Roughing in New Home - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree76Likes
Old 12-22-2016, 08:30 PM   #61
Rewards Points: 14,205
I'm not going to take down a light fixture to troubleshoot a finicky arc fault circuit.
I see wiring like that in houses built in the 60's. They used to feed the lights and then spider down to the receptacles. It made for a mess of splices in the ceiling. Makes no sense now (if it ever did) with arc faults and recessed lighting.
Majewski likes this.
Old 12-22-2016, 08:31 PM   #62
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
I keep as much separate as possible when given the opportunity!
Old 12-22-2016, 08:48 PM   #63
The only code requirement we have here for a receptacle and lighting to be on the same circuit is for the smoke detector. I feed the smoky off the bathroom (no AFCI requirement for the bathroom receptacle).
Old 12-22-2016, 09:10 PM   #64
zac
Rewards Points: 826
Originally Posted by LawnGuyLandSparky View Post
As an example, when I wired houses I'd run the feed to a light, then a 3-wire to it's switch, then a 2-wire to the next light, etc... because when I did wire houses the contractor would supply only regular depth boxes and NO deep ones except for an electric stove or clothes dryer. Of course, back then a blue Carlon still cost about a quarter, but a roll of 14/2 was about 20-25 bucks.
Thanks Lawn Guy.
I started commercial and always worked with drawings so I usually try to lay out my circuitry and as built as I go.
Also switches now require a neutral NEC 404.2 (C) at the box so I can't have a California 3 way. This adds to the wire fill in a box that's going to get a dimmer.
I've only done a few custome homes and usually use shallow boxes but decided this time just to go big on all of them. After seeing the back of the switch (posted) I'm having second thoughts!
Old 12-22-2016, 09:17 PM   #65
I carry a few of these around for deep boxes (or just end up using a 4X4 and a plaster ring, whatever's handy).
zac and Majewski like this.
Old 12-22-2016, 09:24 PM   #66
Majewski's Avatar
Zac if fill becomes a huge issue, you could try the wifi 3ways couldn't you? Not in the sp spots I suppose...
Old 12-22-2016, 09:30 PM   #67
zac
Rewards Points: 826
I use something like this for my switches in 2 and 3 gang as well. I ran out and used the carlon box to finish out. I like the screw type for counter flush applications in remodel cut ins.
The carlon cut ins with the dimmer attached usually have a gap even with an oversized cover.
Old 12-22-2016, 09:32 PM   #68
zac
Rewards Points: 826
I'm confused
Old 12-22-2016, 09:33 PM   #69
I wish I could buy a box like that up here. Our plastic boxes have a metallic strap going from a device hole to a ground screw.
Old 12-22-2016, 09:37 PM   #70
Majewski's Avatar
Originally Posted by zac View Post
I'm confused
Don't worry, I'm drinking and will fade away soon enough.
Old 12-22-2016, 09:38 PM   #71
zac
Rewards Points: 826
It's only 7:37 over there! What the heck is going on?
Old 12-22-2016, 09:38 PM   #72
Majewski's Avatar
I try to use these and the dg ones a lot. They even have gangable ones.
Old 12-22-2016, 09:39 PM   #73
Majewski's Avatar
Oh huge party, you didn't get the invite?
Old 12-22-2016, 09:41 PM   #74
zac
Rewards Points: 826
I'm just getting off of work probably wouldn't make it in time.
Old 12-22-2016, 09:42 PM   #75
Majewski's Avatar
Ok I'll order you like 5....and um drink em before they get warm and order you 5 more...
Old 12-22-2016, 09:47 PM   #76
LawnGuyLandSparky's Avatar
Rewards Points: 172
Arc faults mean almost a complete separation of lighting and receptacle circuits.
From what I've read about them and nuisance tripping, good on you. If I were to build new today, I'd yank them all out right after the inspection.
Old 12-22-2016, 09:50 PM   #77
Rewards Points: 172
Thanks Lawn Guy.
Zac there are deeper boxes that aren't as deep as the one you posted!
Old 12-22-2016, 10:00 PM   #78
zac
Rewards Points: 826
I know. I usually buy 18 for the receptacles and 20 cubits for the switches. I didn't really even think about until I saw the back of the box flush with the stud. Won't do that again unless the back is a concrete is cmu wall.
Home inspections bhaughery New Member Introductions 76 11-29-2016 10:44 PM
New home today's price Northern Girl Business, Marketing, and Sales 45 06-30-2016 10:34 PM
Manufactured Home Codes smorkle General Electrical Discussion 20 06-26-2016 10:48 AM
Mobile Home SparkyJ Residential Electrical Forum 10 04-08-2016 08:21 AM
Electric heat for log home Grogan14 Residential Electrical Forum 7 03-13-2016 08:15 PM
