring did not start until all the holes were drilled and the boxes were uup.
John Valdes and MechanicalDVR like this.
Old 06-11-2017, 08:48 AM   #14
drewsserviceco's Avatar
If you like those, check out Viewtainer.
I have a few different sizes I am planning on using for small quantity of random hardware (the stuff that gets you out of a jam. I've been using one in my tool bag for screw tips and bits and am digging it.
They're available on Amazon as well as through their website. Just shop for prices, sometimes they're much higher than they should be with some Amazon sellers.
Old 06-11-2017, 08:49 AM   #15
Do you put them in some type of tray or crate to carry them around or what?
Old 06-11-2017, 08:50 AM   #16
Are you in the right thread ?
The OP is roughing in residential circuits.
Bits and pieces... good grief !
Old 06-11-2017, 09:08 AM   #17
Get off the shrooms, dude. Wire nuts, Wagos, wood screws, staples, etc. - they all have dedicated containers. It shouldn't be difficult to understand, even for you.
Old 06-11-2017, 09:09 AM   #18
I just throw them in an open top tote. Works for me .
Old 06-11-2017, 09:15 AM   #19
Rewards Points: 865
If you're doing it like that, why not just use an organizer (or many organizers)? They take up less space and are stackable.
Old 06-11-2017, 09:21 AM   #20
Attachment 106826
Jars are nice for storing larger quantities but the organizer is much more handy for working out of.
